![]() Join Date: Mar 2011 Location: Austin texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 17 Times in 4 Posts
(Thread Starter) | Not Ranked : 0 score So after everyone saying it cant be done i have figured out how to disable traction control. Pros: I can chirp tires and slide the car around turns. Cons: ABS Light is on, TCS Symbol is ON, Emergency Brake stays lit even when not engaged. You will not have abs when you have your switch turned off. Step 1. Open your fuse box. it looks like this [IMG] we are looking for the little black box on the left. here is another pic [IMG] step 2. you need to pull that box out. it takes some effort, but once it is out it is out. inside that box is the fuses for abs1 abs 2 and tcs. please take them out of the box. here are some pics of the box once it has been removed and fuses have been taken out. [IMG] [IMG] here is what all the fuses look like when the box is taken out and they are in there fuse holders [IMG] step 3. re insert the 7.5 amp fuse and 40 amp fuse in there respective locations leaving the 20 amp fuse out [IMG] the prong on the right side is the one supplying power. the one on the left is a negative terminal. step 4. install a switch and 20 amp inline fuse. the 20 amp inline fuse should be hooked to the right prong. [IMG] [IMG] step 5. go drive and enjoy. here is a pic of the lights on the dash when the switch is in the off position [ [IMG] [IMG] .now keep in mind this is not a perfect solution. and i used a very short switch i did not install in the cabin (yet) this was just a test to make sure it worked before i make a permanent installation. you will have to turn on your switch and then restart the car to re-enable traction control and abs, and the proper function of the emergency brake light. please use common sense when turning your tcs off. questions comments concerns? im here to help |
| The Following 7 Users Say Thank You to dgillie For This Useful Post: | Broxer (07-27-2011), KostasCX-7 (07-24-2011), mikomi (07-25-2011), Raider (07-24-2011), redneckrecon (07-25-2011), torquemaniac (08-16-2014), Zdraveca (07-26-2011) |
![]() Join Date: Jul 2008 Location: Columbus GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,824
| Not Ranked : 0 score WOW, I simply just push the DSC button and the TC is off..........this seems like a lot of effort.
__________________ |
| The Following 5 Users Say Thank You to Babyface For This Useful Post: | Ehdith (07-24-2011), manelscout4life (07-23-2011), SWAY (07-23-2011), TexasSpeed3 (07-23-2011), whos_MS3 (07-24-2011) |
![]() Join Date: Mar 2009 Location: Broomfield CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 823
Groans: 60
| Not Ranked : 0 score Does the CX-7 not have a DSC button? Does it have traction problems? Soo confused.
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph |
| The Following User Says Thank You to dsmluck For This Useful Post: | bcmountainspeed (07-23-2011) |
(Thread Starter) | Not Ranked : 0 score dsc button doesnt turn off traction control permanently. it comes back on at 30mph |
![]() Join Date: Apr 2010 Location: BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,102
| Not Ranked : 0 score so.......you're disabling your ABS also why? I'm equally confused
__________________ Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Die, You are forgiven. If I Live, I will kill you." Such is the Rule of Honor |
![]() Join Date: Nov 2010 Location: Houston Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,763
Groans: 190
__________________ ~2011 Liquid Silver MS3~ ---->> ZZB TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
(Thread Starter) | Not Ranked : 0 score im disabling abs because it is the only way to also diasble the traction control. unless someone comes up with a software solution. the two systems are on the same fuse |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,038
Groans: 123
| Not Ranked : 0 score Why do u need traction control off on a CX7? You live dangerously close to the edge my friend lol
__________________ 2003 Evo VIII BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever. Old: 2009 White MS3. Fully bolted and tuned. Sold |
(Thread Starter) | Not Ranked : 0 score im not neccesarrily going to be driving with it off 24/7. just on certain roads here in town where the traction control would otherwise hinder my fun. |
| Not Ranked : 0 score Well I think disabling your ABS is also going to hinder your "fun".
| The Following User Says NO Thank You to bcmountainspeed For This Un-useful Post: | bzwyatt (07-25-2011) |
Groans: 60
| Not Ranked : 0 score Really? Must be a CX-7 thing. I can burn rubber past 30 mph without any TC kicking on.
| The Following 2 Users Say Thank You to dsmluck For This Useful Post: | Babyface (07-23-2011), TexasSpeed3 (07-24-2011) |
(Thread Starter) | Not Ranked : 0 score its totally a cx-7 thing. the speed 3 and 6 have more hp. ours is tuned differently to give more low end torque and less hp to get the suv moving quickly off the line because it is so heavy. |
Groans: 60
| Not Ranked : 0 score Ahh ok.
