> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
Like Tree6Likes
  • 1 Post By dale_gribble
  • 2 Post By dale_gribble
  • 1 Post By Project_dog
  • 1 Post By Raider
 Old 11-04-2015, 03:38 AM   #1
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Default FMIC
Well I started to make it FMCI for my 2007 CX-7. After my vvt fuck up.
Project_dog is offline   Reply With Quote
The Following User Says Thank You to Project_dog For This Useful Post:
Raider (11-04-2015)
 Old 11-04-2015, 12:53 PM   #2
Do it.
 Old 11-04-2015, 01:12 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Read some of my threads about FMIC and make sure it's worth the hassle. Unless it's done right, there is the possibility of 0 gains and it's expensive. Meth injection is actually less of a hassle, offers better performance and helps keep the intake valves clean. I've been running it for years now, it is very simple to run on a daily driver.
MINI H1 6.0 - CAR LED TAILS
Spectrix (11-04-2015)
 Old 11-04-2015, 08:34 PM   #4
Here are some pictures. uploadfromtaptalk1446694365353.jpguploadfromtaptalk1446694391135.jpguploadfromtaptalk1446694430783.jpguploadfromtaptalk1446694449819.jpg
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
The Following 4 Users Say Thank You to Project_dog For This Useful Post:
mxlplx71 (11-05-2015), Raider (11-05-2015), SamiChicago (01-14-2016), torquemaniac (11-07-2015)
 Old 11-04-2015, 08:35 PM   #5
Head light is off because I was doing some led mods
 Old 11-04-2015, 09:19 PM   #6
What size is that tubing?
 Old 11-04-2015, 10:20 PM   #7
3 inch
 Old 11-05-2015, 06:26 AM   #8
That piping is crazy overkill and inefficient for smaller turbos (and even big turbos). I have to imagine the throttle response and spool suffer pretty bad. Even 2.5" is overkill. 2.25" is good up to like ~450hp. If you ever tire of the lag, just swap in 2.25" pipe.
MS3Shadow likes this.
 Old 11-05-2015, 11:32 AM   #9
From my tuner. He was telling me 3inch. I'll have no lag.
 Old 11-05-2015, 11:43 AM   #10
ROFL, ok. Your tuner is completely wrong. Ask him on here if he wants to debate his position. I have had like 10 different intercooler setups on my car and done the research as to what an optimized setup is. I wouldn't touch the FMIC option until after meth injection with TMIC. My ETS TMIC with meth injection basically did as well as my custom CP-E FMIC setup with upgraded treadstone intercooler. Don't want to run meth? For k04/mid turbo it's 2.25" piping, ~500-600in^3 volume intercooler (treadstone ideal) with a higher density core. Only reason you need 2.5" or higher is for the big turbo setups, but I think even 2.5" flows to like 700cfm.
ETS TMIC v. CP-E FMIC MS6; guess I need a bigger intercooler
Dale's custom FMIC setup for MS6 - take 2
Why won't any forum sponsors make an MS6 FMIC pipe kit?
TMIC > FMIC > back to TMIC - my journey
Ozynigma (11-15-2015), redboat (11-16-2019), torquemaniac (11-07-2015)
 Old 11-05-2015, 11:45 AM   #11
also who is your tuner?
 Old 11-05-2015, 11:57 AM   #12
OP, here ya go. 3" is rated to 1300CFM and quite inefficient at your airflow level. The k04 flows up to a max of around 500CFM (270g/s). Actually, 2" piping would work and be most efficient for the k04, but most are made with 2.25" for a little room to grow. My BNR S3 setup flows up to 632 CFM and 2.25" piping is more than enough for my turbo that flows up to 350g/s.
*.4 Mach is the point at which air becomes turbulent and losses in efficiency start to occur exponentially. The key is to stay under that speed. You want to use the smallest piping possible that still flows enough to meet your needs. Larger than necessary piping increases lag time with no measurable gain. The velocities are in miles per hour and mach, and the flow rates are in cfm. Measurements for the piping are in inches.
2" piping
1.57 x 2 = 3.14 sq in
300 cfm = 156 mph = 0.20 mach
400 cfm = 208 mph = 0.27 mach
500 cfm = 261 mph = 0.34 mach
585 cfm max = 304 mph = 0.40 mach
2.25" piping
3.9740625 sq in = 1.98703125 x 2
300 cfm = 123 mph = 0.16 mach
400 cfm = 164 mph = 0.21 mach
500 cfm = 205 mph = 0.26 mach
600 cfm = 247 mph = 0.32 mach
700 cfm = 288 mph = 0.37 mach
740 cfm max = 304 mph = 0.40 mach
2.5" piping
4.90625 sq in = 2.453125 x 2
300 cfm = 100 mph = 0.13 mach
400 cfm = 133 mph = 0.17 mach
500 cfm = 166 mph = 0.21 mach
600 cfm = 200 mph = 0.26 mach
700 cfm = 233 mph = 0.30 mach
800 cfm = 266 mph = 0.34 mach
900 cfm = 300 mph = 0.39 mach
913 cfm max = 304 mph = 0.40 mach
2.75" piping
5.9365625 sq in = 2.96828125 x 2
300 cfm = 82 mph = 0.10 mach
400 cfm = 110 mph = 0.14 mach
500 cfm = 137 mph = 0.17 mach
600 cfm = 165 mph = 0.21 mach
700 cfm = 192 mph = 0.25 mach
800 cfm = 220 mph = 0.28 mach
900 cfm = 248 mph = 0.32 mach
1000 cfm = 275 mph = 0.36 mach
1100 cfm max = 303 mph = 0.40 mach
3.0" piping
7.065 sq in = 3.5325 x 2
300 cfm = 69 mph = 0.09 mach
400 cfm = 92 mph = 0.12 mach
500 cfm = 115 mph = 0.15 mach
600 cfm = 138 mph = 0.18 mach
700 cfm = 162 mph = 0.21 mach
800 cfm = 185 mph = 0.24 mach
900 cfm = 208 mph = 0.27 mach
1000 cfm = 231 mph = 0.30 mach
1100 cfm = 254 cfm = 0.33 mach
1200 cfm = 277 mph = 0.36 mach
1300 cfm max= 301 mph = 0.39 mach
frothy (11-06-2015), Ozynigma (11-15-2015), redboat (11-16-2019), torquemaniac (11-07-2015), Vansquish (11-15-2015)
 Old 11-05-2015, 12:05 PM   #13
Cool story bro. Right now I'm going to run 3 inch. If it's to big I'll go down to 2.5 inch. I can't do anything now. I have 3 inch pipe set up. Thank for the info.
