| CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
(Thread Starter) | Neutral : +1 score I will make updates after all changes. Car is 2008 y. with 85.000 km. Until now I make new intake, maf housing, install new air filter, blow off is new. Pump internals are changed (by myself- parts from PTP), today I removed balance shaft. All pictures will follow. About feelings: - maf housing, filter and intake make big plus in power. Most benefits are 4000 rpm and up. - pump internals are working like stock, no difference here (stock ecu soft) - balance shaft, well, difference is bigger like I was thinking before from reading on forums. It is like switch from 6 to 4 cyl. engine. Engine revs better, pulls better from 5k up, but small vibration in same freq. like exhaust sound are here. Engine runs "harder", like I say, 4 cyl now, 6 before. Nothing to worry I thing, but I can feel them. I also change oil and filter- EXELIA 5W-30. Without BS 7l of oil inside |
| The Following User Says Thank You to ro-bi For This Useful Post: | dimkatz (09-30-2011) |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score Step by step |
| The Following User Says Thank You to kmac For This Useful Post: | spoolin00 (06-08-2011) |
![]() Join Date: Feb 2010 Location: Dallas
Rep Power: 1531 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,819
Groans: 145
| Not Ranked : 0 score auto or manual?
__________________ 2011 MS3"Princess GRU" GT2876r AEM Meth Injection, Cobb AP, HTP 3' Intake, KMD interals, Shitty FMIC, JBR 88d RMM, JBR 88d TMM, JBR TIG's x2, JBR BSD, JBR Short THrow Shifter, JBR shifter bushings, Corksport License Plate Bracket, Forge BPV v1, ATP Downpipe, UR Straightpipe Beast Mod, Progress RSB, Koni Yellows, Eibach Pro Kit, Kosei K1-TS Gold 17x8, E85 FREEKTUNE |
| Not Ranked : 0 score Moving to ecu tuning. |
(Thread Starter) | Not Ranked : 0 score Car is manual, ECU tuning will wait until all changes are there (exhaust, metal cat, SST turbo from PTP) Today I am receiving big brake kit- 355mm rotors, 6 piston calipers .) |
Groans: 145
| Not Ranked : 0 score Don't go with ptp go with stage3 bnr Sent from my T-Mobile G2
(Thread Starter) | Not Ranked : 0 score Did you tested both or just reading about? What are major differences in power and life? Please, write from own experiences not from web browsing. |
Groans: 145
| The Following User Says NO Thank You to ro-bi For This Un-useful Post: | Zdraveca (03-13-2011) |
| Not Ranked : 0 score No pics |
(Thread Starter) | Not Ranked : 0 score I tried several times but I cannot upload pictures!? |
| Not Ranked : 0 score Might be too big? Jpg format is best. Next option, photobucket.com account. I host many how-to pics there. |
![]() Join Date: Jan 2010 Location: Greece, Thessaloniki
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
__________________ CX-7 2008 awd manual bnr s3 [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score I changed router and I cannot upload, just download..... In few days I will fix this..... Sorry.... Few pictures are in this thread. http://www.mazdaspeedforum.org/forum/foru...-cx-7-a-64775/ |
(Thread Starter) | Not Ranked : 0 score Here are some newer photos http://s1222.photobucket.com/albums/...view=slideshow Last edited by ro-bi; 03-18-2011 at 05:31 PM. Reason: Tried to attach thumbs |
| The Following User Says Thank You to ro-bi For This Useful Post: | KostasCX-7 (03-18-2011) |
Groans: 145
| Not Ranked : 0 score the exhaust looks pretty nice!
| Not Ranked : 0 score Nice stuff. What kind of brake kit are you running? Is it custom?
