> CX-7 > Interior / Exterior Appearance Mods
  • 1 Post By Thor Hammer
 Old 04-26-2011, 02:32 AM   #1
ganas's Avatar
Posts: 12   (View Stats)
ganas has a spectacular aura aboutganas has a spectacular aura aboutganas has a spectacular aura about
Default License plate bulb replacement
Hi all,
I'm new to this forum and CX-7 too. I'm thinking of getting the license plate bulbs replaced but have no idea where to start. Any idea how? Thank you.
Cheers
ganas is offline   Reply With Quote
 Old 04-26-2011, 07:08 AM   #2
ganas's Avatar
Just found it from another forum:
Installation tips:
Dome Lights -- Those are the easiest, just use a very small flathead and find the little slot along the edge of the lens to pop it off.
Map Lights -- Use a kitchen butter knife on the driver or passenger side of the assembly to pry the clips. It can take a little while to find the leverage point, but don't worry, the clips are metal so you won't break them. Once you find the leverage point you'll definitely know because the assembly will pop right out. This thread has great pics.
License Plate Lights -- As described in the first post in this thread, just use a flathead to pop the covers off, its easy. The worst part is removing the original bulbs in the chilly weather. I suggest that if you're struggling, then turn the lights on for a few seconds and the heat will loosen them up a bit (obviously turn them off before you go yanking on them again though).
The Following User Says Thank You to ganas For This Useful Post:
flappypaddles (09-11-2014)
 Old 04-26-2011, 05:40 PM   #3
bscar's Avatar
Posts: 1,846   (View Stats)
bscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the world
Groans: 46
led replacements?
bscar is offline   Reply With Quote
 Old 04-27-2011, 03:12 AM   #4
ganas's Avatar
led replacements?
That's included..as long as you manage to get all the bulb covers opened by following the previous instructions, then you can change the lights to other standard bulbs or LEDs. Make sure you have the correct bulb size/type.
Found the license plate and dome interior lights to be quite easy to do, and haven't had a chance to do the map lights..it's quite hard though, you don't want to leave some scratches on the roof. Will update if I get that done
 Old 04-27-2011, 03:26 AM   #5
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
thanks for posting your findings. i have been thinking about getting the led license plate light myself. i think it would really clean up the back of my speed
oh10speed3 is offline   Reply With Quote
 Old 04-27-2011, 03:55 AM   #6
ganas's Avatar
@oh10speed3:
Glad to share and, yes it does man..my car is white and looks awesome when you have the LEDs installed. Will post some pics when I get a chance.
 Old 04-28-2011, 05:05 PM   #7
bscar's Avatar
Groans: 46
there's a guy at work who has LEDs for his plates and a single strip on the bumper of his truck. Those lights double as extra brake light and turn signals(red LEDs). Pretty neat when you see it.
 Old 04-29-2011, 04:54 PM   #8
TonyN's Avatar
Posts: 28   (View Stats)
TonyN is a jewel in the roughTonyN is a jewel in the roughTonyN is a jewel in the roughTonyN is a jewel in the rough
Originally Posted by ganas View Post
Hi all,
Cheers
bulb size 194, use a flat head to pop the license plate cover off and then just pull out the old bulb and install the new one. I use Superbrightleds.com 194 SMD Pure white LED, it is pure white like my lexus.
*07 Mazda CX-7 GT AKA The Baby Wagon
Baby Stuff
*05 Mercedes Benz E500 AKA The Daily
Apperance Package, Sport Package, Comfort Package, Lighting Package, Navi, Keyless Go, Airmatic Suspension, AMG Quad Tip Exhaust,
*94 Toyota Supra Turbo AKA The Garage Anchor
Precision 63 / Auto 3.8k Stall / Methanol Injection / Volk SF Challenge / Recaro Speed / Seibon / Eibach / KYB / Greddy / Bomex / C-West / RMM / Tial /
TonyN is offline   Reply With Quote
 Old 01-05-2015, 02:54 PM   #9
Buck79's Avatar
Buck79 has a spectacular aura aboutBuck79 has a spectacular aura aboutBuck79 has a spectacular aura about
Did anyone ever get the map lights replaced?? I'm in the process of trying to pry off the assembly and am a little nervous about messing up!
Buck79 is offline   Reply With Quote
 Old 01-05-2015, 09:26 PM   #10
lvdukerider's Avatar
Posts: 44   (View Stats)
lvdukerider has a spectacular aura aboutlvdukerider has a spectacular aura about
Its been several years since ive replaced mine but if my memory is correct there are two hidden tabs along the rear edge you press foreward to release the asembly from the headliner, dont just pry it out.
lvdukerider is offline   Reply With Quote
 Old 01-06-2015, 06:17 AM   #11
Buck79's Avatar
Thanks for the input. Ill give it a shot after work today and maybe take pictures as well. Thanks again!
 Old 01-06-2015, 03:20 PM   #12
Buck79's Avatar
Ok, the trick to doing the map light bulbs is just to pry it down a little from the rear, not the windshield side, until it pops loose. You will see the two metal clips on the left and right side after you do this. Use just enought pressure to pop it loose or you could screw up the wiring harness. Then there are two knobs that the lights are in that come out with about an 8th turn. Those are the bulb holders. Thats it! Just replace your bulbs and it pops right nack in place.
 Old 01-09-2015, 05:32 PM   #13
Buck79's Avatar
Heres a couple of pics. Much more nice.
 Old 09-27-2016, 03:42 PM   #14
gman121's Avatar
Posts: 3   (View Stats)
gman121 is an unknown quantity at this point
Default License plate bulbs...NEW GUY!
Anybody know how to replace license plate bulbs on a 2008 Mazda CX-7?
Thanks!
gman121 is offline   Reply With Quote
 Old 09-27-2016, 04:00 PM   #15
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Hammer and a chisel.
OK, ok. I think the lenses just pop out. CX7 might be different from my MS6. Why not search on the internet webzzzingy thingy?
gman121 likes this.
 Old 09-27-2016, 04:35 PM   #16
gman121's Avatar
Hahah! Thanks! I did try them internets but all they showed was the lowly MS6...JUST KIDDING!
You were right though...the lenses just pop out and then, if you have tiny, 4 year old fingers, the bulbs will come right out as well.
License plate frames KayWhy MazdaSpeed 3/6 - Appearance 13 06-10-2009 09:32 PM
CP-E License Plate Mount SgtP Custom Performance Engineering (cp-e.com) 43 11-08-2008 12:45 PM
Page generated in 0.35350 seconds with 28 queries
