> CX-7 > Interior / Exterior Appearance Mods
 Old 01-20-2011, 11:46 AM   #1
SugarCeanCx7's Avatar
Posts: 4   (View Stats)
SugarCeanCx7 is an unknown quantity at this point
Default plasti dip
Anyone consider blacking out their badges with plasti dip? Ive been doing some research and I'm considering trying it out. Im concerned with the front badge because its so large compared to the rest. Any thoughts?
SugarCeanCx7 is offline   Reply With Quote
 Old 01-20-2011, 11:50 AM   #2
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
I used the spray kind on the handle-pole spring for my stand up jet ski. If you want a glossy finish, I wouldn't recommend using it as it has an almost satin/semi-gloss texture. Also, I'm not sure where you are located, but I have a feeling it wouldn't stand up well to ice buildup, but it does hold up to water just fine.
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
 Old 01-20-2011, 11:59 AM   #3
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Personally I wouldn't do it. Its going to make the emblems a bit thicker and give a rubber look which I have a feeling would look cheap. Just take your time and scuff them well and rattle can them with a few coats.
2009 CWP Speed3
 Old 01-20-2011, 12:05 PM   #4
jstcruzin's Avatar
Posts: 152   (View Stats)
jstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the world
I would strip the chrome off completely (takes a week or two).
I brought mine free of chrome to a body shop and got them all painted to match. Got it done cheap and didnt have to worry about every couple months touching up cheap paint chips.
09 CX-7 GT - cp-e Xcel intake w/ Nviscid pipe, ETS TMIC, HKS BPV, autometer boost gauge
jstcruzin is offline   Reply With Quote
 Old 03-28-2011, 09:58 AM   #5
ryankokesh's Avatar
Posts: 7   (View Stats)
ryankokesh is an unknown quantity at this point
I used it to black out my chrome kidney grills on the bmw. If the emblem comes off (I dunno - I'm a mazda noob), then it'll be really easy. If not, you'll have to use an x-acto to cut around where you tape it off before you peel the tape off.
Doesn't look rubbery, but does look matte. Holds up really well too.
ryankokesh is offline   Reply With Quote
 Old 07-11-2011, 12:58 PM   #6
You need to be VIP to buy/sell here @SugarCeanCx7.
I deleted that guy's posts, as they did sell a long time ago, in the FS section. VIP access is only $10 a year, and gives you access to a lot more of the forum
 Old 03-02-2012, 06:04 PM   #7
beardog420's Avatar
Posts: 45   (View Stats)
beardog420 will become famous soon enoughbeardog420 will become famous soon enough
im bringing back an old thread. I am going to be doing this to the front M emblem, the chrome strip below it and the stock wheels.
plasti dip spray has been used for along time now with no issues on many different vehicles.
pix will be posted once i have completed it all.
beardog420 is offline   Reply With Quote
 Old 03-02-2012, 06:10 PM   #8
ziggidy08's Avatar
Posts: 389   (View Stats)
ziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the worldziggidy08 is the leader of the world
Groaned at 19 Times in 5 Posts
I used it on my rims about 2 weeks ago and it turned out really good. Comes out a bit matte black but looks great.
Mods:
* FREEKTUNE 9gal 93 / 3gal E85 * Cobb AP * JBR 3.5" WP * FMIC * Autotech HPFP * JBR Dogbone RMM * JBR RSB * Speed Daddy Catless DP * ** Speed Daddy CBE * H&R Sport Springs * Corksport Short Shift Plate *
ziggidy08 is offline   Reply With Quote
 Old 03-02-2012, 06:39 PM   #9
08cosmic3's Avatar
Posts: 2,920   (View Stats)
I did the GT-R mod with plasti dip, been on now for several months but is starting to peel in a couple spots. I'll redo it this summer better than I did the first time because I like the look.
 Old 03-02-2012, 07:36 PM   #10
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
did it to my stock rims, turned out pretty good. they even hold up against machine car wash. but will start to come off i'd say.... 6 months? i did it just so to see how my car would look with black rims, and the result was promising then i got a set of real black rims haha. (enkei raijin)
dhsieh911018 is offline   Reply With Quote
 Old 03-02-2012, 07:43 PM   #11
08cosmic3's Avatar
Pics of the new Enkei's or it didn't happen.
 Old 03-02-2012, 07:47 PM   #12
posted on this forum already... i tried to upload here but it says "u've already posted them on this forum"... link to thread:
#10
new enkei wheel
 Old 03-02-2012, 07:51 PM   #13
08cosmic3's Avatar
Looks good, always like the red and black together. Are they light weight like the RPF1's or heavier like their tuner wheels?
 Old 03-02-2012, 07:59 PM   #14
there are three catagories: performance, tuning, racing.
RPF1 is in the racing category, which is the best. raijin and fujing are in the tuning series, which is like in between racing and performance... performance obviously are the heavy ones. enkei says the main difference is that these come with MAT technology or whatever... making cast wheels lighter and stronger than non MAT treated cast wheels ... for the price you can't go wrong with these
 Old 03-02-2012, 08:21 PM   #15
08cosmic3's Avatar
How much did they cost and what size did you get?
 Old 03-02-2012, 08:35 PM   #16
18x8 +45 , with continental DWS 225 40 18, that's what i had on he stock rims, didn't want to spend money on an extra set of tires so... total cost is 1050(labor, shipping, tax...etc)
 Old 07-11-2011, 12:03 AM   #17
well i feel terrible for not checking back on my posts in a timely fashion. I am very interested in your already black emblems if still available. I didnt use plasti dip due to all of the negative feedback and i think that black would go perfect with my electric blue setup. i have a 07 by the way
Page generated in 0.35393 seconds with 28 queries
