  • 1 Post By BuddySpeed3
 Old 11-16-2016, 03:11 AM   #1
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Default Bent Rod Club
Well last sunday I joined the bent rod club. So let the rebuilt begin. Sad to see.
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
Project_dog is offline   Reply With Quote
 Old 11-16-2016, 05:34 AM   #2
Vitamin M's Avatar
Posts: 87   (View Stats)
Vitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these partsVitamin M is infamous around these parts
Sorry to hear. Were you tuned for that BNR S3 ? Who tuned you ? What was the milage ? What gas were you running ?
Vitamin M is offline   Reply With Quote
 Old 11-16-2016, 05:52 AM   #3
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Sorry to hear man. Could have been worse though. At least the block is salvageable, and you can easily come back stronger! Is that cylinder 4? How much torque was it putting to the wheels, and at what rpm?
It's funny, I am just at paranoid when it comes to being on the stock block. I target peak torque above 4k rpm and never exceed 350 ft lbs, and I run more octane than I need.
Last edited by BuddySpeed3; 11-16-2016 at 05:52 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to BuddySpeed3 For This Useful Post:
Vitamin M (11-16-2016)
 Old 11-16-2016, 06:10 AM   #4
Vitamin M's Avatar
see that worries me because i wanna go big turbo but these stories of guys doing everything right and then bent rods.
 Old 11-16-2016, 08:09 AM   #5
torquemaniac's Avatar
Posts: 733   (View Stats)
@Project_dog; you need some meth love
Self tune or the preferred CX7Modderz tuner (PD)?
2011 CX-7 AWD 2.3 turbo
 Old 11-17-2016, 06:23 AM   #6
In my mind, as long as peak torque happens a bit later in the rpm range, and isn't excessive, you can have the tune setup to try and carry that torque as far out to red line as possible. Naturally torque will taper off as rpm increases.
For example; If we are able to carry a conservative 330 ft lbs of torque to 6000 rpm, that equals 376 hp. 330 ft lbs is still safe for a stock block with proper consistent fueling, consistent boost targets (aka. a good tune).
There are many who target 400 ft lbs on the stock block with a good tune, and have been laughing. Me personally, my limit for peak torque is 350 ft lbs, and always above 4k rpm. It really comes down to how comfortable you feel, and always realizing that there is a risk if pushed too far.
The formula to calculate HP is as follows:
HP = (TQ x RPM)/5252
After playing with that formula for a bit, I realized just how attainable high HP numbers are with conservative TQ numbers. The goal is to target a conservative TQ number, and carry it as far out to red line as possible to yield the most HP.
Vitamin M likes this.
Vitamin M (11-17-2016)
 Old 11-17-2016, 08:53 AM   #7
Vitamin M's Avatar
From my basic understanding another way to do that (achieve peak torque at higher RPM) when not through a tune but mechanically is to reduce piston stroke distance and increase bore diameter. In mechanical sense this will change an engines performance by shifting peak torque towards the upper RPM range without taking into consideration any tuning changes. But with stock motor, options are limited to tuning ofcourse.
The Following User Says Thank You to Vitamin M For This Useful Post:
BuddySpeed3 (11-17-2016)
 Old 11-17-2016, 08:55 PM   #8
Yeah that makes sense. Kinda like how honda motors rev so high due to their shorter strokes, but make a lot less torque.
 Old 11-19-2016, 04:16 AM   #9
I was tuned for the turbo. I had a over boost code. For some reason I never heard the exhaust leak on my car. Once we pulled the turbo off. The bottom two or three dp nuts were loose. Then we pulled the motor out. The back side of the engine was covered in black soot. I'm happy it didn't go through the block. I just order parts for the rebuild. The block is bored out for 88 mm pistons. Answer yes I want some methanol. But this build is going to set me back. I really want to port and polish the head and intake. But i dont think i have the time to do it
But I did notice some things about the oil flow in the block Im going to work at by sanding the block out.
The Following User Says Thank You to Project_dog For This Useful Post:
torquemaniac (11-19-2016)
 Old 11-19-2016, 06:27 AM   #10
You should mod the transmission also while you are at it...I can send you the pressure regulator upgraded spring if you want (I have one left)
Faster and firmer shift really improve the driving experience, but you will have to use the manual shifter for the rest of your life
 Old 11-19-2016, 10:15 AM   #11
Pm on face book.
Car Club USA: Back to the Future with the SoCal DeLorean Club Haltech Automotive News 0 01-21-2016 10:10 AM
Car Club USA: Porsche Club of America Escape to Rushmore Haltech Automotive News 0 12-16-2015 10:10 AM
Car Club USA: Ferrari Club of America Haltech Automotive News 0 04-21-2015 10:30 AM
Car Club USA: Club Loose Haltech Automotive News 0 02-19-2015 10:40 AM
Page generated in 0.31987 seconds with 24 queries
