> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
 Old 01-22-2015, 11:39 PM   #1
vegaslightsss's Avatar
Posts: 8   (View Stats)
vegaslightsss is an unknown quantity at this point
Default Swirl Valve linkage Pic,does anyone know if
this piece can be purchased or I am stuck buying a complete intake manifold,the triangle looking thing circled in yellow,made of plastic... Or what it is called?
vegaslightsss is offline   Reply With Quote
 Old 01-23-2015, 02:51 PM   #2
spals's Avatar
Posts: 305   (View Stats)
spals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the world
You're talking about the plastic piece that moves as the intake manifold flappers move, correct?
I just broke this off of my 3 the other day. I had to JB weld it back on. Stuck a toothpick on top and a plastic piece on bottom to hold it in position while the weld was curing. Make sure you grab the JB weld that holds up to high heat.
I'm 99% sure you can't buy it separately. You need a new manifold to get that piece. If you go VIP you can access the For Sale forums where people sell their stock manifolds sometimes so you might be able to pick one up for cheap.
CP Pistons 88mm, Manley H-Beams, Balanced Crank
BNRS3V2, Cobb Catted DP, ETS TMIC, 3.5" JBR Alum Intake, AT HPFP
GS EBCS, 3 Bar Map, JBR 88 RMM, DM OCC, TIGs, BSD+Baffle
SBC Stage 2 Daily, JBR RSB, Koni Yellow, Konig Miligrams 18x8.5, Nitto NT-05 245/45
Spalsbuilt-Freektuned
spals is offline   Reply With Quote
 Old 01-24-2015, 04:37 PM   #3
thank you so much,I figured,the engine problem i had was due to a faulty hydraulic tensioner,do these cx7 foul iridium's easily? Just bought 4 new,i cant remember if i put new ones in the head after the valve job because I had just changed them before she blew the head gasket and it sat at a mechanic for her extended warranty that took a month to decide they weren't going to pay to fix it so I think they were under water so to speak for a while,It runs perfectly until you put it in gear then missfire city and no DTC..
 Old 01-25-2015, 07:05 AM   #4
spals's Avatar
Holy run on sentence Batman! I have no idea if you are making statements or asking questions. Slow down and try again with some punctuation.
07 CX7 swirl valve questions vegaslightsss CX-7 > Turbo Induction & ECU Tuning 1 01-22-2015 06:30 PM
shift linkage leak or pressure release valve Mzrpower MazdaSpeed 6 - Engine, Transmission & Driveline 2 08-01-2012 02:06 PM
Busted Linkage momasboi Mazdaspeed3/6 General Discussion 7 03-26-2012 06:03 PM
shifter linkage jassak50 2010 MS3 - Engine, Transmission & Driveline 0 06-03-2011 08:51 PM
Report: Rumors swirl about possible demise of USF1 team Haltech Automotive News 0 02-17-2010 10:00 AM
Page generated in 0.24266 seconds with 22 queries
