> CX-7 > Interior / Exterior Appearance Mods
 Old 01-05-2012, 09:24 AM   #1
Salukis10's Avatar
Posts: 18   (View Stats)
Salukis10 has a spectacular aura aboutSalukis10 has a spectacular aura about
Default HID Conversion Kits
Only had my 2011 Mazda CX-7 for a week. This is my first new car, but the upgrade bug has already set in. I dont want to do anything major to the car just yet, but was thinking some HID lights would look real nice. I want the brigest possible lights. I found a set here:
NOTTO® SE - Complete HID Conversion Kit - 2011 Mazda CX-7 HID Conversion Kit
15,000 K - Infinte Blue
I was wondering if anyone has used this brand or have suggestions on another brand. I looked at the DDM site but i dont see anything as bright.
Also this kit come with relays, the instructions says that the relays might not be needed. But i was thinking that since I am going with a such a bright bulb that I may need them. ANy sugestions, comments, concerns would be much appericated.
Thanks ahead of time.
Salukis10 is offline   Reply With Quote
 Old 01-05-2012, 09:28 AM   #2
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
The "K" is degrees Kelvin which is the color, not the lumens. 4300/4500k will have the most lumens.
The Following User Says Thank You to triplejumper18 For This Useful Post:
Salukis10 (01-05-2012)
 Old 01-05-2012, 09:42 AM   #3
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
You dont want 15k HID's those are ricer bright and you wont be able to see a damn thing. Most common is 6k
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Boost Addict is offline   Reply With Quote
The Following User Says Thank You to Boost Addict For This Useful Post:
 Old 01-06-2012, 07:17 AM   #4
ryandlor's Avatar
Posts: 126   (View Stats)
ryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant future
brighter is wattage, ....These are 35W. To get brighter, more light you would need a 55W kit that draws more power. These dont come in 55w, but you can get 55w from DDM.
15K is a color. 15k will be more blue than a smurf. 5k is good, nice white light . I have 6k and it has a little too much blue for my liking. 4300k is purest white i think, below that you move to yellow.
I wouldnt buy this kit personally, use a ddm kit.
2009 CX-7
Platinum Silver Metallic
AWD
ryandlor is offline   Reply With Quote
The Following User Says Thank You to ryandlor For This Useful Post:
Salukis10 (01-06-2012)
 Old 01-06-2012, 07:40 AM   #5
Groans: 196
55w kits have more lumens in general but in each respective wattage level 4300/4500k will have the most lumens and it decreases in brightness the further you move from that in both directions.
 Old 01-06-2012, 10:45 AM   #6
Salukis10's Avatar
Looks like I will be buying a kit from ddm. Thanks for your help.
 Old 01-06-2012, 11:35 AM   #7
35W, 5000K will work just fine, if you have not ordered. I got a lot of miles on my DDM Tuning 3000K HID's that I am using for foglights.
 Old 01-06-2012, 11:39 AM   #8
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Please do not get 15k whatever kit you choose!
BillsFan (01-06-2012)
 Old 01-06-2012, 01:30 PM   #9
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Lol with 15k you wont see 20 ft in front you.
TEAM LUXURY
 Old 01-08-2012, 09:42 AM   #10
Salukis10's Avatar
So many peopl have told me that I don't want the 15K that I am not going to buy them. I think I am going with the 6K in a 55 Watt. From what I am understanding this will give a nice Bright White light with just a small hint of blue. I am probably going to buy the kit from DDM.
The Following User Says Thank You to Salukis10 For This Useful Post:
Sid3wayS (01-08-2012)
 Old 01-08-2012, 10:26 AM   #11
Stick with 35 watt. 55 is known to fry wiring. You will need to get the accessory harness for 55 watt, minimum.