| The Following User Says Thank You to KostasCX-7 For This Useful Post: | Raider (05-28-2011) |
(Thread Starter) | Not Ranked : 0 score Not running jet but it is custom 100% Now I have a lot of work with preparing of hayabusa engine for work in boat so no time for car. Here is video of almost finished engine- first run. There is no clutch inside, no gears, output axle is on opposite side, exhaust (non sequential pairing) and intake (all runners equal ) are custom made (by me), I will make changes in ECU,..... http://www.mrc.si/forum/download/file.php?id=237 http://www.mrc.si/forum/download/file.php?id=236 |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Some progress on brakes. I have one hat finished, waiting for second. Screws are there just for sample- after there will be 12.9 screws. |
| The Following User Says Thank You to ro-bi For This Useful Post: | Raider (05-28-2011) |
![]() | | #20 | ![]() |
Groans: 145
| Not Ranked : 0 score That looks great ro-bi. Its nice to see someone doing some brake work for the cx Sent from my T-Mobile G2
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have to make adapters for calipers and change screws for longer. |
| The Following 2 Users Say Thank You to ro-bi For This Useful Post: | KostasCX-7 (04-30-2011), Raider (05-23-2011) |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Some news here- A long story about but in short, on 18. january I sent turbo to PTP and yesterday I received official answer from post office: they lost package!!! I will receive refund of 875 euro (insurance) and after I will not try again. I will go with GT3071. With stock internals and some 18 psi of boost it should make a lot of power and I think that internals could survive. |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Try to swap the stock connecting rods only with k1's
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score If I will changing rods, maybe put there 0,051 thick gasket? What is feeling with lower CR? Is driving with no boost like NA diesel engine or it is no big difference from CR 9.5:1 VS 8:1? p.s. Is it enough to change rods? Stock pistons are o.k. for 18 psi? Last edited by ro-bi; 05-06-2011 at 11:40 PM. |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Brakes are tested and they work PERFECT! Much more control like stock, no vibrations, braking force is enormous with light push on pedal. ABS can become active at speeds over 100 km/h without any forcing- just a little harder braking. I dont know how to describe feeling but brakes are handling all weight and speed with ease. Also weight is 10 Kg lower for ONE axle so 20 Kg for both over stock!!!! |
![]() | | #26 | ![]() |
Groans: 145
| Not Ranked : 0 score Pst pics as soon as you can congratsSent from my T-Mobile G2
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
Groans: 145
| Not Ranked : 0 score Wow that looks good now buy some rims to show em off Sent from my T-Mobile G2
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score I hope to make exhaust this week. All parts are here, only some time is missing... |
![]() | | #30 | ![]() |
![]() Join Date: Nov 2010 Location: p.pines, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 372
| Not Ranked : 0 score Nice work! A write up on those brakes would be great but I do understand not having the time. I'm hoping the summer will bring some free time for myself to get more done. Keep the mods going! Enjoy! Forgot to ask did you upgrade the master and booster when you changed the breaks??
__________________ 09 CX-7 GT - cp-e Xcel intake w/ Nviscid pipe, ETS TMIC, HKS BPV, autometer boost gauge Last edited by jstcruzin; 05-25-2011 at 07:51 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Exhaust is on the car. No light, all working fine, just small leaking on downpipe. I will fix this soon. Sound is a little boomy on idle but higher sound is fantastic. Not loud, but with sporty tone. I ll post some pictures tomorrow. |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Power gain is big- turbo spools faster, almost no lag, after 4.5 Krpm car pulls stronger and stronger until red line. My but-dyno telling me about 20 hp minimum gain but probably much more Last edited by ro-bi; 05-28-2011 at 03:46 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to ro-bi For This Useful Post: | KostasCX-7 (05-30-2011), Raider (05-28-2011) |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Looks sick, nice work. Audio clip? |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Looks Nice...would love to hear it!
__________________ 09 CX-7 GT - cp-e Xcel intake w/ Nviscid pipe, ETS TMIC, HKS BPV, autometer boost gauge |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Sound was disturbing at low rpms when cruising or at idle. Booomy. I added resonator and now is almost like stock at lower rpms ![]() |
![]() | | #38 | ![]() |
Groans: 145
| Not Ranked : 0 score Damn robi that's really nice work! Sent from my T-Mobile G2
![]() | | #39 | ![]() |
![]() Join Date: Nov 2010 Location: Long Beach, CA
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score This thread is VICIOUS!!!
__________________ Hey, you in the Toyota - you SUCK ASS! |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score vicious - definition of vicious by the Free Online Dictionary, Thesaurus and Encyclopedia. ??? Could somebody explain word VICIUS? Is this good or bad in this context? Thank you, Robert Last edited by ro-bi; 06-04-2011 at 11:48 PM. Reason: no answer for long |
| Step by Step Brake Job from Grassroots Motorsports | FUB4R3D | MazdaSpeed 3 - How-To's | 36 | 06-14-2014 03:08 PM |
| 2-Step? | D08SPEED3 | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 05-11-2010 12:26 PM |
| Cut It Out: Toyota's recalled pedal modification remedy detailed step-by-step | Haltech | Automotive News | 0 | 12-18-2009 12:10 PM |
