 Old 07-08-2016, 02:48 PM   #1
mherrera's Avatar
Posts: 6   (View Stats)
mherrera will become famous soon enough
Default Shake on gear change
Hi everyone, I have a 2010 cx7 and it start normal and start moving normal, but in sometimes between 60 and 80, shake when it time to change gear. It have if I let the car to change gear slowly, if I accelerate at more than 3,000 rpm I don't feel the shake, and if I use manual I can change the gear without problem. I took it to a mechanic and he said it is the solenoid. What can I do he said I can change the solenoids with problem o change the whole valve box.
Thanks.
mherrera is offline   Reply With Quote
 Old 07-08-2016, 02:55 PM   #2
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
you might want to get the factory service manual and see what it would take to replace and the testing procedures
 Old 07-08-2016, 03:01 PM   #3
mherrera's Avatar
Thanks for reply, Where could I get that manual?
 Old 07-12-2016, 04:47 AM   #4
torquemaniac's Avatar
Posts: 733   (View Stats)
You need to give a more detailled description of the problem (in what gear does the ''shaking'' happens...)
I dont think you need to change the valve body for this...you can make adjustment to the clutch control valve on the Aisin TF-81 transmission...the adjuster can compensate for wear in the valve body components
If you are interested I can guide you through the process
2011 CX-7 AWD 2.3 turbo
The Following 2 Users Say Thank You to torquemaniac For This Useful Post:
Vansquish (07-12-2016), WetzMS3 (07-12-2016)
 Old 07-12-2016, 07:34 AM   #5
mherrera's Avatar
Thanks for the answer torquemaniac, In more detail I feel the shake between 4 and 6 gear. Like I said it happen if I let the vehicle change the gear normally about 2,000 rpm. If I accelerate at more that 2,500 or 3,000 rpm I do not feel the shake. And on manual either.
Thanks,
The Following User Says Thank You to mherrera For This Useful Post:
torquemaniac (07-12-2016)
 Old 07-12-2016, 07:46 PM   #6
Thanks,
Just to clarify things, do you feel the shake in manual mode when you shift it at 2000rpm (that is in 4th to 6th gear?
If you can reproduce the effect in manual mode, do you feel a shift delay and then a bump when the gear engage?
 Old 07-13-2016, 07:13 AM   #7
mherrera's Avatar
No, I do not feel the shake on manual, only on automatic. When it happens the vehicle start shaking and then stop when gear change.
Thanks,
 Old 07-13-2016, 08:07 AM   #8
Thanks,
OK...so you literally feel the car shaking and cant replicate the problem at 2000rpm in manual mode...I am lost now...
The problem should happens in both automatic and manual mode at 2000rpm if it was the transmission
The transmission should not make the car shake also...maybe one of the motor or transmission mounts are damaged
 Old 07-13-2016, 09:14 AM   #9
mherrera's Avatar
Another information. I took the car to a mazda mechanic and with some scanner it detected a bad solenoid. When he changed the problem disappear for 2 days. After that it appear again. Now he says it can be some kind of pressure problem, the solenoid is damage again, or other piece that now I do not remember the name.
 Old 07-16-2016, 08:02 AM   #10
mherrera's Avatar
Hi, I went for a ride with the mechanic and the scanner says the solenoid are OK. Now the mechanic say after feeling the shake that the problem is the torque converter. That it could be damage and need to be replace.
Thanks.
 Old 11-14-2016, 10:01 AM   #11
Dropen's Avatar
Posts: 46   (View Stats)
Dropen will become famous soon enoughDropen will become famous soon enough
I have a similar issue, when the car (in automatic) change to the 3 to 4th it make a bit shake... Did the replacement of the torque converter works?
Dropen is offline   Reply With Quote
MS6/MS3 gear ratios change paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 292 07-22-2018 01:10 PM
Throttle blips on gear change furinax Mazdaspeed3/6 General Discussion 7 09-18-2017 10:16 AM
3rd gear stops at 4k and change hron13 2010 MS3 - ECU Computer Tuning 17 01-18-2013 04:08 PM
Man buys truck with change, LOTS of change Haltech Automotive News 1 08-14-2008 09:15 AM
Page generated in 0.30757 seconds with 24 queries