 Old 01-08-2012, 10:28 AM   #12
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Groans: 70
the 6k will be fine in 55w - 55w usually washes out a lot of color.
scubasteve711 is offline   Reply With Quote
The Following User Says Thank You to scubasteve711 For This Useful Post:
Salukis10 (01-12-2012)
 Old 01-13-2012, 03:04 AM   #13
goo
goo's Avatar
Posts: 38   (View Stats)
goo will become famous soon enoughgoo will become famous soon enough
I upgraded mine to hids, the universal type. Had problems aligning it. The bulb rubber housing or the rubber thing that hold the bulb is too small, so when the clip does not hold it in place. My mechanic had to bend the clip and put some electrical tape round the rubber housing to make it fatter. Hope someone understands me.
goo is offline   Reply With Quote
 Old 01-13-2012, 06:13 AM   #14
08cosmic3's Avatar
Posts: 2,920   (View Stats)
I have the DDM 35w 6K and love it. 35w's is plenty bright and some say that 55W is too bright and just pisses off other drivers. There is a large truck in my hood with super bright HID's mounted in refracting headlight assemblies and it is obnoxious. Truck sits up high and blinds everyone.
 Old 01-13-2012, 07:05 AM   #15
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
i've got the ddm 3500k fogs and they have been great. one of my ballasts went out occasionally, sent it back, now a new one is on its way. i love lifetime guarantees.
glad to hear you decided against 15000k. that's crazy. 6000k is perfect. 8000k is already too blue. 15000k would be almost black.
 Old 01-16-2012, 12:01 AM   #16
Salukis10's Avatar
thanks for the heads up!
 Old 01-18-2012, 08:55 AM   #17
jstcruzin's Avatar
Posts: 152   (View Stats)
jstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the world
I second the 35w over the 55w! Easy plug and play install from DDM. I have the 6k slim kit in the fogs and jst ordered the bulbs for the factory HIDs and they are awesome. If you want more white I'd go with the 5k, it's closer to stock. I'll try and take a couple pics tonight for you to see...
09 CX-7 GT - cp-e Xcel intake w/ Nviscid pipe, ETS TMIC, HKS BPV, autometer boost gauge
jstcruzin is offline   Reply With Quote
 Old 03-02-2012, 05:58 PM   #18
beardog420's Avatar
Posts: 45   (View Stats)
beardog420 will become famous soon enoughbeardog420 will become famous soon enough
ive been using DDm in all my cars for a long time - how was the install?
beardog420 is offline   Reply With Quote
 Old 03-02-2012, 06:01 PM   #19
08cosmic3's Avatar
Was very easy, more time spent trying to decide were to put the ballast than the actual install.
 Old 03-03-2012, 03:30 PM   #20
mikak88's Avatar
Posts: 10   (View Stats)
mikak88 can only hope to improve
Groaned at 7 Times in 4 Posts
im in the same boat as you salukis10. did you get any photos of the lights installed?
mikak88 is offline   Reply With Quote
 Old 03-03-2012, 05:58 PM   #21
beardog420's Avatar
i just placed my order - any tricks i should know about as i read i have to go through an access panel in the fenderwell
 Old 03-03-2012, 06:03 PM   #22
lildisco's Avatar
Posts: 332   (View Stats)
lildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond reputelildisco has a reputation beyond repute
I had the ddm kit in my regular 6 and never had any issues. I've installed them on several 6's, and I haven't heard of them having any issues. If I could do it over again, I'd get the retro fit kit to fit the d2s bulbs. The glare off signs and other things that reflect is killer. Fine for short trips, but you get eye fatigue if your on long trips. Part of the reason why I went with a gt, Hids standard. Once you go hid, you never go back. 5,000k 35w is perfect. I wanna say therpmstore, still has my picture of my 6 on their website. It gives you a good comparison of what they are like stock. Also gives you what Kelvin gives you the best light output. I think 4,000k - 5,000k is the most light output or Kelvin.
Cooper Red Mica 2008 CX7 AWD GT w/Nav
K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors
Originally Posted by TopGear Magazine
This is a good car, a fine family SUV that will serve you well, if unremarkably. It's on sale from 18 May, and its arrival signals the phasing out of the larger CX-7, like the 2 supermini, one of Mazda's underrated, underappreciated cars. Let's hope the CX-5 avoids the same fate. It deserves to.
