![]() Join Date: Nov 2010 Location: Fishers, IN
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score so I took the 7 I'm to have them look for a coolant leak, oil change, and free rotation... when I went to pick up the car the guy proceeds to tell me that they didn't find act leak and topped off the coolant ( the smell/ steam Is back since) and did a "pressure test for free"; that was the good news. the bad news is the battery is all but dead and a tire rod is severely worn. continuing on, he says our battery is so weak they even had to jump it to get it started... the car had never hesitated or had any difficulty state starting. the battery is 138 and that I wouldn't want to get an aftermarket battery because the 7's sometimes have issues/ don't run right..." especially the turbo's". .... I'm like seriously, that's your angle? I mean I've heard some crazy pitches before bit this one is one of my favs! unless I'm missing something... ( common sense?) as I was leaving, he made a big deal about how hewanted me to see if it would start in front of him so that if it didn't, he could jump me...... stated right up, like it had every single time ( had has continued throughout the week). going to get the battery tested tonight and wanted to see what batteries you all have used and recommend ( not being anything top of the line or fancy. going to take it back this weekend to get the tie rod fixed ( extended warranty)and have them look at the coolant smell again. any suggestions? |
| Not Ranked : 0 score I hope you did get a metal chair and hit that guy with it. Just Auto Zone, Duralast Gold. Be done. That is all you really need. Of course, if you never had problems starting, go to Auto Zone, get it tested. Might have been a bullshit excuse to sell a battery. |
![]() Join Date: Jun 2012 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,245
| Not Ranked : 0 score Or they left the lights on and killed the battery and decided to blame it on your battery.
__________________ 2012 Liquid Silver Metallic MazdaSpeed3 with Tech Package. South Bend Clutch Stage 3 Endurance | TWM Full Replacement Shifter | Synapse Engineering BPV | Autotech Internals | Grimmspeed EBCS - 3port | NGK 1 Step Colder Plugs | CNT Catless DP and CBE w/resonator deleted | COBB AP - E35 Tune | HTP 3.5" Intake w/ AMSOIL Dry Filter and Pre-Filter | HTP Battery Tray w/ Energizer 51R | CP-E TMIC | CorkSport DISI Silicone Boost Tubes | Damond Motorsports/Saikou Michi Co. Stage2 OCC | Damond Motorsports Short Shift Plate | Sure Countershift | BOSCH 3 Bar MAP w/MattJackson86 PnP Harness | JBR Rear Sway Bar | JBR EGR Block Off Kit | JBR Manifold - TIG | JBR Throttle Body TIG & Coolant Bypass | JBR 88a RMM | JBR 88a TMM | JBR 80a PMM |JBR DISI Bypass Valve Hose | Ported and Polished Intake Manifold DIY | RX8 Wheels w/ Nitto Motivo 235/40/18 Tires | CP-E Towplate | DIY Custom 600g Shift Knob | Redline Tuning Hood QuickLIFT | 30% / 15% Tint | Craven Speed Stubby Antenna | Broadway 400mm Rear View Mirror | Debadged Mazdaspeed 3 Waiting to be installed: Devil's Own Stage 2 DVC-30 Meth Injection | Damond Motorsports Meth Throttle Body Plate On Order: Coming Soon: DIY Projects: FYCN - TEAM LBN BEERS - FYCN-TEAM MUMFORD - FYCN |
| The Following 3 Users Say Thank You to SparkySparks For This Useful Post: |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score Or left the door open for the courtesy lights to run.....
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" |
(Thread Starter) | Not Ranked : 0 score hahahahhah... if there was a folding chair close enough... taking it to auto zone tonight. |
![]() Join Date: May 2015 Location: JAX & FLL
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Thread resurrection: Is there space to fit a larger battery than OEM? |
| The Following User Says Thank You to Code Monkey For This Useful Post: | Easter Bunny (05-31-2015) |
![]() Join Date: Oct 2014 Location: sugar land, texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score i don't have much to offer here as we're usually seeing a preference for smaller batteries to clear space. however, it's better to create a new topic if you're unable to find your answer. let the dead rest in peace.
__________________ guzzlin' a guinness stout. |
| Not Ranked : 0 score Clearly the search button was used for me to ask such a question but maybe I didn't use the correct keywords in the search. LOL, facepalm & flying mower = nice. I pulled out the battery and realized that there is no chance in hell. It would appear that the insulating box is important heat protection for longevity. I'll have to install a small battery (kinetix HC600) under/behind the back seat for supplemental power.
__________________ Wife's 2009 CX-7 Daily G35 traded in for 2013 JCW for her Red R35 weekend warrior. |
| adding batteries | Timekeeper10 | 2010 MS3 - Car Audio & Electronics | 20 | 02-13-2012 11:34 AM |
| lithium batteries | mzr0818 | MazdaSpeed 3 - Engine, Transmission & Driveline | 16 | 12-03-2011 01:29 PM |
| batteries.com 15% off Storewide Coupon Code at batteries.com | Haltech | Hot Deals Section | 0 | 04-10-2008 05:30 PM |
