 Old 05-06-2018, 07:01 PM   #1
jred1418's Avatar
Posts: 1   (View Stats)
jred1418 is an unknown quantity at this point
Default overheating, need thermostat help
I change the radiator and a week later in starts to overheat. did research then I had found air in the line from when I replaced the radiator. and now it will run at normal temp for 2 days or so, then all of a sudden I run hot. if it the thermostat, how and where is it
jred1418 is offline   Reply With Quote
 Old 05-07-2018, 03:08 AM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Search the site using google and the information shown below. The truth is out there.
site:www.mazdaspeedforum.org/forum (search term goes here)
How To:Thermostat mach69 MazdaSpeed 3 - How-To's 130 11-16-2018 08:32 AM
Bad thermostat? Bombtek MazdaSpeed 3 - Engine, Transmission & Driveline 13 12-02-2013 06:37 AM
Overheating....Thermostat?? MS6FL MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 11-25-2011 11:36 AM
getting dtc:P0126 Coolant thermostat stuck open ON 2 Thermostat dixie789456 MazdaSpeed 6 - Engine, Transmission & Driveline 4 06-08-2010 10:52 AM
Page generated in 0.23527 seconds with 21 queries
