 Old 04-26-2016, 08:18 AM   #1
rycher's Avatar
Posts: 4   (View Stats)
rycher is an unknown quantity at this point
Default Remove/Lower transaxle to get to turbo???
I think my turbo seals are gone and im needing to remove and reinstall my turbo but im curious if you have to remove/lower transaxle in order to get the turbo out.
I have the 2010 cx - 7 AWD. I asked this in a thread i already had but didnt get an answer so i thought i'd create new thread. I have done alot of reading and i've read both answers that yes you have to remove'/lower transaxle for the AWD model..
is this true???
Thank you in advance.
rycher is offline   Reply With Quote
 Old 04-05-2017, 11:43 AM   #2
CX-7Pilot's Avatar
Posts: 22   (View Stats)
CX-7Pilot will become famous soon enough
I don't think you do, but it's still a pain. Does anyone have the factory repair manual guide?
CX-7Pilot is offline   Reply With Quote
 Old 04-05-2017, 12:30 PM   #3
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Go VIP and the FSM's are available.
The turbo is removed from the top of the engine.
 Old 04-08-2017, 06:39 AM   #4
torquemaniac's Avatar
Posts: 733   (View Stats)
The turbo is easily removed with a stick of dynamite
You can remove the turbo from the top : removing the cowl will help but is not necessary...however be ready to curse a lot with the bolts and O2 sensor...those are frequently seized!
The workshop manual is in the CX-7 intro thread
2011 CX-7 AWD 2.3 turbo
HOW TO: Remove your turbo CX7Haley CX-7 > How-To's 11 09-16-2014 10:43 AM
How do i remove the lower lip? tragik 2010 MS3 - How-To's 16 10-12-2011 10:21 AM
How Hard to Remove Turbo ? Scatt Nasty MazdaSpeed 3 - Engine, Transmission & Driveline 9 02-26-2009 05:55 PM
Lower peak boost after Turbo Inlet install 802MS3 MazdaSpeed 3/6 - Turbo Induction 22 01-16-2009 06:54 PM
MS3 Transaxle oil pbblaster MazdaSpeed 3 - Engine, Transmission & Driveline 16 04-10-2008 07:39 PM
Page generated in 0.24843 seconds with 23 queries
