> CX-7 > Turbo Induction & ECU Tuning
CX-7 > Turbo Induction & ECU Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here!
  • 1 Post By Steve@VersaTune
 Old 12-06-2014, 12:18 PM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Default VersaTuner 1.9.5 Released
VersaTune is proud to announce the immediate availability of VersaTuner 1.9.5
The update includes these changes:
All Platforms
It is now possible to reconfigure the layout of the Tune Editor by dragging and docking the different sections of the window or making them hide automatically.
Mazdaspeed6/Mazda6 MPS, Mazdaspeed3/Mazda3 MPS, Mazda CX-7
We have included an E85 calculator in the Tune Editor to calculate the correction factor to put in the Fuel Specific Gravity table to correct fueling for your specific ethanol/gasoline blend. It also calculates the actual specific gravity of the fuel and stoichiometric air to fuel ratio.
Added the following new tables in the Tune Editor:
Cold Cranking and Afterstart Enrichment
Warmup Enrichment
Cold Cranking and Afterstart Enrichment Decrement
Warmup Enrichment Decrement
These tables allow you to increase the cold cranking and warmup fuel enrichment to improve cold starting and warmup drivability with high ethanol blends.
For more information on how to use VersaTuner to tune Mazda MZR DISI 2.3l Turbo engines for E85, please refer to our E85 tuning guide:
https://www.versatuner.com/E85TuningGuide.aspx
Bug fixes
Reset button in the Tune Editor restores the value to the value in comparison tune.
Corrected the SI to Imperial unit conversion for the Rev Limit Warmup Temperature Hysteresis tables for Series II RX-8.
Alpha Wolf likes this.
Steve
Lead Tuner
The Following User Says Thank You to Steve@VersaTune For This Useful Post:
TiGraySpeed6 (12-06-2014)
VersaTuner 1.9.5 Released Steve@VersaTune 2010 MS3 - ECU Computer Tuning 5 12-22-2014 01:02 PM
VersaTuner 1.8.5 Released Steve@VersaTune VersaTune 28 11-03-2014 01:42 PM
VersaTuner 1.8.5 Released Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 1 03-21-2013 09:45 AM
VersaTuner 1.7 Released! Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 8 05-03-2012 07:20 PM
VersaTuner 1.7 Released! Ugnius@VersaTune VersaTune 0 04-25-2012 11:39 PM
Page generated in 0.22391 seconds with 20 queries
