 Old 03-02-2017, 04:27 AM   #1
tritom45ca's Avatar
Posts: 2   (View Stats)
tritom45ca is an unknown quantity at this point
Default Help with intake manifold
I had a timing chain break, took everything apart and found a couple of bent valves.
Today I have a rebuilt head ready to go back on. When I took off the intake manifold I noticed that a plastic arm that is attached to a rod going through the intake runner had broken off. I'm wondering if my intake is pouched because of this or can the rod with the flapper valves be removed.
I have attached a pic of the valve that attaches to the rod going into the intake runner with the missing plastic arm.
Any help would be much appreciated.
tritom45ca is offline   Reply With Quote
 Old 03-02-2017, 07:14 AM   #2
mktx01's Avatar
Posts: 185   (View Stats)
mktx01 is infamous around these partsmktx01 is infamous around these partsmktx01 is infamous around these parts
You can remove the flappers like a pnp intake manifold. There is a code you have to turn off through the access port though.
How to Port the Stock Intake Manifold
mktx01 is offline   Reply With Quote
 Old 03-02-2017, 08:38 AM   #3
tritom45ca's Avatar
Awesome, thanks for the reply.
 Old 03-02-2017, 08:57 AM   #4
mktx01's Avatar
Anytime, good luck with the car.
 Old 03-02-2017, 09:21 AM   #5
Police - Grammarhead
Vansquish's Avatar
If you have to deal with emissions testing, you're not going to be able to port the intake without throwing a code. You can actually get around this by A) searching the forum, and B) doing what I posted in the link below:
Now what..P2006
Varomnia (03-02-2017)
Ecoboost Intake Manifold VS MZR Intake Manifold theschrum Ford Focus ST Ecoboost - General Discussion 39 10-28-2013 10:28 PM
Page generated in 0.26737 seconds with 23 queries
