  • 1 Post By DubVms3
  • 1 Post By cpolly69
 Old 03-30-2011, 07:32 PM   #1
X lady killer X's Avatar
Posts: 7   (View Stats)
X lady killer X has a little shameless behaviour in the past
Default venting to atmosphere
is anyone doing this on the cx-7?
i put an HKS bov on and had it stock... never noticed a difference...
unhooked the bypass valve hose and let it chill.. i can super here the turbo and it feels like it pulls a little harder ( sucking un restricted air into the turbo from the bypass valve? )
i drove like 30 miles then all of a sudden a CEL when sitting in a parking lot...
now...
cell is on but i like the sounds im getting and the "extra" power feel is dope... i like the VTA sound because its super loud...
is anyone set up to VTA and not getting a CEL?
lmk what you did or im just going to put the tube back on be super quiet again
X lady killer X is offline   Reply With Quote
The Following User Says NO Thank You to X lady killer X For This Un-useful Post:
Bucker (03-30-2011)
 Old 03-30-2011, 07:37 PM   #2
Put the tube back on
Bucker (03-30-2011)
 Old 03-30-2011, 07:40 PM   #3
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
hear*
donate, both of you
 Old 03-30-2011, 07:40 PM   #4
DubVms3's Avatar
Posts: 101   (View Stats)
DubVms3 is just really niceDubVms3 is just really niceDubVms3 is just really niceDubVms3 is just really nice
Block the recirc hose off with a plug and reset your ecu and you should be fine. I am running vta with turboxs. I put it on, blocked off the recirc hose, and drove it for about 100 miles and threw a cel. I unhooked my battery cable for 10 sec, put it back on and never again threw a cel
jgarrison likes this.
True red 2008 MS3 GT-Mazdaspeed CBE- Mazdaspeed CAI- Mazdaspeed lowering springs- Nator(gutted) downpipe- testpipe-Autotech Internals- Hypertech tuned- HKS SSQV- CPE gauge pod- Prosport boost-oil temp- Innovate AFR Wideband- Broadway mirror- 20% tint- Grayco car seat
DubVms3 is offline   Reply With Quote
 Old 03-30-2011, 07:40 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i want a BOV that goes ....pssss-nigggaaaaaaaaaahhhhhh
The Following 2 Users Say Thank You to rodrigo For This Useful Post:
aaronc7 (03-30-2011), TheNewGuy (03-30-2011)
 Old 03-30-2011, 07:42 PM   #6
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
757CX7 likes this.
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
myt_tuf1 (03-30-2011)
 Old 03-30-2011, 07:49 PM   #7
will post up tomorrow after blocking that bitch
for all i know it could be another EGR code i got a few weeks ago for no fucking reason
 Old 03-30-2011, 07:51 PM   #8
DubVms3's Avatar
Alright then
 Old 03-30-2011, 08:03 PM   #9
irishking03's Avatar
Posts: 2,136   (View Stats)
If you didnt block the hose than its going to throw a CEL. I Have HKS on my MS3 that was running vta. Never had CEL but my battery was also disconnected when I installed BOV. Im now running Recirc and think it sounds so much better. I do like the VTA mode but think I like recirc alot better. GL..
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
 Old 03-30-2011, 09:05 PM   #10
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
use the search, also these cars are made to run in recirc, dont vta, hook the hose back up and run it like its supposed to
2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge
speedms6 is offline   Reply With Quote
 Old 03-31-2011, 03:58 AM   #11
yearzero's Avatar
Posts: 439   (View Stats)
yearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the world
^ agreed.
i'm not sure if anyone has found a proper tuning solution for vta but without a tune i wouldn't run in vta. i like the sound too, but screwing with your car's performance for sound is just ricer bullshit.
Cobb SRI - CXRacing FMIC - NGK 1step colder - DashHawk - Cobb AP Stage2 + ATR - SU RMM - PTP IM Gasket - CP-E catless downpipe
yearzero is offline   Reply With Quote
 Old 03-31-2011, 04:39 AM   #12
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
you guys are all silly gooses!
lemme explain why vta is bad on a stock draw thru maf setup
your maf is located pre turbo also know as draw thru, hence air is metered before it hits the turbo. whn you vta all the extra air that gets bounced back when the throttle plate is closed is accounted for. so the ecu already calculated for that extra air and when no extra air comes back, the fuel is still getting dumped in with no air making you run rich.
running pig rich between shifts is bad. why? do a search
p.s if you really want to vta, make a blow by maf setup. also if you dont understand wat im talking about, search. but try google because the only person ive seen do this is on the ms plateform is qwik6.
 Old 04-01-2011, 05:22 AM   #13
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
i had a map on my standback made to run vta. so OP buy my standack and run vta
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 04-01-2011, 05:48 AM   #14
kmac's Avatar
Posts: 1,792   (View Stats)
Vta is very homosexual.
 Old 04-02-2011, 10:28 AM   #15
ottoblotto's Avatar
Posts: 266   (View Stats)
ottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond repute
LOLed a lot...
2011.75 BMW E90 M3
El-Superbeast-O
ottoblotto is offline   Reply With Quote
SURE TIP Installed, Noise when Venting Cue CX-7 > Issues & Troubleshooting 13 02-14-2011 11:24 PM
fucking venting bbjoy Mazdaspeed3/6 General Discussion 19 02-11-2011 11:20 AM
Venting about clutch service at dealer!! myspeedy07 MazdaSpeed 6 - Engine, Transmission & Driveline 2 11-28-2008 12:51 PM
Page generated in 0.35445 seconds with 32 queries
