 Old 07-23-2016, 06:42 PM   #41
ToyCop's Avatar
Posts: 237   (View Stats)
ToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond reputeToyCop has a reputation beyond repute
Gets a crowfoot wrench, extension, and torque wrench. That's how I did it on my old Mazda.
2011 Mazdaspeed 3 VRM W/Tech
CorkSport: 3" Power Series SRI, BPV & hose, Boost tubes, Battery box, HPFP internals, Short shifter and bushings.
ETS TMIC, Ultimate Racing test pipe, Damond dual OCCs, Damond TMM, CP-E S2 RMM, COBB APv3, Freektune OTS+ 93 Oct.
Rice: RallyArmor, Morimoto XB LED Fogs, VLeds Triton Reverse Lights, Redline boots and armrest cover, Maisonvi shift knob.
Audio: Pioneer AVIC-7100NEX
ToyCop is offline   Reply With Quote
 Old 07-23-2016, 10:42 PM   #42
blackms3_71's Avatar
Posts: 2,250   (View Stats)
And why after tighten it are y then backing it off a 1/4 turn?
 Old 07-24-2016, 12:01 AM   #43
Juschiln19's Avatar
Posts: 160   (View Stats)
Juschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of lightJuschiln19 is a glorious beacon of light
Because in the oil cooler leaking tread it says if u over tighten it, it will cause a leak aswell. And if I'm just going to guess on what torque it's at. that's why i tightened all the way down then to prevent leaking from over tightening then back it off a smuge..
06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly
Juschiln19 is offline   Reply With Quote
 Old 07-24-2016, 12:07 AM   #44
Juschiln19's Avatar
Did u do the calculations to get the correct torque? after using a adapter like that what the torque wrench says will be off.
There's no easier way the calculation on that is a pia
 Old 07-24-2016, 12:53 AM   #45
ToyCop's Avatar
If the handle of the wrench is at a 90 to the crowsfoot head the difference is minimal. The ones I use have a pretty short shank. If the shank added any considerable length I'd figure it out. I've used these on everything from cars to rifles and have never had any issues. Using antiseize or thread locker causes higher torque values as well. Just don't go crazy wrenching on it.
The Following User Says Thank You to ToyCop For This Useful Post:
Juschiln19 (07-24-2016)
 Old 07-24-2016, 01:04 AM   #46
Tbh when i did the spin on conversation idk about so many people having issues. I didnt tq anything and i did remove the whole housing. Put it all back together and never had a leak. Sucks so many people having issues
Juschiln19 (07-25-2016)
 Old 11-13-2016, 04:57 PM   #47
leftysoftball's Avatar
Posts: 1   (View Stats)
leftysoftball is an unknown quantity at this point
Hello all, first post here. I has a leak from the gen 1 oil cooler gasket that I repaired in Dec. 2014. Started leaking again this fall. I torqued the cooler bolt but it's leaking again. For the life of me, I couldn't find a void, tear or break on the old gasket I took out but I installed an new one anyway.
I couldn't get a torque wrench on the 4 mounting bolts either but it's not leaking from there. Maybe I got lucky on that.
Before doing this job again, I'm considering buying a gen 2 cooler rather than replacing the plastic/silicone gasket that may wear out in another couple of years. Will the gen 2 cooler mount up to the existing oil filter assbly.? Ebay has the whole cooler with bolt and gaskets for $130 - $160 delivered.
Thanks,
Sean
leftysoftball is offline   Reply With Quote
2007-2010 mazdaspeed3 VVT FrankenFk MazdaSpeed 3 - Engine, Transmission & Driveline 5 01-22-2012 10:08 AM
2010 MS3 Wheels on a 2007 MS6 PoMan Wheels & Tires - SILVER 22 10-15-2011 11:50 AM
Boost leak fixed, engine runs cooler? -cj- MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 08-01-2010 10:01 AM
2010 to 2007-9 gear swap? labikesrcool MazdaSpeed 3 - Engine, Transmission & Driveline 18 04-29-2009 06:11 PM
Page generated in 0.32435 seconds with 24 queries
