> CX-7 > Car Audio & Electronics
 Old 09-13-2019, 08:21 AM   #1
Buddylee3177's Avatar
Posts: 2   (View Stats)
Buddylee3177 is an unknown quantity at this point
Default 07 cx-7 can’t set clock
07 cx-7 with stock touchscreen. After battery disconnect I’m unable to set the clock. Go into settings calibration set clock and the hour up down doesn’t do anything. Any ideas?
Buddylee3177 is offline   Reply With Quote
 Old 09-13-2019, 04:57 PM   #2
ChevyCruizer's Avatar
Posts: 12   (View Stats)
ChevyCruizer will become famous soon enough
Not being a smart ass but disconnect the battery at 11:59 and then hook it back up at noon, that is if it auto sets to noon.
2007 Mazdaspeed 3, as purchased...Cobb AccessPort and SF intake with the factory turbo inlet pipe, el cheapo CX Racing Front Mount Intercooler (FMIC) kit (fits like crap), unknown 3 inch turbo back exhaust, smokey K04 turbo that is oiling up the intake and intercooler.
Purchased and awaiting install...AutoTech High Pressure Fuel Pump (HPFP) Internals, Treadstone TR-8L intercooler, HTP under-route piping kit and 3.5" Full Intake System, 51R battery and tray, CorkSport 3.5 Bar MAP sensor and 3 Port Electronic Boost Control Solenoid (EBCS), Damond Motorsports PVC plate with OCC, EGR delete and motor mount kit, Torque Solutions Short Shifter Plate (SSP). Purchased on Black Friday 2018...BNR S4, Full Race exhaust manifold, JMF intake, Stratified eTune.
Researching and purchasing soon...upgraded in tank fuel pump, Meth injection and/or auxiliary fuel injectors.
Dreaming about...building up a motor with forged internals and/or a 2.5l stroker.
ChevyCruizer is offline   Reply With Quote
The Following User Says Thank You to ChevyCruizer For This Useful Post:
Db09ms3 (09-13-2019)
 Old 09-13-2019, 05:09 PM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Read your driver manual or buy one
Stockish
 Old 09-13-2019, 05:44 PM   #4
I did that’s why I came here I’ve set this clock numerous times after working on the car without a problem. Not working this go around
 Old 09-13-2019, 05:49 PM   #5
Db09ms3's Avatar
Interesting. Bump!
Stockish
Need new clock spring. Help please Nickhxc4life MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 09-27-2016 11:27 AM
Clock resets Soffball 2010 MS3 - Car Audio & Electronics 5 11-09-2010 06:06 AM
setting clock eric8 2010 MS3 - Troubleshoot/Diagnostics 10 03-21-2010 07:21 PM
Page generated in 0.24418 seconds with 22 queries
