| CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Aug 2011
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Anyway, I'm a fairly experienced wrench, but I'm not a professional, and this car has required very little work, so I'm a complete virgin when it comes to its engine bay. I have some AllData info showing a pretty involved job. Anyone know of a DIY write-up for turbo work on these? Thanks in advance. |
![]() Join Date: Mar 2012 Location: Middletown, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score There's one for the ms 6 which shouldn't be far off. Apart from manifold bolts being rusted solid the other main issue is the oil drain bolts under the turbo. If you're FWD you can access them from underneath, if you're AWD the transfer case is in the way so you'll have to lie on the engine and undo the bolts by feel. Putting them back in while keeping the gasket in place is going to require some patience. If you do it yourself get flex head ratchet wrenches, various extensions, a stubby ratchet, deep sockets and a can of PB Blaster to soak those manifold nuts overnight. Sent from my iPhone using Tapatalk
__________________ Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM |
![]() Join Date: Apr 2014 Location: Brisbane, QLD, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
| Not Ranked : 0 score I am about to do this job voluntarily in the next month to upgrade from a K0422-582 to a MS3 K0422-882 turbo. You will need a special tool to remove the first oxygen sensor which let's you remove the heat shield and then the upper down pipe from the turbo. This is the O2 sensor tool I just ordered. http://bit.ly/1pZcrss
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified Last edited by Ozynigma; 08-19-2014 at 08:47 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Sep 2013 Location: Valrico FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 475
Groans: 51
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs | |
(Thread Starter) | Not Ranked : 0 score Believe it or not, the dealership repaired it under warranty, even though it's long out of warranty (2007 with 60k on it). They stuck me for a new EGR valve but all in all I'll call it good. |
![]() Join Date: Nov 2014 Location: Pittsburgh PA
| Not Ranked : 0 score How much should I expect to pay at the dealership if my Turbo goes? |
| Not Ranked : 0 score A prolapsed rectum.
| The Following 2 Users Say Thank You to Code Monkey For This Useful Post: | Easter Bunny (12-15-2014), jack_hammer (12-15-2014) |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| The EGR should probably have been a warranty item as well, as it's part of the emissions system that is warrantied beyond 60k.
| Not Ranked : 0 score Why don't you ask them for a quote? Its a couple of days labour plus a few thousand for a genuine Mazda turbo. There are better options like a BNR S1 as a replacement but if you can't do it yourself you will still have to pay a competent mechanic.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified |
| The Following User Says Thank You to Ozynigma For This Useful Post: | R3L3NTL3S (09-26-2016) |
| Not Ranked : 0 score Just out of curiosity I called and asked the dealership for a ball park to replace the turbocharger if it fails: $2500 What's the failure rate of the turbochargers? 25%, 50/50? 100% (after a certain amount of miles)? |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score There was a bad batch for the 2008.5s. I'll put it this way, the dealership sent my vin in to Mazda proper, and THEY called the dealership back stating a new turbo was in route. No pictures needed or questions asked (I had all new intake stuff and a dp on back done.) I don't know how far it reached besides the halfs, I imagine more of the 08s. So short answer, of it was an 08.5, failure is about 100%.
__________________ 2008 Mazdaspeed3 GT ::COBB STS/Turbo Inlet/AP/SW/BPV, Fujita F5 CAI, CP-E RMM/DP/CBE/FMIC, TWM Shifter Bushings/JBR Side Mounts:: 2019 Audi Q7 |
| Not Ranked : 0 score I have a 2011, so less of a chance, if I'm reading you correctly. |
| Not Ranked : 0 score Correct. 2010-11 was about the time Mazda started all their bs fixes for the 08 turbos. That said, just watch it.
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
| Not Ranked : 0 score Failure is 100%. Seals will eventually leak, nothing lasts forever.
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
My 2007 built CX7 had the original model K04-581 turbo. It got to 130,000km with absolutely no issues at all. I then chose to replace it recently with the higher performance K04-882 turbo from a Gen2 Speed 3. The Gen 2 models of the 3 and CX7 had updated turbos the K04-582 and K04-882 (replacing the earlier K04-881). These have the improved seals. The biggest cause of failures in CX7 turbos is lack of maintenance and in particular missing oil changes or extending the time/miles between services. Mazda recommend every 10,000km or every 6 months in Australia. I did let a few of my services go out to 12 months but still less than 10,000kms. My opinion is that a well maintained CX7 motor should see 160,000km / 100,000 miles from a turbo. After this the failure rate is likely to increase. The turbo is a component under higher stresses and with higher wear rates than a lot of the other mechanical components on the car. So you would expect the rest of the engine to outlast a turbo.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified | |
| replacement IWG for atp turbo? | ryein7 | MazdaSpeed 3/6 - Turbo Induction | 1 | 04-13-2012 04:32 PM |
| Overboosting after turbo replacement | Lama | MazdaSpeed 3/6 - Turbo Induction | 10 | 09-26-2011 06:06 PM |
| stock turbo replacement upgrade | 671 grains of reason | MazdaSpeed 3/6 - Turbo Induction | 63 | 09-17-2011 09:14 AM |
| OEM Turbo Replacement Procedure-Question | Speedy3 | MazdaSpeed 3/6 - Turbo Induction | 5 | 11-27-2008 05:24 PM |
| F430 Replacement: lightweight with turbo V8 | Haltech | Automotive News | 0 | 10-28-2008 10:10 AM |
