> CX-7 > Wheels, Tires, Brakes & Suspension
  • 2 Post By ryoonc
 Old 07-10-2013, 10:36 PM   #1
ryoonc's Avatar
Posts: 15   (View Stats)
ryoonc is just really niceryoonc is just really niceryoonc is just really niceryoonc is just really niceryoonc is just really nice
Default CX-9 sized brakes on a CX-7
The size of the backing plate and similar offsets on the caliper brackets suggested that the CX-7 and CX-9 shared similar brake parts. So after buying one caliper bracket and confirming that it did fit, the rest of the parts (rotors, pads, other bracket) were ordered and put on.
This would fit on a CX-9 too.
Rust
New rotors, caliper bracket, pad
Old rotors, caliper bracket, pad.. quite a difference
Raider and torquemaniac like this.
ryoonc is offline   Reply With Quote
The Following 7 Users Say Thank You to ryoonc For This Useful Post:
Colin1337 (07-11-2013), dale_gribble (07-11-2013), Easter Bunny (07-26-2015), H3R3TIC (07-11-2013), Raider (07-11-2013), Tomas (07-11-2013), torquemaniac (03-19-2019)
 Old 07-11-2013, 02:48 PM   #2
Very cool. In theory, since CX-7 shares a lot with MS6, CX-9 brakes may fit Speed 6!
 Old 07-11-2013, 05:09 PM   #3
ryoonc's Avatar
If the backing plate is the same size, then it probably would haha
It was the most economical bigger-brake upgrade that I could think of (was originally my friend/mechanic's idea). Corksport and Brembo seem to be the only choice otherwise, but there are other things I'd rather do first with ~$1.5k..
The only reason I did this was because it was relatively cheap ($300 total parts+labor) and my front pads/rotors were almost done anyways. The rear rotors, after 76k miles, still look pretty clean and even now the pads seem to have plenty of padding left so I'll probably leave those until they wear out.
Also long time no see raider, you still got your 7? (im ryoonc from mcx7.com a while back, the site seems to have died)
 Old 07-11-2013, 05:11 PM   #4
Colin1337's Avatar
Posts: 1,330   (View Stats)
Colin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the world
Would be awesome if this actually ended up working on the 6 as well. Cool idea
2005 CTS-V
KCCO
2006 Mazdaspeed6 SOLD
COBB AP /|\ 3' Magnaflow CBE /|\ Autotech FPI /|\ COBB SF Intake /|\ NGK plugs /|\ RMM /|\ Megan springs /|\ GReddy RS BOV /|\ Strapped diff /|\ eGay catless DP /|\ BSD 'kit" /|\ PTP oil pan baffle /|\ Custom FMIC /|\ Spin on oil filter conversion
1995 Miata SOLD
Tokiko Illumina Adjustables | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts.
Colin1337 is offline   Reply With Quote
 Old 07-11-2013, 05:16 PM   #5
What size are the CX9 brakes?
Also aren't their calipers twin piston?
 Old 07-11-2013, 05:17 PM   #6
ryoonc's Avatar
I know the cx7 is twin piston, and I'd bet the cx9 is too
As for the size, a quick search yielded:
D1258, Rotor Size: 12.6
The Following User Says Thank You to ryoonc For This Useful Post:
Lex (07-11-2013)
 Old 07-11-2013, 05:21 PM   #7
So the rotor diameter on the CX-9 is the same as the MS3. The calipers are the same CX7 and CX9.
 Old 05-06-2014, 09:31 AM   #8
SpecialK's Avatar
Posts: 830   (View Stats)
SpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the worldSpecialK is the leader of the world
Old thread bump -
So will they fit on a ms6 or no?
2006 Mazdaspeed 6 Zoom Zoom Boom Feb/2014 - fixed 3/30/2014
Motor:
2012 Block / V2 AP / Autotech HPFP / HTP 3" intake / AEM dryflow filter / Fidanza Flywheel / NGK 6510 Step Colder Plugs / TurboSmart BPV / Catless M2 DP / JBR SSP / CPE RMM
Suspension:
Poly SwayBar Bushings / CP-e Rear Diff Mount / BC Coilovers / 245/40/18 on 18x8" RX8 Wheels
Visual:
25% Tint On All Windows / 25% Tint Side Markers / Front Grill Plasti-Dipped Black / Stockers Plasti-Dipped Black / Black Mad M on Trunk / De-Badged / Heavy Shift Knob
Fluids:
Motocraft gold in gearbox / Redline in TC and diff / Oil - Rotella T6 /
SpecialK is offline   Reply With Quote
 Old 07-26-2015, 05:12 PM   #9
JVal1283's Avatar
Posts: 8   (View Stats)
JVal1283 will become famous soon enoughJVal1283 will become famous soon enough
I'm assuming this is just a front brake upgrade...I don't see the rear needing much
Also, I would just need to buy the bracket, rotor, & front pads for a 9 correct?
2009 CX-7 AWD Sport
CS Intake, TIP, EGR delete, Synapse DV
JVal1283 is offline   Reply With Quote
 Old 10-09-2018, 09:40 AM   #10
Reima's Avatar
Posts: 23   (View Stats)
Reima has a spectacular aura aboutReima has a spectacular aura about
Old thread bump as I need to replace my rotors and pads.
Reima is offline   Reply With Quote
 Old 04-09-2019, 03:11 PM   #11
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
is there anyone that actually made it and can confirm the new minimum wheel size with those cx9 brakes. I need to replace brakes on my wife cx7 but she just bough brand new 17inch winter tires this year and i would like to be able to re-use it...
I ask because while hauling the camping car with it, having better brakes could help a bit...But if it need 18inch minimum, i may just look into more agressive pads and keep factory size.
By the way, i can confirm the cx7 2010 factory size front brakes are smaller in diameter than Ms3 or MS6, but the disc thickness is heavier on the cx7. (i have both in hands.)
So ms6 swap could give more ''bites'' but could probably fade a bit faster because of the thickness difference
The ms3 and 6 are close in diameter and the ms6 caliper + braket would bolt up there (I mean replacing both caliper + brakets and disc) but not with the 3 hardware.....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 11-06-2019, 10:07 PM   #12
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
what year CX-7 does the OP have? Gen 1 or Gen 2?
or all the front brakes on the CX-7 the same?
Also anyone experiment with the Gen 2(16-19) CX-9 front brakes?
redboat is offline   Reply With Quote
 Old 11-12-2019, 10:13 AM   #13
Jeff23spl's Avatar
shopping for brakes for the cx7, rotor and pads seem the same for all years....
old mazda was using fomoco parts with ford but new cx9 are no longer half a ford so i expect less chance to fit...maybe more from an escape or something similar.
Wife drive 2010 CX7
redboat (11-12-2019)
« mazdaspeed rims | - »
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f126/cx-9-sized-brakes-cx-7-a-149983/
Has anyone removed their brake backing plates? This thread Pingback 08-06-2014 06:36 PM
OEM MS3 brakes = Volvo S60 brakes? levitron MSF KB - Mazdaspeed 3/6 - Suspension & Brakes 110 09-19-2012 01:42 PM
OEM MS3 brakes = Volvo S60 brakes? levitron MazdaSpeed 3/6 - Suspension & Brakes 109 03-02-2012 06:14 PM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 10:34 AM
over sized throttle body... SpeedSixxx MazdaSpeed 3/6 - Turbo Induction 13 07-25-2009 10:29 AM
Page generated in 0.34481 seconds with 28 queries