(Thread Starter) | Not Ranked : 0 score And I know some of you are going to be saying why did I not buy a sports car. well, I owned 3 cars previous to this. I mazda6s 1st gen, srt-4 modified to 315 whp, and a 91 500sl. I was tired of tiny cars and wanted to try something sporty but bigger. The cx-7 is definitely way slower, but I appreciate how comfortable it is for long trips. and a spacious back seat also comes in handy |
(Thread Starter) | Not Ranked : 0 score update: After driving with tcs off for about 100 miles, I have no check engine light and the smile on my face wont go away. So far I have not felt or seen any ill effects. I did a permanent install in the cabin via a switch. and after the car is off and the tcs is turned on. I do not have to go through the process of resetting tcs by turning the wheel. |
![]() Join Date: Jan 2010 Location: Greece, Thessaloniki
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 58
| Not Ranked : 0 score when switch is on, the dash lights looks like christmas tree I'll try it
__________________ CX-7 2008 awd manual bnr s3 [SIGPIC][/SIGPIC] |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score THANK YOU!!!! ![]() I was looking for this since figured out that cannot be turned off. Only bad thing at your setup is maybe switch- there are some high current since fuse is 20 amps so maybe 40 amps relay and small switch in cabin could do better for longer period of usage. For others- this is not dangerous if you use it when it have sense. Do not use this on highway or other roads with good grip and high speeds or in rain if you do not know how to slide |
(Thread Starter) | Not Ranked : 0 score hmmm. never thought about that, so where would i install the relay? |
![]() | | #19 | ![]() |
Rep Power: 124 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 72
| Not Ranked : 0 score Learn to drive. Haven't people driven cars without ABS before? There was a time cars didn't have ABS, nor any traction control, brake assist, nannies, etc... My first car had no electronic nannies, not even power windows, A/C or power steering. And I drove that FWD beater through 7 winters in Canada. To this day, I still have a habit of pumping my brakes, hard to undo the poor man's ABS reflex.
__________________ FYHN |
| The Following User Says Thank You to mikomi For This Useful Post: | bzwyatt (07-25-2011) |
![]() | | #20 | ![]() |
![]() Join Date: Nov 2010 Location: Alhambra
Rep Power: 524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 237
Groaned at 35 Times in 14 Posts
| Not Ranked : 0 score Can't believe all these pussies... 'I'm so confused...' ... guess they're dumb too. |
| The Following User Says NO Thank You to bzwyatt For This Un-useful Post: | bcmountainspeed (07-26-2011) |
![]() | | #21 | ![]() |
| Not Ranked : 0 score On place of your switch. And switch could remote open/close relay via smaller wires from cabin. It could not be best if you take main wires into the cabin due to relative high possible current (20 Amps fuse). I will make this on short time and post some pictures. |
| The Following User Says Thank You to ro-bi For This Useful Post: | mikomi (07-25-2011) |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thank You Ro-Bi , I appreciate the help with the relay. I know my solution isn't perfect. I'm just hoping to get things moving in the right direction. I did this mod for the mercedes benz forum as well. one of the aftermarket companies was trying to charge us $1000 for this mod when i figured it out for $5.00 lol Also, what is up with all the guys complaining about abs being off. as Mikomi said. ABS hasn't been around forever. I miss my srt due to the fact that there was no traction control. I could just slide it and spin it if I wanted to. |
![]() | | #23 | ![]() |
| Not Ranked : 0 score This fix kinda reminds me of when I worked for a company in England that gave us a Vauxhall Corsa, GM's European equivalent of a Geo Metro, I think. We had a limited mileage allowance, so we looked for ways to drive the car without clocking mileage. We would pull the fuse on the speedometer. The trip- and odometers ran off the speedometer, or at least the same fuse, so that's all it took to disable them. I was shocked it was so simple to 'tamper' with the odometer, seemed like a major oversight. Nice fix dgillie. |
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score I appreciate the thanks. Someone had to find a way to get these things sideways. |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score any update on this? |
![]() | | #26 | ![]() |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
| Not Ranked : 0 score Brilliant find, I think the in cabin switch would make this ideal.
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score pic of in cabin switch. [IMG] my tcs disable is on the very left. the others are for lights which I got flamed for in other threads. btw to those of you who say you dont like how it looks, well good for you, I don't care |
![]() | | #28 | ![]() |
| Not Ranked : 0 score N0o time for some 14 days..... |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score NOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!! !!!!!! ah, oh well, i guess ill just have to be patient. I appreciate the update. |
![]() | | #30 | ![]() |
![]() Join Date: Aug 2008 Location: Salinas, CA
Rep Power: 197 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score I drove ro 25 years without ABS or traction control. Still have my 70 Bug which has neither. You can drive without it. But you cannot be a bad driver without it. ![]() Same with new sport bikes. They nanny ware them so guys who lack to skill to ride them can buy them and maybe not die. But for those who can it interferes with our fun.
