> CX-7 > Wheels, Tires, Brakes & Suspension
Like Tree6Likes
  • 1 Post By bertrand_CX_7
  • 1 Post By Raider
  • 1 Post By Hectik1
  • 1 Post By Zdraveca
  • 1 Post By breakfstincluded
  • 1 Post By Raider
 Old 10-30-2011, 07:14 PM   #1
Alpha Wolf's Avatar
Posts: 396   (View Stats)
Alpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the world
Cool Just ordered EBC Red stuff Pads for my CX7
Did an oil change today and then ordered up EBC Red Stuff pads for my car.
I will take some pictures when I put them on and will report how the are working etc...
2007 Touring CX-7 Liquid Platinum
Kenwood DDX419 DVD/Bluetooth/CD/ Rosen headrest DVD/Game units CP-E CAI ETS 3" Black Powder Coated TMIC
Forge Black Powder Coated BPV Nitto 420 Tires Vogtland Lowering Springs. Tuned with VersaTune
Alpha Wolf is offline   Reply With Quote
The Following 2 Users Say Thank You to Alpha Wolf For This Useful Post:
bertrand_CX_7 (11-04-2011), Raider (10-30-2011)
 Old 10-31-2011, 07:08 AM   #2
ryandlor's Avatar
Posts: 126   (View Stats)
ryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant future
Que? EBC Red Pads?
2009 CX-7
Platinum Silver Metallic
AWD
ryandlor is offline   Reply With Quote
 Old 10-31-2011, 08:06 AM   #3
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Originally Posted by ryandlor View Post
Que? EBC Red Pads?
EBC Red Stuff
 Old 10-31-2011, 02:52 PM   #4
ryandlor's Avatar
Originally Posted by triplejumper18 View Post
EBC Red Stuff
Ahhh... the Internets is a great inventioon, especially the Googles.
How many miles are ur current pads?
2009 CX-7
AWD
 Old 10-31-2011, 03:16 PM   #5
Groans: 196
Sorry, I meant EBC Redstuff. It's one word. I suppose Redstuffs might be plural.
 Old 11-04-2011, 12:00 PM   #6
Alpha Wolf's Avatar
Current OEM pads are the ones that came on the car.
50,000 miles on them.
Rear pads showed up but not the front. Seems they shipped the fronts out a day later separately. WTF? Why would you ship these separately?? Hope the fronts get here today...
Sorry for my short hand.. Red Stuff Pads.... LOL
 Old 11-04-2011, 05:54 PM   #7
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
Wooh, congrat Alpha for so many miles on your car. Just hitting 30000. Planing to keep this Car for a while.
Alpha Wolf likes this.
 Old 11-04-2011, 06:25 PM   #8
They are just breaking in at 50k! Try 85,500 miles!
 Old 11-04-2011, 07:52 PM   #9
There you go
 Old 11-05-2011, 07:41 AM   #10
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
72,000 miles here on OEM brakes!
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
 Old 11-06-2011, 05:20 PM   #11
Alpha Wolf's Avatar
Well I pulled the wheels and did the brakes today.
I was shocked actually at how much pad I had left. I expected them to be worn down. I could have gone another 25,000 miles from the looks of them ... LOL All 4 disks looked fine with no grooves etc so I just re-used them.
Red Stuff Pads come with extra backing plates and some of the clips.
I chose to clean and reuse the OEM clips and backing plates as they are Cadnium plated. And they have no wear on them.
I did use 2 cans of Brake Cleaner to clean everything up while I had it apart.
Very easy to do. Only thing to watch is the front inside pad has a clip that goes on the front side edge and it points away from the pad. Not sure what this is supposed to do but whatever.
Red Stuff pads come with a break in compound on the pads that does make some noise when using the brakes. As this extra abrasive is used to lap your pads to your disks. They stated that it takes between 200 and 600 miles to get through this layer and for the pads to quiet down. I only have 10 miles on the car today since installation.
First impression is braking power is good. It has a little more initial bite than the OEM.
After 600 miles I will test them out with some hard braking from 60 etc...
Quality pads. So far so good.
To get your pistons back in the calipers so you can put them back on the new thick pads, place an old pad on the piston, then use a C-Clamp of the correct size to clamp to the pad and the back of the caliper and it just goes in without any problem when you screw down on the clamp.
The two bolts holding the front calipers on are different diameter and length so pay attention as to which one came from what hole.
I used my impact gun to remove and then only lightly screw on the wheel nuts. Then I used my large torque wrench to tighten them down using an X pattern.
Front uses a 17mm to remove the bolts and the rear uses a 14mm.
The Following User Says Thank You to Alpha Wolf For This Useful Post:
Hectik1 (01-26-2012)
 Old 11-06-2011, 06:31 PM   #12
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
you should try corksport brake lines. i had them on my cx7 and they were awesome.
Sent from my iPod touch using Tapatalk
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 11-06-2011, 07:03 PM   #13
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
I think red stuffs is an oreo flavor
 Old 01-25-2012, 10:16 AM   #14
Alpha Wolf's Avatar
1000 mile update...
A lot of dust generated while the break in material was present.
Once that is gone very little dust present.
Quiet pads. No squeeks etc.
Power not that much different from stock pads.. A little more initial bite at light pedal pressure.
 Old 08-15-2013, 10:10 PM   #15
Alpha Wolf's Avatar
Update. 69,000 miles. on car.
Way less brake dust than the OEM pads.
After break in. they do not have as much initial bite than the OEM pads.
Still going strong no issues.
ThOrZwAr (07-05-2016)
 Old 08-16-2013, 03:44 AM   #16
Good stuff man!
Ordered Stoptech Rotors, Pads, SS Lines, Fluids.. Performance Racing MazdaSpeed 3/6 - Suspension & Brakes 10 04-02-2008 06:42 AM
Page generated in 0.36881 seconds with 27 queries
