> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
  • 1 Post By torquemaniac
 Old 10-17-2015, 10:54 AM   #1
Dimka's Avatar
Posts: 10   (View Stats)
Dimka is an unknown quantity at this point
Default BNR-S3 on the CX-7
Hello guys!
I want to share the experience of using BNR S3 Turbo on its CX-7 with automatic transmission, and at the same time to ask your advice.
My current configuration is: BNR-S3, 3 port EBCS, Autoteh HPFP, Inletpipe, Downpipe. As a result, when the tuner finished, I got about 270whp.
The figure in the picture nice, but that joy is over, because even at 100% duty cycle turbine inflates 1 bar excess of 3,000 rpm, further more, but pressed to the seat starts from 3,500-4,000 rpm.
This led to my friends with a simple chip leave me off. My acceleration of 0 to 60 miles per hour is equal to 8 seconds. I think this is a very long time. Adjuster says that nothing can do about it because it is larger and heavier turbine spins ..
However, it is impossible to force faster start BNR-S3 ??
Please tell me what to fix?
Dimka is offline   Reply With Quote
 Old 10-17-2015, 02:14 PM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
Your mod - "inlet pipe". Is that a full 3'' intake or just the turbo inlet?
 Old 10-17-2015, 02:32 PM   #3
Dimka's Avatar
Just the turbo inlet
 Old 10-17-2015, 03:47 PM   #4
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Your tuner doesn't know what he's doing.
 Old 10-17-2015, 04:14 PM   #5
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Who is tuning you? Doesn't sound like it's one of the awesome e-tuners from here on MSF.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 10-17-2015, 04:42 PM   #6
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Seems about right for an auto bnr s3 on pump gas...
No idea why you're maxing out fuel though, that's just bad tuning...
Here's a corksport + meth on a cx7 http://www.mazdaspeedforum.org/forum/foru....php?p=2945261
 Old 10-17-2015, 05:40 PM   #7
torquemaniac's Avatar
Posts: 733   (View Stats)
Here's a corksport + meth on a cx7 Seen the light and modding CX7 for more power - Page 6 - Mazdaspeed Forums
I think he means that the turbo is slow to spool even at 100% DC (BCS duty cycle)
Dimka likes this.
2011 CX-7 AWD 2.3 turbo
The Following User Says Thank You to torquemaniac For This Useful Post:
Dimka (10-19-2015)
 Old 10-17-2015, 06:18 PM   #8
speed23's Avatar
Get a full big intake and have stratified or freaktune tune your car. That will ensure your getting the best out of your mods.
The Following User Says Thank You to speed23 For This Useful Post:
Dimka (10-20-2015)
 Old 10-18-2015, 01:09 AM   #9
Dimka's Avatar
Oh no, he's not here MSF. )) He set my car on the road by races with removal of logs.
Maybe CS Turbo has an early spool?
Oh yeah, you understood me correctly! Tuner does not restrict the turbine, but it is still too late spool
Do you think a full 3 "intake will help accelerate the spool?
 Old 10-18-2015, 08:33 AM   #10
Cheapspeed's Avatar
Your catback exhaust will be a restriction now that you have a larger turbo.
Dimka (10-19-2015)
 Old 10-18-2015, 11:29 AM   #11
speed23's Avatar
Check out post # 20 in this thread:
BNR Stage 3 WGA adjustment
I also think an intake would help.
The CS turbo spools slower than bnr stage 3.
The Following 2 Users Say Thank You to speed23 For This Useful Post:
Dimka (10-19-2015), Vansquish (10-19-2015)
 Old 10-18-2015, 02:23 PM   #12
Dimka's Avatar
Thanks to all huge for helps and references! I will try. An interesting subject with the WGA control...
 Old 10-19-2015, 08:16 AM   #13
Like other said, your best bet are breathing mods (better flowing intake, intercooler, exhaust manifold, catback) and a good tune
I didnt check the WGA thread for the BNR S3, but when I had problem with my wastegate (too strong spring), I could easily hit 25psi at 3400rpm in second gear with 1/3 throttle...my scenario is extreme, but the wastegate adjustment could improve your spoolup substantialy
Dimka (10-19-2015)
 Old 10-19-2015, 07:26 PM   #14
blackms3_71's Avatar
Posts: 2,250   (View Stats)
I think u should get a tune from a msf tuner. I wouldnt trust anyone else tbh
Dimka (10-20-2015)
Page generated in 0.33071 seconds with 25 queries
