 Old 08-20-2011, 06:32 PM   #1
Matx's Avatar
Posts: 1,681   (View Stats)
Matx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the worldMatx is the leader of the world
Default transmission
I have a friend that has a cx7 says when the car was going about 30-40 when it downshifted from 3rd into 2nd it slamed into gear so hard that the tires locked up and it was feeling like it wanted to stop, he gets home and it will no longer go into reverse it had a code "ABS-1306" read it off the AP. it will go into gear going forward any ideas?
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
Originally Posted by backward_0 View Post
.... I will be more than happy to fuck your world off....
Matx is offline   Reply With Quote
 Old 08-21-2011, 11:09 AM   #2
edwhayes's Avatar
Posts: 157   (View Stats)
edwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to all
Sounds like a faulty TCM. Flatbed it to the dealer for safety reasons.
edwhayes is offline   Reply With Quote
The Following User Says Thank You to edwhayes For This Useful Post:
Raider (08-21-2011)
 Old 08-21-2011, 02:58 PM   #3
AP is not even supposed to work on cx7. ThaT said, tcm issues, tow it in, have dealer try refalshing tcm, or replace.
Also, fluid leveL check, and when was it last flushed if over 40k miles.
 Old 08-21-2011, 05:19 PM   #4
Matx's Avatar
Only used AP to read code was flushed @ 45k will have dealer reflash it thanks
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 08-23-2011, 11:13 AM   #5
Alpha Wolf's Avatar
Posts: 396   (View Stats)
Alpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the world
Reflash TCM
2007 Touring CX-7 Liquid Platinum
Kenwood DDX419 DVD/Bluetooth/CD/ Rosen headrest DVD/Game units CP-E CAI ETS 3" Black Powder Coated TMIC
Forge Black Powder Coated BPV Nitto 420 Tires Vogtland Lowering Springs. Tuned with VersaTune
Alpha Wolf is offline   Reply With Quote
transmission cm-jp1 MazdaSpeed 6 - Engine, Transmission & Driveline 3 03-30-2010 08:58 AM
transmission AK-speeder MazdaSpeed 3 - Engine, Transmission & Driveline 6 08-24-2009 09:44 PM
Page generated in 0.25702 seconds with 23 queries
