 Old 05-02-2018, 05:32 PM   #1
UBeenProbed's Avatar
Posts: 1   (View Stats)
UBeenProbed is an unknown quantity at this point
Default Engine specs?
Hello everyone, new to the forum. I bought a blown 2010 cx7 2.3 turbo. Threw the number 3 rod. Bought to fix and use as the family car (and because I wanted an excuse to be in the garage). But anyways, sourced a block for a Mazdaspeed 3 got it honed and hot tanked and the head resurfaced, seats and valves. List of parts I’ve bought: water pump, oil pump, timing set, but actuator and sprocket, all gaskets, head bolts, injector seals, turbo cartridge(old one was sloppy and leaking oil) and new rings. There’s more just can’t think of them off the top of my head. Doing a stock build, no intentions of any performance add one.
I’ve been searching all over trying to find torque specs and ring gap specs or even and chiton or haynes service manual but I haven’t came up with anything. I’ve got everything I need as far as I know, just got the new crank and main bearings in the block. Snugged the girdle up until I can find some info.
Anyone know torque specs for:
Main girdle bolts
Conn rod bolts
Head bolts
Cam sprockets and mounting bolts
Harmonic balancer
Flywheel bolts
Torque converter to flywheel nuts
gap specs for the piston rings?
Also what is the procedure for proper gear alignment for the balance shaft assembly?
Any build tips as well?
Any and all info is appreciated very much, I want to build this right since my 1 year old son will be in it. Built an engine for my sn95(which still isn’t done haha). And to be honest, I came into this build thinking it was like all the other engines I’ve worked on, I was wrong. =P
But anyways thanks for allowing me into the forums and thanks for any help and advise.
I will post pictures of the grenade and build progress as well.
UBeenProbed is offline   Reply With Quote
 Old 05-02-2018, 06:18 PM   #2
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
Donate for access to all the manuals on the forum
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
 Old 06-02-2018, 11:49 AM   #3
Aja1732's Avatar
Posts: 33   (View Stats)
Aja1732 will become famous soon enoughAja1732 will become famous soon enough
CX-7 FAQ Thread
The service manuals are located in this thread. Used them many times.
Aja1732 is offline   Reply With Quote
All-Data engine TQ specs HOCKEYNUBE 2010 MS3 - Torque Specs & information 17 02-02-2020 09:40 PM
torque specs for engine on ms6 dkfung88 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 01-24-2014 05:18 PM
Engine Stand Bolt Specs Airman3454 Gen2 MS3 General Discussion 6 07-07-2013 05:47 PM
Engine specs viper1b2 MazdaSpeed 3 - Engine, Transmission & Driveline 6 05-09-2011 06:14 PM
MS3,MZ3, MZ5 Engine Mount Torq Specs Grumpyjap MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-05-2011 02:47 PM
Page generated in 0.24373 seconds with 22 queries
