> CX-7 > Accessories
 Old 01-17-2011, 08:20 PM   #1
geminiviper's Avatar
Posts: 81   (View Stats)
geminiviper has a spectacular aura aboutgeminiviper has a spectacular aura aboutgeminiviper has a spectacular aura about
Groaned at 22 Times in 2 Posts
Default Towing Hardware
I'm not sure where this should go, I hope this works...
I need to put a tow hitch on my 2008 CX-7 Grand Touring. I'm looking for a recommendation for what to buy. I have looked on the forums here but I can't seem to find towing threats for the CX7.
Do I need a class 2 or class 3 hitch? Where do I get a good wiring harness? And most important, where is a good place to get the hitch?
geminiviper is offline   Reply With Quote
 Old 01-17-2011, 08:35 PM   #2
Ntahndagirl's Avatar
Posts: 598   (View Stats)
Ntahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the worldNtahndagirl is the leader of the world
I would recommend going to a u-haul. They are usually pretty smart about hitches. as for the class, probably a class 2 cause of the weight limits on the vehicle. Good luck.
Ntahndagirl is offline   Reply With Quote
 Old 01-17-2011, 09:15 PM   #3
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
This might help.
Trailer Hitch for CX-7
Here are some hitches...DISCLAIMER: I have NO IDEA if these will work or not. The website recommends them for an '08 CX-7.
Discount Trailer Hitch Kits, Receiver Hitch & Trailer Hitches
Here's some more:
http://www.etrailer.com/hitch-2008_Mazda_CX-7.htm
and some more:
http://www.autoaccessoriesgarage.com...uck/Mazda/CX_7
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 01-18-2011, 05:08 AM   #4
ottoblotto's Avatar
Posts: 266   (View Stats)
ottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond repute
i got the oem mazda tow hitch and its worked out great. the dealership technician pitched a bitch cause it was the first one they did and apparently its a mother to install... but it looks good and as far as putting on a small trailer for my harley, its worked out just fine...
2011.75 BMW E90 M3
El-Superbeast-O
ottoblotto is offline   Reply With Quote
 Old 01-18-2011, 07:34 AM   #5
edwhayes's Avatar
Posts: 157   (View Stats)
edwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to all
From my experience, the factory hitch is usually the best but, if cost is an issue then UHaul has been good.
edwhayes is offline   Reply With Quote
 Old 01-18-2011, 11:46 PM   #6
lvdukerider's Avatar
Posts: 44   (View Stats)
lvdukerider has a spectacular aura aboutlvdukerider has a spectacular aura about
I purchaced my 2" Reese hitch from Auto zone for about $175 and the factory plug n play wire hook up from the dealer for $80 bucks. The install I did myself and was easy, just drop the muffler off the rubber hangers and slip it in place. you do have to file the mounting holes in the body just slightly as per the instructions to fit the mounting washers. I went with the 2" just because I have a 4 place bicycle carrier that is 2" and cant have it hanging out any farrther by using a 1" to 2" adapter.
lvdukerider is offline   Reply With Quote
 Old 01-20-2011, 12:28 PM   #7
Alpha Wolf's Avatar
Posts: 396   (View Stats)
Alpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the world
I have the factory hitch. Requires trimming the bumper but fits up high and is hidden. Just bolts on.
2007 Touring CX-7 Liquid Platinum
Kenwood DDX419 DVD/Bluetooth/CD/ Rosen headrest DVD/Game units CP-E CAI ETS 3" Black Powder Coated TMIC
Forge Black Powder Coated BPV Nitto 420 Tires Vogtland Lowering Springs. Tuned with VersaTune
Alpha Wolf is offline   Reply With Quote
 Old 02-13-2011, 04:14 PM   #8
So I got my hitch installed. In the end I purchased from etrailer.com. Here is the hitch and wiring harness I got. Because I have the Grand Touring package I had the tow package wiring in the rear panel where the tail light access is. The entire project took me about 45 minutes which seemed to take longer than it needed to, probably due to me not being auto mechanically inclined. The hardest part of the whole thing was dropping the muffler. It took me a minute to figure out that to get the rubber muffler mounts off was as simple as pulling them off... Figures. After that I filed the holes a bit bigger so I could fit the bolt and spacer in the frame. Etrailer.com made it super easy, they provided wire with a coil on one end which is used to "screw" the bolt into. Then loop the wire through the spacer and snake it into the frame. Took all of about 5 minutes to get the spacer and bolts in once the holes were filed. Lifting it up and having a second pair of hands would have been easier than doing it by myself lying underneath but it got done without too much trouble. Here are the links to what I bought, and here are some pictures.
Hitch:
Trailer Hitch for 2008 Mazda CX-7 - Hidden Hitch 90154
Wiring:
Custom Fit Vehicle Wiring for 2008 Mazda CX-7 - Tow Ready 118249
 Old 02-28-2011, 07:17 PM   #9
BLWNHR's Avatar
Posts: 7   (View Stats)
BLWNHR has a spectacular aura aboutBLWNHR has a spectacular aura aboutBLWNHR has a spectacular aura about
Wow, that's totally different to the Australian version! The AU version also doesn't require any cutting of the bumper.
I can get some shots of mine if anyone is interested.
BLWNHR is offline   Reply With Quote
 Old 03-01-2011, 03:05 PM   #10
Alpha Wolf's Avatar
Thumbs up
I would be interested to see what you are getting down under.
The reason is here most owners do not like to be able see the hitch hanging down...
 Old 03-17-2011, 10:36 AM   #11
I find that you really don't see it that well unless you look closely. It's hidden enough for me anyway. I just made my trip from southern Illinois (St. Louis Metro East) to eastern Idaho. I pulled a 5x8 trailer with around 1,000 pounds total for around 1,460 miles. I averaged 50 miles to the quarter tank. The CX7 didn't really have a problem towing it but I could feel the weight behind me. The wiring harness I used was great, easy to plug in. I ran it through the back floor over the heat shield to the harness. Overall I'm rather satisfied with it.
Fortunately I didn't really have to do any cutting when installing the hitch. A small mount of filing to make the hole bigger for the bracket was easy enough.
« - | winter mats? »
Spy Shots: Next Volkswagen Passat caught towing Haltech Automotive News 0 05-12-2010 01:10 PM
Video: Hummers still good for some things, like towing giant snowplows Haltech Automotive News 0 02-09-2010 11:00 AM
Dodge increases towing capacity of 2010 Ram on paper with no hardware changes Haltech Automotive News 0 07-29-2009 09:00 AM
REPORT: GM says next-gen hybrid pickups could have 50% better towing Haltech Automotive News 0 02-25-2009 05:00 PM
New Ace Hardware Coupon Codes - $10 off $50 or $20 off $125 + Free Ship to Store at Ace Hardware Haltech Hot Deals Section 0 04-15-2008 12:10 PM
Page generated in 0.31456 seconds with 28 queries