__________________ 2007 Touring CX-7 Liquid Platinum Kenwood DDX419 DVD/Bluetooth/CD/ Rosen headrest DVD/Game units CP-E CAI ETS 3" Black Powder Coated TMIC Forge Black Powder Coated BPV Nitto 420 Tires Vogtland Lowering Springs. Tuned with VersaTune |
![]() | | #31 | ![]() |
![]() Join Date: Jun 2012
| Not Ranked : 0 score Not to revive an old thread, but i figured out the relay diagram if anyone wants it. |
![]() | | #32 | ![]() |
| Not Ranked : 0 score BTW if you do not understand these then just close your hood and go watch tv. This is in correspondence to the Fuses as seen when looking into the engine bay with the guide above. I am merely posing this to help with a more safe way of switching the system off and on. The first one is a outside powered switch setup. Meaning the switch receives its power from say the battery. Not sure if it needs fused or not but do it to be safe. . . . The next one is a self powering system, It uses power from the relays line itself to power the switch. Also not entirely sure if this one is correct but i dont see why not, i will be running it by my mod buddy tomorrow. . . . Enjoy and happy tire slipping. EDIT: The orange wire is ground FYI. |
| The Following User Says Thank You to GrandPapaSmurf For This Useful Post: | torquemaniac (08-16-2014) |
![]() | | #33 | ![]() |
![]() Join Date: May 2011 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Groaned at 340 Times in 107 Posts
| Not Ranked : 0 score Dude.. I can't even keep from crashing on Forza with ABS and TC off... Probably worse in the real world. |
![]() | | #34 | ![]() |
| Not Ranked : 0 score lol i play GT5 with ABS off and TCS off |
![]() | | #35 | ![]() |
| Not Ranked : 0 score UPDATE: ok i just built the relay self powering system today and installed it on my 2009 CX7 Touring and it works flawlessly. Now you dont have to stress about burning up a switch. |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score WOW! I appreciate the update. FYI I havent had any problems with mine at all. And It has been a year so Far |
![]() | | #37 | ![]() |
![]() Join Date: Dec 2010
| Not Ranked : 0 score For those who can't understand why anyone would bypass the TCS, here is a very real problems with the CX7 version. Since the CX7 is drive by wire, the TCS will essentially close the throttle if the slightest wheel spin is detected thus causing a very dangerous scenario when entering traffic or crossing a busy intersection. I have seen so many people report close calls thinking it was "turbo lag" when it was actually the TCS taking over the throttle. You romp on the gas pedal to get across the intersection before the next car approaches, the tires slip a little on the painted stripes then the TCS kills the engine as to stop the wheel spin (which is so slight) then has to recover when the so called slippage has ended. This process can take as much as a full second for each instance of spin. Now you are in the middle of the intersection with traffic barreling down on you and your fist instinct is to mash on the gas harder but nothing happens. Traction control can be a very useful tool for safety sake but Mazda got this one so wrong. It's far more dangerous in my opinion because of the way it controls the throttle so aggressively, not to mention that this being a turbo charged engine, every time the TCS kicks in, you loose whatever boost has spooled up because it gets bypassed when the throttle closes. I have experienced this problem first hand and pushing the button at every stop is retarded. In closing, there are better ways of invoking traction control other than killing the throttle but this probably was the easiest and least costly way to do it. Oh yeah I almost forgot, I almost got stranded in some mud because the TCS would not allow the throttle to go beyond idle and the only way the car was going to move was to get some wheel spin.Then it dawned on me that I should try pushing the button... It worked! Since the vehicle speed seems to be read from the rear wheels, it allowed the drive wheels to spin freely at least till the vehicle got up to the speed threshold. It may be possible to trick the computer into only seeing a speed less than 30mph while in TCS bypass. Just an idea. |
![]() | | #38 | ![]() |
Groans: 190
tappin from a N E X U S
__________________ ~2011 Liquid Silver MS3~ ---->> ZZB TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN | |
| The Following User Says Thank You to SWAY For This Useful Post: | Agent_Orange (06-25-2013) |
![]() | | #39 | ![]() |
![]() Join Date: Feb 2014 Location: Irvine, CA
| Not Ranked : 0 score excuse me if i missed it or ignorant... (or dumb LOL) why couldnt you just use the old "TCS" button? and would this new installed switch (in diagram above) flipped in the off position, disable the stock TCS button? |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Because it only disables it under a certain rpm or mph. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f128/how-actually-disable-traction-control-pics-86722/ | ||||
| Mazda CX-7 - Mazda - Suomi24 Keskustelut | This thread | Refback | 02-25-2015 02:44 PM | |
| Mazda CX-7 - Mazda - Suomi24 | This thread | Refback | 01-05-2015 02:51 AM | |
| Montreal Subaru Club ? Consulter le sujet - Qqun s'y connait en mazda? (anti-patinage CX-7) | This thread | Refback | 12-16-2013 12:39 PM | |
| Tuning Mazda cx-7 - Page 8 | This thread | Refback | 10-11-2013 04:55 AM | |
| traction control light on.... | countrymanjeff | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 04-01-2016 07:08 PM |
| can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? | btstarcher | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 06-17-2011 11:06 PM |
| Customizing Traction Control with LC | Trader | Cobb ATR Support | 6 | 08-19-2009 10:10 PM |
| Traction control light | tuners | MazdaSpeed 3/6 - Suspension & Brakes | 1 | 07-20-2009 06:14 PM |
| Traction Control (MS3 specific) | SLS MS3 | Cobb ATR Support | 15 | 06-08-2009 01:08 PM |
