 Old 04-05-2017, 11:57 AM   #1
CX-7Pilot's Avatar
Posts: 22   (View Stats)
CX-7Pilot will become famous soon enough
Default Turbo DIY - Anyone have a link?
I need to replace the gasket that's between the turbo and the exhaust manifold. I was removing the 4 bolts in the hopes of being able to slip the new gasket between the parts, but then the aft passenger side bolt busted off on me. Now I need to take the whole thing apart.
What started off as an exhaust leak has now turned into a major repair.
Does anyone have a link with a description/photos of what has to happen in order to remove the turbo so I can get the stud that broke removed and then put in a new gasket? I'm going to be getting an o2 sensor tool today. Anything else I should get? I have the basic sockets and wrenches. I've heard some 14mm wobble neck wrenches will help.
I have a turbo gasket set for the 2 large surfaces and some o-rings that came with it as well. Do I need any other gaskets before tearing this apart?
https://encrypted-tbn0.gstatic.com/i...UcjA-bIxpLsn-i
Thanks for any help.
CX-7Pilot is offline   Reply With Quote
 Old 04-06-2017, 10:50 AM   #2
CX-7Pilot's Avatar
thought I'd post a photo of my problem. I've searched youtube for solutions and the only thing I can think of that might work is welding a washer/nut to the stud. It's about flush with the flange. It might stick out about 1/16th of an inch. I might try drilling it out. I have a compact 90 degree drill fits in the spot. Any suggestions? The local Mazda expert frowned at the idea of trying to weld something to get it out.
 Old 04-06-2017, 07:17 PM   #3
sheston's Avatar
Posts: 1,847   (View Stats)
Personally, I would try to get it off the car to work on it. I might have enough sticking out without the exhaust flange to grab it with vise grips....
 Old 04-07-2017, 05:10 AM   #4
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
This might help:
https://www.youtube.com/watch?v=JQ-dfNrAp34
It shows exactly how to remove everything.
MS6 Bushing/Link Set? Knight F Mohawk MazdaSpeed 3/6 - Suspension & Brakes 2 04-28-2014 06:11 PM
Looking to buy(link included) druddock Mazdaspeed3/6 General Discussion 13 11-09-2012 01:42 PM
end link removal j.ferger MazdaSpeed 3/6 - Suspension & Brakes 2 10-17-2011 12:15 PM
Page generated in 0.24417 seconds with 23 queries
