> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
Like Tree122Likes
 Old 04-16-2014, 06:15 PM   #1
torquemaniac's Avatar
Posts: 733   (View Stats)
Default Big turbo build CX-7 :P
I decided to make a thread about my CX-7 build to spice up the CX-7 forum a bit...most of the thread on here are about problems or cosmetic mods...time for more POWA for the CX-7
Ill have terrible gas millage, maybe destroy the transmission, but its gonna be fun while it last
My objective is to finish the engine build this summer...not so sure about that with only a driveway to work, 2 kids that require a lot of time (another baby girl due for august), a tight budget and lots of custom fabrication
The project started with finding a big turbo that spool fast, is in my budget and is reliable
After making a lot of research, I found the turbo I wanted : the Holset HY35
Holset turbo are reliable (the one I got had 305972km on it with no shaft play) and are used on Dodge Ram Cummins (turbo diesel)...they can be found for cheap because the Cummins guys like to upgrade to even bigger turbo (like we do with K04)
Holset are know for spooling fast (for their size) on gasoline engine, because the turbine is engineered for the colder exhaust gas of diesel engine
The HY35 was also engineered to spool faster in order to be used on Cummins with automatic transmission
Here are the specs of the HY35 :
Compressor wheel inducer 56mm
Compressor wheel exducer 76mm
Turbine wheel inducer 65mm
Turbine wheel exducer 58mm
Estimated A/R 0.65 (Holset dont publish A/R...)
Estimated flow rate 60lbs/min (in between a GT3071 and GT3076)
After a couple months at looking everyday at the local (Canadian) ads, I found my baby for 300$
Here is a picture of the HY35 versus the K04
More details of the build to come...
2011 CX-7 AWD 2.3 turbo
The Following 26 Users Say Thank You to torquemaniac For This Useful Post:
06wwpms6 (05-21-2014), ABolewski (07-10-2014), adamizme (04-16-2014), alaskazero (08-25-2014), altaprecision (07-10-2015), A_tired_goose (06-03-2015), cld12pk2go (05-17-2014), derek13p (08-23-2014), ganque (10-15-2015), helmetface (08-05-2014), hermz (07-08-2015), impossible (05-20-2014), jack_hammer (07-06-2014), kolosok17 (05-20-2014), lildisco (04-17-2014), Micha (04-21-2014), Monotonous ONE (05-21-2014), ms3blackmica (10-28-2014), Raider (05-20-2014), rob ms6gt (09-24-2014), sidekick (07-05-2014), speed3 britz (05-08-2014), speed3sailor (05-18-2014), theschrum (05-18-2014), xx5PEEDxx (04-16-2014), Zdraveca (04-19-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f123/big-turbo-build-cx-7-p-168742/
MS3 50,000km sans OCC... This thread Refback 07-19-2015 04:41 PM
Big turbo cx-7 This thread Refback 06-04-2015 02:18 AM
Tuning Mazda cx-7 - Page 2 This thread Refback 04-20-2015 01:05 AM
Cx 7 moteur et turbo scrap This thread Refback 04-09-2015 03:50 PM
Cx-7 vs cx-9 This thread Refback 04-05-2015 11:52 AM
Hose Intercooler This thread Refback 04-04-2015 06:45 PM
Project Q - Another modder's thread - Page 2 - Alfa Romeo Forum This thread Refback 11-17-2014 01:58 AM
HFS3 install on Mazda CX-7 (2.3T) - waterinjection.info This thread Refback 07-01-2014 01:22 AM
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Why not another S3 turbo build! taf0422 MazdaSpeed 3/6 - Big Turbo Builds 187 02-21-2013 02:13 AM
MX-5 EFR Turbo Build Andy@Killshot Miata - Forced Induction 40 12-28-2011 04:01 PM
My big turbo build Speedie6 MazdaSpeed 3/6 - Big Turbo Builds 4 12-09-2010 01:54 AM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 02:55 PM
Page generated in 0.91401 seconds with 32 queries
