| Not Ranked : 0 score
old mazda was using fomoco parts with ford but new cx9 are no longer half a ford so i expect less chance to fit...maybe more from an escape or something similar.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
| The Following User Says Thank You to Jeff23spl For This Useful Post: | redboat (11-12-2019) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f126/cx-9-sized-brakes-cx-7-a-149983/ | ||||
| Has anyone removed their brake backing plates? | This thread | Pingback | 08-06-2014 06:36 PM | |
| OEM MS3 brakes = Volvo S60 brakes? | levitron | MSF KB - Mazdaspeed 3/6 - Suspension & Brakes | 110 | 09-19-2012 01:42 PM |
| OEM MS3 brakes = Volvo S60 brakes? | levitron | MazdaSpeed 3/6 - Suspension & Brakes | 109 | 03-02-2012 06:14 PM |
| 2009 MS3 brakes vs. 2010 MS3 brakes | Driver72 | 2010 MS3 - Suspension & Brakes | 11 | 11-21-2009 10:34 AM |
| over sized throttle body... | SpeedSixxx | MazdaSpeed 3/6 - Turbo Induction | 13 | 07-25-2009 10:29 AM |
