 Old 11-17-2016, 09:15 AM   #1
mauricio88's Avatar
Posts: 1   (View Stats)
mauricio88 is an unknown quantity at this point
Default Gasket replacement Mazda CX-7
Hello everyone. I am new on this forum, but I use to read it. You have a great forum here. I own a Mazda CX-7 2.3 turbo from 2008 and now I have it at the mechanic. The issue is the cylinder 3 was out of service. At first, we thought it was something electrical or the spark plug, but then the mechanic took out the gasket to see the cylinder and he found it was overheated. Now I don't know it I have to change the piece completely, because it is very difficult to find it. I attached some images to see the problem.
I live in Dominican Republic and it's not that easy to find this part. What do you think I should do with that? Thank you very much for your help. I promise to participate actively in the forum.
Regards.
mauricio88 is offline   Reply With Quote
 Old 11-17-2016, 12:00 PM   #2
Dropen's Avatar
Posts: 46   (View Stats)
Dropen will become famous soon enoughDropen will become famous soon enough
Regards.
Take a look here...
Dropen is offline   Reply With Quote
Replacement 3" Donut Gasket for UR DP??? Cujo 2010 MS3 - Engine, Transmission & Driveline 2 05-20-2014 08:21 AM
PG manifold V2, replacement gasket with small raised area... leak path? MS3 Ventura Mazdaspeed3/6 General Discussion 2 09-29-2008 09:12 PM
Page generated in 0.24032 seconds with 21 queries
