  • 1 Post By b.wilson
 Old 07-25-2011, 08:26 AM   #1
b.wilson's Avatar
Posts: 1   (View Stats)
b.wilson is an unknown quantity at this point
Default CX-7 cylinder 4 misfire code? need help
Have changed the spark plugs, Checked the coil pack on another cylinder but still comes up with the same code p0304 cylinder 4 misfire.
Car is running horrible? any sugestions?
Car is stock with no upgrades except wheels. 86,000 miles
Bmcgough likes this.
b.wilson is offline   Reply With Quote
 Old 07-25-2011, 01:27 PM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
Dirty valves, bad injectors, compression. I would do a compression test and make sure u have power and cycling ground at your coil.
 Old 07-25-2011, 01:34 PM   #3
Tke a look at this thread.
http://www.mazdaspeedforum.org/forum/foru...misfire-68182/
I think the Po302=cyl #2 and P0304=#4.
Might be why.
 Old 12-13-2014, 08:39 AM   #4
stick's Avatar
stick is an unknown quantity at this point
I have 07 cx 7 with 86k miles and have a misfire in cyl 3. took it dealer and they said piston ring is bad.
issue started with a weird idle during cruising speeds, thats it.
luckily I have ext warranty and getting a mild rebuild with new piston rings, connecting rod bearings, new EGR, and new motor mount under warranty.
stick is offline   Reply With Quote
 Old 08-01-2018, 07:47 PM   #5
Bmcgough's Avatar
Bmcgough is an unknown quantity at this point
Default 2007 Mazda CX 7 Misfire Cylinder 4
Hello, I’m happy to find a forum without the vendors & junk that accompanies their ads.
I’ve been having a horrible time trying to fix my car. I’ve replaced plugs, coils, and the computer. It’s becoming very costly & I desperately need to find a solution. I’m hoping someone here has some experience with this issue and can share some wisdom!
Bmcgough is offline   Reply With Quote
misfire rodrigo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 10-28-2011 10:37 PM
massive misfire unr8ted MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 04-26-2010 02:29 PM
Cylinder 2 misfire Help!!! gt5 MazdaSpeed 3 - Engine, Transmission & Driveline 7 03-27-2010 03:55 PM
random cylinder misfire - p0300 p300 phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 17 09-26-2008 03:50 PM
Page generated in 0.25247 seconds with 24 queries
