| CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: May 2013 Location: Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 2
![]() Join Date: Apr 2014 Location: Brisbane, QLD, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 225
| Not Ranked : 0 score We are much nicer in the CX7 forums. No tune required for BPV unless you go silly and go a VTA BOV. Have a google search for the Stratified blog. They cover off a lot of issues like this around tuning. Sometimes they also make a thread on MSF about it. I think you will find there is a thread that tells you not to waste money (like I did) on an aftermarket BOV until you are trying to hold more than 21psi boost with a bigger turbo.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines | |
(Thread Starter) | Not Ranked : 0 score Cool thanks for the help. I found out about the go fast bits adjustable from my buddy who has a wrx wagon. He only does a 25% vta and that keeps his car happy with no codes and the loading up issue and was hoping the same for the 7 as well. I'm trying to get back into tuning and all that again after a nine year break while working on aircraft. I thought I would never forget all the little stuff but time left me in the dust. Catching back up is a bitch. This is all in prep for a more power, but still daily driver drop the kiddos off at school kinda car. One more thought just came to mind, fuel pump upgrade is that needed as well? Or is that something that can wait for now. Last edited by CX7Haley; 09-15-2014 at 05:38 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Nov 2012 Location: Hayward, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score Rule of thumb is HPFP internals for anything more then a intake. If you have a AP you can keep an eye on your HPFP pressures to see whn you "need" it. but thats a bit sketchy to me. Just do internals if you do more then a intake
__________________ 2013 CWP W/ Tech" LS/VTEC swap running 9's |
(Thread Starter) | Not Ranked : 0 score Cool easy enough. Any particular brand better than the other? Autotech or KMD? Or this just a price difference. |
Autotech is the most proven product. Corksports has a comparison chart on their website. Do your own research and make your own choice. Now that the obligatory first recall is over I gave the Corksport internals a go.
__________________ CX7 - The younger, taller and sexier replacement for the MS6. 2007 CX7 2.3 DISI AWD | Forged Build | Mahle Pistons | Molnar Rods | APR studs | Corksport Turbo @25psi | ETS TMIC | Cobb XLE BOV | CS HPFP | JBR 3.5" WPI | Cooling Mist WMI | CS OCC | CX9 20x7.5's | CX9 Brakes | Pedders Lowered 40mm | VersaTuned by Stratified | |
| Not Ranked : 0 score Has been running CorkSport's for a while, I think I have at least 4 track weekends on them, not a single hiccup.
| Just making sure it will fit. | btrend | MazdaSpeed 3/6 - Suspension & Brakes | 2 | 02-11-2014 07:08 PM |