My tuner is a buddy of mine.
Last edited by Project_dog; 11-05-2015 at 12:05 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-05-2015, 12:12 PM   #14
I guess it does suck when you know you bought shit that won't work very well. I've been there before. You can CSB me if you want, I gave you data to back it up. It wouldn't cost much more to just get a 2.25" piping kit.
Might want consider an established tuner after that bit of sage advice he gave tho.
Crarrs (11-15-2015), frothy (11-06-2015), MS3Shadow (11-05-2015), Raider (11-05-2015), Vansquish (11-15-2015)
 Old 11-05-2015, 12:19 PM   #15
I hope you can take that advice.
dale_gribble (11-05-2015), MS3Shadow (11-05-2015), Vansquish (11-15-2015)
 Old 11-05-2015, 12:26 PM   #16
Well I'm 90 %done with my piping. I need my car back. Like I said. If I have problems with having lag I'll switch pipe size. Thanks for the advise.
I'll keep my big fmic.
Last edited by Project_dog; 11-05-2015 at 12:26 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-05-2015, 12:29 PM   #17
If you start spooling now you should be able to hit your boost target by Thanksgiving.
Ozynigma and dinoxor like this.
 Old 11-05-2015, 12:41 PM   #18
Haha lol. I own a 67 bug. I know what it's like to go from 0-55 in 11 minutes.
Once again thanks for info.
dale_gribble likes this.
The Following 2 Users Say Thank You to Project_dog For This Useful Post:
 Old 11-05-2015, 12:53 PM   #19
I had a 1977 Adventurewagen camper with an automatic trans. I had that very decal on the back window.
Project_dog likes this.
Project_dog (11-10-2015), Vansquish (11-15-2015)
 Old 11-15-2015, 04:26 AM   #20
Ozynigma's Avatar
Posts: 743   (View Stats)
Great info there Dale. I had the same sort of discussion with OP a year or so back.
I did a lot of reading and have stuck with an ETS TMIC and added Cooling Mist WMI and a Corksport turbo to my CX7. We got the last 20% / 65awhp just by adding the WMI.
Come on @Project_dog who's this backyard tuner you found who won't even give you a base map for your mods
 Old 11-15-2015, 02:48 PM   #21
 Old 11-15-2015, 03:48 PM   #22
2.5"?
 Old 11-15-2015, 07:20 PM   #23
it is still 3 inch pipe. im going to order 2.5 later. I need my daily driver back.
The person who is going to tune it a friend of mine. he had been tuning for many years. i trust him.
Got it all welded up. installed. Started it up today. Having issue after I rebuilt the motor.
Last edited by Project_dog; 11-15-2015 at 07:20 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-09-2015, 09:20 AM   #24
pankrok's Avatar
Posts: 18   (View Stats)
pankrok is a jewel in the roughpankrok is a jewel in the roughpankrok is a jewel in the rough
any progress on this?
very interested as next week im going to install fmic on mine
pankrok is offline   Reply With Quote
 Old 12-10-2015, 01:50 PM   #25
It's all done
 Old 12-13-2015, 02:11 PM   #26
All welded up.
lildisco likes this.
DaUberSchwebel (12-14-2015)
 Old 01-02-2016, 02:40 PM   #27
The car has been running great. very strong. Im going to replace some of the clamps, because the are cheap.
 Old 01-14-2016, 03:27 AM   #28
pankrok's Avatar
noticed laggy responce in mid low end rpm?
 Old 01-14-2016, 09:43 AM   #29
Not really.
Sent from my SAMSUNG-SM-G920A using Tapatalk
 Old 02-16-2016, 06:03 AM   #30
pankrok's Avatar
for the hot side shouldn't you calculate actual sonic speed for temp before fmic?
according @kevin link
Stealth 316 - Turbo Outlet Temperature
even 23 psi would give temp in hot side more than 300degF so sonic speed is already 1.27 times higher than the reference point.
shortly (if not completely wrong) 2" pipe after turbo is good for more than 650cfm.
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Page generated in 0.48216 seconds with 26 queries