Tuned with
lildisco is offline   Reply With Quote
 Old 03-03-2012, 06:08 PM   #23
lildisco's Avatar
If you bought the ddm kit, they just plugs into your existing harness. The ballast its the hardest because you have to try to find a place to mount it. I zip tied mind to the frame. Going on 6 years w/o any issues.
Tuned with
 Old 03-03-2012, 06:32 PM   #24
beardog420's Avatar
im sure ill be fine mounting it somewhere, but was wondering about gaining access to the bulbs without removing the lamps. am i right to say that there is a panel in the fenderwell which is what i read somewhere here.
Vogtland Springs, AutoExe Strut Bar, HIDs, 20% Tints, Tails and Reflectors Tinted, Baby Seat
More to come
Gone, but not forgotten
2009 Chevy Trailblazer SS
2005 Mini Cooper S - To much to list
2002 Nissan Spec-V - To much to list
1986 Buick T-Type - 400sb on a 200 hit
1986 GMC Jimmy - Lifted for some fun in the mud
1987 VW Golf - 2.0L transplant
1988 Ford Rustang LX -306DSS Roller Motor
1980 Chevy Iroc-Z
1980 Chevy Monte Carlo - 355sb
 Old 03-03-2012, 07:39 PM   #25
lildisco's Avatar
you remove the finder liner to gain access to the back of the housing for the bulb. you may have to make a hole in the dust cover on the back of the bulb so that you can run the wires from the ballast
Tuned with
 Old 03-03-2012, 09:12 PM   #26
beardog420's Avatar
when making this hole, have you noticed any condensation in the housing?
More to come
1980 Chevy Iroc-Z
 Old 03-03-2012, 09:47 PM   #27
lildisco's Avatar
i believe the ddm kit came with a rubber grommet. It's been 5 or 6 years since i've done an install of these. My 6 hasn't had any nor to my knowledge as any of the others i've done.
Tuned with
 Old 03-03-2012, 10:14 PM   #28
beardog420's Avatar
yes they do - thanks
More to come
1980 Chevy Iroc-Z
 Old 03-03-2012, 10:45 PM   #29
lildisco's Avatar
i think i used a little bit of RTV sealant around the grommets because i cut the hole slightly too big. just in case moisture did try and get in. I know my stock HID's in the cx7 fog up, which i guess is a common issue, but Mazda said they wouldn't repair it. where my beam is, it's not effected, but where my hi-beam and the turn signals are, do fog up. My headlights do fog up almost everytime i use them, but i haven't noticed any bad effects other than aesthetics.
Tuned with
 Old 03-20-2012, 09:44 PM   #30
beardog420's Avatar
simple install - the headlight bulb covers have a hole in them so the DDM grommets fit snug inside with no cutting.
More to come
1980 Chevy Iroc-Z
 Old 03-21-2012, 06:36 AM   #31
lildisco's Avatar
Sweet!
Tuned with
 Old 05-08-2012, 05:38 PM   #32
DementedCX's Avatar
Posts: 39   (View Stats)
DementedCX is a jewel in the roughDementedCX is a jewel in the roughDementedCX is a jewel in the rough
With respect to color...that's completely your choice...as for brand... I used SuperVision on my 08 TC had it for almost 3 yrs and never once had to replace any part of it.
DementedCX is offline   Reply With Quote
35w to 55w conversion Beauj27 MazdaSpeed 6 - How-To's 13 09-28-2011 10:34 PM
Useful Conversion Guide Crossbow Mazdaspeed3/6 General Discussion 0 04-13-2009 06:48 AM
di to pi conversion cbspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-05-2009 09:48 PM
HID Conversion Kit SpdFreak MazdaSpeed 3/6 - Car Audio & Electronics 62 01-27-2009 05:18 AM
Page generated in 0.48946 seconds with 35 queries
