> CX-7 > Wheels, Tires, Brakes & Suspension
 Old 08-02-2012, 10:18 AM   #1
Smadginader's Avatar
Posts: 9   (View Stats)
Smadginader is an unknown quantity at this point
Default Fender Well Rubbing??
Hey Guys,
This past weekend I noticed that when turning the wheel at a certain angle i felt a rubbing vibration in the steering wheel and a slight noise. When i got home I looked in the fender well area and found that on both sides of the car the fender well plastic had come loose from under the front of the car, as if the plastic fasteners came off, and had been rubbing the tires which by then had big grooves melted out the plastic pieces due to the rubbing.. Both sides are the same which is really weird... Any thoughts?
Smadginader is offline   Reply With Quote
spacers + rubbing. TrueReddd MazdaSpeed 3/6 - Suspension & Brakes 15 06-21-2012 04:46 PM
Need help with rubbing jjfam1 MazdaSpeed 3/6 - Wheels & Tires 14 02-09-2012 11:02 AM
tire rubbing maddocx240 Mazdaspeed3/6 General Discussion 21 12-06-2011 11:48 AM
Why am I rubbing? Smily27 2010 MS3 - Wheels & Tires 17 07-13-2011 04:18 PM
225-45-18s, who else is rubbing? 4thStroke MazdaSpeed 3/6 - Wheels & Tires 14 07-07-2008 11:39 PM
Page generated in 0.22363 seconds with 20 queries
