![]() Join Date: Feb 2012 Location: Claremont Ca.
(Thread Starter) | Not Ranked : 0 score I have a 2008 CX-7 that is going to need brakes soon. I get a vibration at Freeway speeds and when braking. My Question is 2 part. Part 1 - Best Brake Pad Brand for my CX-7 Part 2 - Resurface or Replace Rotors? Thanks Guys! |
![]() Join Date: Dec 2016 Location: Europe / Poland
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score The workshop manual says 1. Measure the thickness of the disc plate. • If the thickness is not within the specification, replace the disc plate. Minimum front disc plate thickness 26 mm {1.03 in} Minimum front disc plate thickness after machining using a brake lathe on-vehicle 26.8 mm {1.06 in} If you have vibrations the replacement is the best option. ATE set works good in my car for almost 2 years / 30kkm |
![]() Join Date: Feb 2012 Location: Cleveland, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| Not Ranked : 0 score Never had an issue with Centric Blank Rotors & Hawk HP Pads. I've had that combo on my CX7 for a few years. Only complaint is brake dust, but that's to be expected with the pads i have, but i'll take it over better stopping power Sent from my XT1710-02 using Tapatalk
__________________ Cooper Red Mica 2008 CX7 AWD GT w/Nav K&N Drop In, Stock Air Box Mod, HKS BOV, Silver Star Turn Signals, LED Fog Lights, Xtec Hi-Beam Lights, Tinted Tail Lights, ETS TMIC, CS Boost Pipes, RX8 Wheels wrapped wtih Yokohama AVID ENVigors ![]()
![]() Join Date: Sep 2017
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score My brakes were replaced by the dealer before I bought it, so OEM parts are good. Braking is strong and steady.
__________________ Bstrom | Powell, TN 2011 CX-7 | 1995 Miata | 2003 Tundra | 1999 4Runner Limited |
| New Brakes Soon | EvoFire | MazdaSpeed 3/6 - Suspension & Brakes | 10 | 01-01-2014 12:14 PM |
| OEM MS3 brakes = Volvo S60 brakes? | levitron | MSF KB - Mazdaspeed 3/6 - Suspension & Brakes | 110 | 09-19-2012 01:42 PM |
| OEM MS3 brakes = Volvo S60 brakes? | levitron | MazdaSpeed 3/6 - Suspension & Brakes | 109 | 03-02-2012 06:14 PM |
| 2009 MS3 brakes vs. 2010 MS3 brakes | Driver72 | 2010 MS3 - Suspension & Brakes | 11 | 11-21-2009 10:34 AM |
