![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
__________________ 3rd rebuild on the way...maybe... |
![]() Join Date: Jan 2011 Location: Lynn Haven/Niceville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 831
Groans: 77
| Not Ranked : 0 score
__________________ 2011 MS3 BLACK MICA W/TECH PACKAGE BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC Stratified Tune In Progress SCCA Member# 450495 Class - SMF TRMotorsport C3 17x9 Hancook 255/245 RS-3 LIQUOR AND WHORES |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Driver looks like a rich 16 year old who sucks dick when he's not getting his pockets lined with cash from daddy. Fuck your LED's Go post that shit on 24/7
__________________ |
| The Following 6 Users Say Thank You to helmetface For This Useful Post: | Kamaril (06-27-2013), Kellerspeed3 (06-27-2013), mazdaspeedemon3 (07-23-2013), Pointless (06-27-2013), robertof (06-28-2013), speed3sailor (07-13-2013) |
![]() Join Date: May 2011 Location: Alhambra, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,199
__________________ ![]() 2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub. 346hp 392lbs of sexyness |
| The Following User Says Thank You to Oliverms3 For This Useful Post: | skeeter149 (06-27-2013) |
![]() Join Date: Sep 2012 Location: Columbus, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 939
Groaned at 25 Times in 15 Posts
| Not Ranked : 0 score Looks like a pumpkin. He's gonna be pissed when the heat from his calipers/brakes melt his LEDs. |
| The Following User Says Thank You to gigliotti175 For This Useful Post: | Cheapspeed (06-28-2013) |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
| Not Ranked : 0 score Gayer than Ellen.
![]() Join Date: Jul 2008 Location: Brockton,Mass
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,661
Groans: 206
__________________ [SIGPIC][/SIGPIC] O4 350z "Money pit" 06 MS6 "Gone" BOSTON STRONG |
![]() Join Date: Feb 2010 Location: Seattle, WA
Rep Power: 2233 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 142
Groaned at 58 Times in 37 Posts
| Not Ranked : 0 score Of course he's playing dubstep
__________________ Zoom-Zoom-Coons on 05/10/16 ![]() 2011 Mazdaspeed3 Celestial Blue Mica BUILT BY CORKSPORT CP-e Catted Downpipe || CP-e HPFP || Corksport Turbo || Corksport 3-bar Map Sensor || Corksport EBCS|| Corksport SRI || Corksport TIP || Corksport CBE || Corksport Boost Cut Killer || Corksport FMIC || Corksport SSP || Corksport MM Inserts || Corksport Blue Shift Knob || Corksport Injector Seals || DM Full EGR Delete Kit || Corksport License Plate Relocation Kit || Snyapse Engineering Synchronic BOV || Cobb V3 Accessport (PD Tune in progress) |
(Thread Starter) | Not Ranked : 0 score Forgive me MSF for I have sinned. I have had impure thoughts about a riced out Mazda since my last confession.
![]() Join Date: Feb 2009 Location: Dupont wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
| Not Ranked : 0 score can u say RICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
![]() Join Date: Feb 2012 Location: San Antonio, TX
Rep Power: 1139 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,253
Groans: 50
Groaned at 37 Times in 21 Posts
| Not Ranked : 0 score Later, usually try be kinder more gentle but you are on the wrong forum, 24/7 is more your style. This is a performance site, if it doesn't make you faster why bother.
__________________ 2010 Velocity Red w/tech package: Cobb AP, Cobb DP, Tr8L FMIC, Auto Tech internals, BNR S-4 turbo, JBR 3.5 aluminum intake, CPE stage 2 rmm, JBR 80 duro TMM, JBR 70 PMM, JBR SSP and bushings, JBR 5mm spacers, JBR RSB, JBR By Pass Tube, Magna-flow CBE with the "fix", NGK 6510's, JBR EBCS, SSP OCC(now Kozmic), JBR EGR delete, EGR deleted, JBR IM TIG, JBR TB TIG-coolant by-pass, Turbo smart BPV, built block with CP pistons, eagle rods, ported head, pinned cams, shimmed valve springs, Spec clutch stage 3, FordMoCo full syth transmission fluid, Eibach pro kit, ported IM with VCTS delete, ported exhaust mani, Werksracing strut tower brace, TB Performance front traction bar and mid-chassis brace, Corksport adjustable struts and shocks, slotted/drilled rotors, SS brake lines, and lots of TLC. FreekTuned Kotzur built 93/E-85 Prius killa. |
(Thread Starter) | Not Ranked : 0 score I got a kick out of it, was looking for CX7 races (didn't find much) when I stumbled on it. My car stays stock as far as aesthetics are concerned.
| The Following User Says NO Thank You to Cheapspeed For This Un-useful Post: | Celestspeed3 (06-28-2013) |
![]() Join Date: Jun 2013
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Not a big fan on the led's behind the wheels.. But if anyone can help me find those fog lights with that side lamp that would be awesome! !!!!!! I'v searched everywhere I possibly could but no luck yet! |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score that does not not suck
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() Join Date: May 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 18
| Not Ranked : 0 score Cool idea, terrible execution. I could think of a couple ways this wouldn't have looked so cheap, but I wonder how he did it. Using a microcontroller, or some sort of analog setup perhaps?
__________________ MazdaEdit ECU Flash (14psi flat boost) Corksport Power Series TBE AEM Short Ram Intake Autoexe Strut Tower Bar Forge BPV ETS 3" TMIC H&R Sport Lowering Springs Complete interior/exterior LED swap (VLEDS v3 triton amber, red, and switchback) |
![]() Join Date: Nov 2010 Location: p.pines, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 372
If you're still interested in get them, I can find you the part numbers. Let me know. This the little mod I did to them a while back... 2009 Fog Light Bezels
__________________ 09 CX-7 GT - cp-e Xcel intake w/ Nviscid pipe, ETS TMIC, HKS BPV, autometer boost gauge | |
![]() Join Date: Jan 2013 Location: Rockland County NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 131
| Not Ranked : 0 score I like the video title "LED tuning"
__________________ 2008 Sunlight Silver MS3 Turbosmart Dual Port, JBR SRI + TIP, JBR 88 RMM, JBR SSB, Autotech HPFP, SU Test Pipe, Freektuned OTS+ ![]() |
Thanks! | |
| Neo car audio help | Dizzy Turbo | MazdaSpeed 3/6 - Car Audio & Electronics | 4 | 11-28-2012 12:09 AM |
| MS3 vs Audio A4 2.0T | curlyface | Street Racing Stories ( Bench Racing ) | 11 | 05-18-2012 10:13 AM |
| Audio Help | Joellc2434 | MazdaSpeed 3/6 - Car Audio & Electronics | 5 | 12-16-2011 04:37 PM |
| Audio | Rican219 | MazdaSpeed 3/6 - Car Audio & Electronics | 10 | 05-22-2008 07:03 PM |
