CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
| LinkBack | Thread Tools | Search this Thread | Display Modes |
11-29-2015, 09:57 AM | #1 |
Rep Power: 0 Thanks: 0
(Thread Starter) | Not Ranked : 0 score New to forum blown tubo so the wife's 2007 cx7 blew turbo white smoke out the rear and at lest a quart of oil in the throttle, have the new turbo, what kind of prep to put the new on, pulled the throttle body and cleaned it, as well at hoses and piping, cleaned egr and pipe, can seem to get the oil pipe off from underneath what's the secret, what else should I clean or replace. my experience is with carbs and points so be gentle |
11-29-2015, 10:36 AM | #2 |
Rep Power: 0 Thanks: 1,356
Groans: 50
| Not Ranked : 0 score Clean intercooler. I guess a can of brake cleaner through one side and out the other. Why can't you get the oil line off? What's giving you trouble?
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. |
The Following User Says Thank You to robbspeed For This Useful Post: | Raider (11-30-2015) |
11-29-2015, 10:48 AM | #3 |
(Thread Starter) | Not Ranked : 0 score Cant seem to find a tool/way to get it off the block, was able to get it off the tubo, can I use a flexible gun cleaning rod to push debris/gunk( if any )back into the pan, the transmission/transfer case is in they way |
11-30-2015, 10:44 AM | #4 |
Rep Power: 0 Thanks: 927
| Not Ranked : 0 score Lots of oil in the intercooler and throttle body can be a sign that the piston rings have gone bad With bad rings, there is more blowby in the crankcase (thus more pressure in the crankcase)...the excess pressure will do two things : - prevent the turbo from properly draining (crankcase pressure will try to escape from the turbo oil drain line, and this will push oil pass the turbo seals : smoking turbo) - the excess blowby will entrain a lot of oil with it while escaping from the PCV and valve cover breather...this means lots of oil in the intake, intercooler and throttle body I would do a cylinder compression test to be on the safe side!
__________________ 2011 CX-7 AWD 2.3 turbo Ported Holset HY35 // Custom top mount EM // Tial MV-S 38mm // Custom DP and catback // L2A intercooler with AMG CWA-100 pump// Perrin MBC // 3.25 Blow-thru MAF // Aquamist HFS-4 v.2 direct port injection // Eagle rods // Supertech 4032 pistons // Forge BPV v.2 // Perrin air/oil separator // Autotech HPFP // Custom RMM insert // TB coolant bypass // Full EGR delete // 3.5 bar MAP // Launch control with anti-lag // Derale remote transmission cooler // Upgraded transmission boost valve // Shimmed transmission accumulators // Adjusted transmission clutch control valve // Digital overboost protection system // Custom firewall heatshield // JKS rear spoiler // Painted VC and IM // BSD // Custom vent pod with boost and meth gauge // Tuned with Versatuner"When the turbo spins the bull$hit ends" BOOST the replacement for displacement |
The Following User Says Thank You to torquemaniac For This Useful Post: | Raider (11-30-2015) |
11-30-2015, 11:45 AM | #5 |
6 mods and some Kool-Aid Join Date: Mar 2008 Location: Jax, FL
Rep Power: 28977 Thanks: 20,271
| Not Ranked : 0 score When my wife's turbo shit the bed at 48K miles, the intercooler had thick tar buildup of oil, but did not make it past the fins. Compression test for sure. |
12-01-2015, 12:16 AM | #6 |
(Thread Starter) | Not Ranked : 0 score so pulled the intake off to get to the pcv valve, here's the weird thing I don't understand, oil is pooled in the lower part of the intake but valves are dry, oil in the turbo to intake piping? big plastic part. but no oil in the intercooler, mazda did a vvt and timing chain fix in august at 200,000 said bottom and top end were still good. I recently changed the EGR, oil cooler and filter adapter, any of this related to what is going on now, oh the pvc valve was completely gunked shut Last edited by RRiddle; 12-01-2015 at 12:18 AM. Reason: addition |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread | Thread Starter | Forum | Replies | Last Post |
Forum Wars - Mazdaspeed Forum vs 8thcivcs.com - FYHN | Haltech | Site News | 421 | 02-23-2014 10:45 PM |
Welcome forum at or near top of forum index | Jesse MS3GT | Website Help/Feedback | 1 | 03-06-2008 09:03 AM |
