> CX-7 > Wheels, Tires, Brakes & Suspension
  • 1 Post By Jeff23spl
 Old 04-04-2019, 10:58 PM   #1
Sissycx7's Avatar
Posts: 5   (View Stats)
Sissycx7 is an unknown quantity at this point
Default mazdaspeed rims
Hey guys, would mazdaspeed 6 fits my 2011 cx7 my stock rims 17” offset 45, speed rims is 18” 55 offset. Planning to put some 225/55/ rubber. Anyone experience on this size.
Thanks in advance
Sissycx7 is offline   Reply With Quote
 Old 04-04-2019, 11:19 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
proof-reading prolly hasn't played a major role in your life, but anything that fits on a ms6 rim prolly fits your cx7 fine, gl bro.
94 M
MS6
IS350
 Old 04-05-2019, 02:13 PM   #3
Sissycx7's Avatar
Thanks for your sarcasm reply. Fyi did try to looked it up and I did see anything about 55offset that would fit a cx7. I joined this group to ask for help but guess I’m wrong but thanks for your quick reply.
 Old 04-05-2019, 02:24 PM   #4
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Why wouldn't you just google the damn specs for each wheel? Duh.
 Old 04-05-2019, 03:03 PM   #5
Sissycx7's Avatar
I know the specs bru. I’m asking if it would fit.
*Sarcastic
Well if you can't search this forum then you're lazy as fuck.
Alot of hate here.
Last edited by Sissycx7; 04-05-2019 at 03:03 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-05-2019, 02:25 PM   #6
Db09ms3's Avatar
Posts: 536   (View Stats)
*Sarcastic
Stockish
 Old 04-05-2019, 03:20 PM   #7
Db09ms3's Avatar
I love you tho
Stockish
 Old 04-05-2019, 04:41 PM   #8
whatsabrooklyn's Avatar
Posts: 147   (View Stats)
whatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud of
https://www.autorimshop.com/mazda-cx...xoCKxYQAvD_BwE
here is an oem rim that is 18in with an offset of 50. (not 55 but close)
you could try to meet up with other mazdaspeed people at a nator group and ask them if you could try to see if the rim fits.
whatsabrooklyn is offline   Reply With Quote
 Old 04-05-2019, 05:35 PM   #9
Sissycx7's Avatar
Thanks for the reply man!
 Old 04-06-2019, 12:19 AM   #10
no problem, are you buying them off ebay or craigslist?
we do have a used section on this forum, but you have to donate to be able to view it. not sure if there are any wheels available on it but something to keep in mind..
 Old 04-06-2019, 09:53 AM   #11
Sissycx7's Avatar
Im buying it locally but still need some research if it fits
File Type: png C0B30655-C9E2-45F5-AD14-797DBE4FF517.png (10.65 MB, 7 views)
 Old 04-06-2019, 01:40 PM   #12
i would just go and ask if you could pop it on before you buy it. that may be the easiest way. or you could call mazda headquarters and ask them, they might be able to give some input
 Old 04-09-2019, 03:00 PM   #13
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
it ''wheel'' bolt up but to the CX7 since Mazda keep the same 5nuts patern for few decade. Just the usual cx7 wheel is wider for factory larger 235 vs 215.
( 7'' vs 7.5 or 8 not sure)
factory size is more like 235 60 18 so 225 55 exceed the usual 3% error margin. Speedo and shift point will be affected too.
Db09ms3 likes this.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
07 sti rims on mazdaspeed 6 almcbs MazdaSpeed 3/6 - Wheels & Tires 5 06-04-2012 10:55 PM
Page generated in 0.34457 seconds with 26 queries
