> CX-7 > Wheels, Tires, Brakes & Suspension
 Old 11-25-2014, 01:04 PM   #1
liamfm's Avatar
Posts: 9   (View Stats)
liamfm is an unknown quantity at this point
Default Rear brakes
Hi all,
1st post here. I'll keep it brief. At 58k my wife's cx7 needs new rear pads (so says the tech when BOTH her rear wheel bearings were replaced). There is a grinding noise under braking, and I know the parking brakes are in rough shape from lack of use.
I have new pads (akebonos), rotors (AC Delco Duralast) and new parking brake hardware and pads. I've done drum and disc brakes before, but never drum in hat parking brakes. Any diagrams or tricks I should know in advance would be great. I'll take a photo, and do 1 side at a time, but just wondering if there is the one trick that I'll only learn from someone having done it (or me doing it).
Thanks in advance. Bummed that the pads are worn after 58k, and that the rears wore faster than the fronts... I'll be checking the slides for sure to make sure everything moves well.
Best,
Liam
liamfm is offline   Reply With Quote
Mazda 3, need help with rear brakes nash2000 MazdaSpeed 3/6 - Suspension & Brakes 16 07-08-2014 11:56 AM
rear brakes smoking 98zjdave 2010 MS3 - Troubleshoot/Diagnostics 4 06-11-2013 07:38 AM
What fails with rear brakes? TWOptSL0W MazdaSpeed 3/6 - Suspension & Brakes 8 03-03-2011 06:57 PM
brembo brakes for the rear qtrmile beast MazdaSpeed 3/6 - Suspension & Brakes 17 02-22-2011 08:43 PM
do any MS3 rear brakes look like this?? ElBartoRex MazdaSpeed 3/6 - Suspension & Brakes 7 02-25-2010 01:54 PM
Page generated in 0.21760 seconds with 20 queries
