| CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() | | #41 | ![]() |
![]() Join Date: Dec 2010
| Not Ranked : 0 score Thanks! |
![]() | | #42 | ![]() |
![]() Join Date: Jun 2012 Location: Montreal, QC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 927
I will post the specs later...
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement | |
![]() | | #43 | ![]() |
![]() Join Date: Jul 2013 Location: Spokane, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 94
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score I need to read this. I want more than 320hp at the wheels |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score As stated in post#35, the TCM will adapts to the change done on the valve body, and the quality of the shift will suffer The only way around this issue is to make access holes on the valve body cover to easily re-adjust the clutch control valves with an hex key At the request of @Project_dog; here are some pictures of the valve body cover with the access holes I did not keep the measurements for the access holes positionning, so you will have to take the measurements (the best is to have the holes directly aligned with the clutch control valves, but some holes end up in some round part of the cover, so you will have to move the holes a bit to have a flat surface for the rivnut) A part of the block also need to be cut to have access to the B1 clutch control valve with an hex key (see pictures) In the last picture is shown the harness bracket that must be removed to gain access to the C1 clutch control valve Here is the part list for the cover mod (McMaster-Carr part number): - Rivnut 95105A135 - Stainless screw 97763A232 - Viton o-ring 9464K13 - Ribut install tool 96349A280 Attached is a PDF of the clutch control valves as a reference
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement Last edited by torquemaniac; 11-27-2016 at 05:44 PM. |
| The Following User Says Thank You to torquemaniac For This Useful Post: | Tomas (11-29-2016) |
![]() | | #45 | ![]() |
This spring gives a +30% increase in pressure (I would have gone with a +40% spring, but I could not find a spring with the right specs...unless I shimmed the pressure regulator sleeve...this could affect the stroke of the valve so I opted to not go this route) Attached is some note on the spring specs (OEM and upgrade)
![]() | | #46 | ![]() |
![]() Join Date: Apr 2018
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score How hard is it to replace the valve body in cx7 trans? Where is the pan located? Is it that vertically mounted bucket Looking cover on the sida? Is there a turorial anywhere with pics how to do it? |
![]() | | #47 | ![]() |
![]() Join Date: Apr 2014 Location: Brisbane, QLD, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
| Not Ranked : 0 score Its the black vertical pan on the front. It's just awkward getting all the bolts out. I don't know of any tutorials. The workshop manuals can be found through the CX7 FAQ thread for reference.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified |
![]() | | #48 | ![]() |
| Not Ranked : 0 score When i pull the valve body are there any springs or parts that may fall out i need to be aware of? |
![]() | | #49 | ![]() |
| Not Ranked : 0 score Yes I did have a piece fall out, I can't remember which one now, it was a couple of years ago. So be careful.
![]() | | #50 | ![]() |
| Not Ranked : 0 score Man i wish there was a write up with pics somewhere. I have the manual ins. And im not afraid of the job Just wish i had a bit more reference material |
![]() | | #51 | ![]() |
| Not Ranked : 0 score Any idea on procedure to reset shift adapts? |
![]() | | #52 | ![]() |
| Not Ranked : 0 score Ok got all prep work done and cover off Doing swap next week Not too bad so far Anybody know what the best way to clean off the old RTV is? Is theree a solvent for that? |
![]() | | #53 | ![]() |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score razor blade/starter fluid Don't go gouging the case like a newb
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
![]() | | #54 | ![]() |
| Not Ranked : 0 score Disconnect battery will reset ECU. It will relearn after that. I use brake/parts cleaning spray solvent with a wire brush
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified Last edited by Ozynigma; 04-08-2018 at 05:33 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #55 | ![]() |
(Thread Starter) | Not Ranked : 0 score The only way to reset the shift adapt is to go to a transmission shop...disconnecting the battery wont do it (the transmission is controlled by the TCM and not the ECU)
![]() | | #56 | ![]() |
![]() Join Date: Aug 2018
Rep Power: 0 ![]() Thanks: 5
| Not Ranked : 0 score @torquemaniac You're a pioneer in your ways! I would love to chat with you personally about some of your findings. I am just in Onterrible. I can't PM just yet, but you have been the sole reason for me joining MSF. You can find me on IG if you were so inclined. Same username. |
![]() | | #57 | ![]() |
![]() Join Date: Oct 2019 Location: Russia
Can I talk to you personally? Interested in the issue of setting up the AWTF-81 hydroplate. Thank. | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f123/cx-7-transmission-z-178708/ | ||||
| Project Q - Another modder's thread - Page 5 - Alfa Romeo Forum | This thread | Refback | 04-14-2015 08:57 AM | |
| Project Q - Another modder's thread - Page 2 - Alfa Romeo Forum | This thread | Refback | 12-05-2014 12:26 AM | |
| transmission | Matx | CX-7 > Engine, Transmission & Driveline | 4 | 08-23-2011 11:13 AM |
