![]() Join Date: Dec 2016 Location: Europe / Poland
Rep Power: 0 ![]() ![]() Thanks: 4
(Thread Starter) | Not Ranked : 0 score Hi, I'm almost sure but I need confirmation. Is it fuel pressure sensor? |
Groans: 60
| Not Ranked : 0 score Yes. That should be it.
| The Following User Says Thank You to SSinstaller For This Useful Post: | tomek CX7 (05-29-2017) |
| Cx-7 fuel pressure sensor | Tluv808 | CX-7 > General Lounge + New Member Welcome | 1 | 01-07-2014 01:14 PM |
| Bad Fuel Pressure Sensor? | JumpingJackson | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 8 | 11-18-2013 07:51 PM |
