![]() Join Date: Jul 2014 Location: Minneapolis, MN
(Thread Starter) | Not Ranked : 0 score Has anyone found a harness or figured out a way to get the plug mounted outside, on the hitch? I'd prefer this much more than having to hang wires out the back when I've got something hooked up. I've found some how-tos that allow this on the CX-9, and I'm wondering if anyone has done the same with the CX-7. |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score Did exactly that with my 2010 GT. I purchaced the factory pig tail from Mazda which plugs right in the stock harness, the connection is behind the right rear plastic trim panel in the cargo area. It then goes through a hole in the floor which is sealed with a rubber plug. Very ease do it yourself install. |
(Thread Starter) | Not Ranked : 0 score Thanks for the reply! Do you have any sense of whether a non-OEM plug would be able to do the same? I'm mostly concerned with sealing around the pass-through point. Or am I better off just getting the Mazda pig tail and going with it? |
| Not Ranked : 0 score I went with the Mazda plug just for the clean and instalation but I dont see any reason you cant use any other plug, you just have to probe the wires and splice it into the harness. If I remember right I think theres already a rubber plug in the right rear floor to run the wires through, forgive my memory as I did mine four years ago shortly after purchace. |
| MS3 Tow Hitch | cesaros | Gen2 MS3 General Discussion | 30 | 05-20-2013 04:15 PM |
| Hitch options?! | json | CX-7 > Accessories | 7 | 02-13-2013 10:06 AM |
| Curt Class I hitch and wiring harness | SRTie4k | Mazdaspeed3/6 General Discussion | 10 | 07-31-2011 01:34 PM |
| Apricorn Aegis 250GB USB 2.0 External Portable Hard Drive w/ Built-In Plug $95.99AR Free Shipping | Haltech | Hot Deals Section | 0 | 04-04-2008 02:20 PM |
