| CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Aug 2015 Location: Santiago, Chile
(Thread Starter) | Not Ranked : 0 score I had to change my old CX-7 turbo because it was wasting oil to the combustion chamber, so i bought a new K04-882 model (I know thats not the stock model for the car). All the parts fits very well, but i have a problem in high RPM, when i go around ~2000RPM it works fine, but if i pushed a bit more the error code P300 appears. This suppose to happen? or theres any other problem that i probably have in my car? Anyone tryed this before and had some issues as me? After changing the turbo i replace: - Coils - Injectors - Cleaned and measured spark plugs (ok) I have the versatune Base 93/98 Octane installed in my car. Greetings. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score Turbos are different between the 3/6 speeds and cx7. Contact your tuner with this info.
__________________ Stockish |
Groans: 60
| Not Ranked : 0 score If the plugs aren't really low miles I'd replace them just to be sure.
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
Gap should be pretty tight for that turbo and tune. .028” would be a good choice.
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| If you are using iridium spark plugs (ITV22/ITV20/NGK6510/etc.) then you need to be careful about cleaning or changing the gap in the plugs, as the iridium coated wire is fragile. Furthermore, according to Mazda's published specifications from 2010, the plug gap should be between 0.024" and 0.027" (0.61mm - 0.68mm) for this motor.
I know at 0.040 it doesn't work at all, it missfire before 10psi.... OP. Have you checked engine compression as missfire may not comes from spark but from low compression also. I ask because the turbo could leak oil but it could also be the result of too much engine blow by...
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| Not Ranked : 0 score See subsequent response from Vanquish. Mazda OEM plugs have an iridium plating on the center electrode. That is an alloy that is extremely resistant to heat, but is easily damaged if scraped. This is the preferred type plug due to the high heat generated in the combustion chamber of our cars. Platinum does not handle heat quite as well. Generally speaking, you do not even try to "clean" such plugs, but rather replace them when needed because of the risk of damage. You can gap or regap them, but must be very careful to avoid contacting the fine wire in the center except with something like a wire type gapping tool or feeler gauge. Avoid using the coin type that will scrape against the tip of that wire. Yes, .028" is probably on the outside of the preferred range but works ok for stock. Closing to .026" will be better. I forgot that. My guess is that new plugs are in order. NGK iridium in the stock heat range would be a good choice. NGK iridium plugs are OEM, but you can save a little by getting them from antermarket vendors. Their aftermarket part number would be NGK ILTR6A-8G. The part number on the box is 3787.
(Thread Starter) | Not Ranked : 0 score I will check the spark plugs, but they worked fine after changing the turbo (with the old smoky turbo). If the problem stills, what do you recomend? tunning the car for the turbo's new properties? |
Also, misfire codes from low compression will happen at idle and will seem to run fine above idle...especially in boost. Ask me how I know. Since you probably had a good portion of stuff removed, check all electrical connections.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) | |
(Thread Starter) | Not Ranked : 0 score Sry, bad translation... I mean that i "cleaned" the spark plugs before changing the turbo, like 600kms ago and it didnt show me any error, only the oil and smoke were the trigger to had to change the turbo. And now with the new turbo the error appears when i push the rpms. |
This engine is hard on plugs, even when in stock trim. If your total miles on them, regardless of whether “cleaned” or not is 15,000 or more, get new ones. You might also, just to be sure, flash back to stock (I think AP called that stage 0) and then reload that Stage 1 basemap.
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score Along with the other recommendations... how's the AFR/LTFT? If it's been running rich it could foul the plugs, and if it's been running lean you might have a leak causing misfires
__________________ 94 M MS6 IS350 |
(Thread Starter) | Not Ranked : 0 score The car is in the mechanic now... i will load the ms3 table from versatune to see what happens (i hope that it dont blow lol), the sparks was changed by new, but i havent tryied the car yet. |
| The Following User Says Thank You to Dropen For This Useful Post: | MSMS3 (05-22-2019) |
![]() Join Date: Dec 2016 Location: Europe / Poland
Rep Power: 0 ![]() ![]() Thanks: 4
CX-7 with manual transmission has the same turbo 3/6 speeds K0422-882 I think you cannot load stock table from 3/6 or CX-7 MT because the engine has to work with AT, but ... I may be wrong Last edited by tomek CX7; 05-23-2019 at 01:04 PM. | |
(Thread Starter) | Not Ranked : 0 score Good point... Theres any 3/6 automatic? |
| Not Ranked : 0 score No. All 3 and 6 Speeds have the 6 speed manual.
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well, i have the car back now. It works fine for now, i had to change the 4 spark plugs. The new turbo works pretty good, no error 300 for now, i will have to use the car for some time if the error happens again. I didnt change the tunning of the car. Im using the versatuner default tune. |
| The Following User Says Thank You to Dropen For This Useful Post: | MSMS3 (05-25-2019) |
| HKS Turbo Timer Problem | 4lo2go | MazdaSpeed 3/6 - Car Audio & Electronics | 14 | 04-28-2018 01:31 PM |
| Turbo Air Delivery Problem | abm89 | CX-7 > Issues & Troubleshooting | 4 | 08-11-2012 08:32 AM |
| turbo timer problem | reconbygod12 | Mazdaspeed3/6 General Discussion | 6 | 06-07-2011 06:28 AM |
| Coolant in Oil, Wiring Problem in Chevy Cobalt, Cruise Control Complaint with Toyota Prius, Changing An O2 Sensor, Heate | Haltech | Automotive News | 0 | 03-10-2009 03:10 PM |
| Changing a turbo guestion. | SharkDiver | MazdaSpeed 3/6 - Turbo Induction | 9 | 08-28-2008 08:57 AM |
