> CX-7 > How-To's
 Old 11-04-2010, 09:41 AM   #1
Default How to: Clean your CX-7 EGR (Speed 3 based instructions, but should help)
EDIT: This is for people who want to retain the EGR. You can block it off and clear the CEL through AccessPort if you want. I elected not to, as I do not have an AccessPort.
I got a P0401 CEL at 51K miles on my 2007 Speed 3 the other day after 2 or 3 days of slow starts, where it would crank a while before firing up. Guy at Advanced who read the code said EGR was clogged, a $430 part from the dealer. Having owned a Protege 5, I knew what a stuck EGR was like, and how it can be cleaned, but no how-to posted yet for the Speed3 apparently. I read a few threads online, and here especially, so I am posting here first to share. This is how I did it. Feel free to do it differently if you feel like it. This is probably not the only way to do it. It is just how I did it. Don't like it? Well, sorry I guess. A 10 and 8mm deep and shallow socket, pliers, a 22mm wrench, flat blade and Philips screwdrivers, Brake Parts cleaner, and some coolant will be needed. Oh,and a person with skinny fingers.
1st, it is not that hard to do if you know a little bit on working on our cars already.
1st, where is the EGR. It is here:
Now what to do. To start, remove your OEM TMIC, battery and battery box. Also remove your turbo inlet pipe. loosen the top on the coolant overflow tank. Put a rag in the turbo.
The EGR is the silver thing with the black plastic on top. The pipe with 2 bolts coming out to the left of it is the EGR pipe.
There is a hose coming out of the back of the EGR, held on with a clamp. Pull the clamp back, disconnect the hose from the EGR, and let the coolant drain. You will lose a quart or so, the overflow will be empty.
Remove the 2 bolts holding the EGR on, and pull it out. Here is the EGR with the gasket on it. You cannot see it, but there is carbon inside, Nasty, but comes out easy.
Now go up tho the front to the throttle body. You may make a mess if you have not already removed the coolant lines from the throttle body like I did. If you did not, do it now.
Remove the throttle body by taking out the 4 bolts:
Remove the 2 bolts holding the back part of the EGR pipe on
Now use that 22mm wrench, loosen the bolt holding the front part of the EGR pipe now visible:
remove the pipe:
Admire the nice pile of carbon in front of the pipe.
Feel free to blow compressed air through the pipe while it is removed. If clogged, use a coat hanger or something, and get out as much as you can. You might need to take it to a mechanic to get it dipped in parts cleaner if you do not have it.
Skipped pics, but remove the 4 screws holding the plastic top of the EGR valve. Don't strip or break them. They are as a strong as Dollar Tree trash bags.
There is a plunger. It is stuck. spray with brake cleaner on the holes, until clean, Scrape out carbon if needed.
Then reinstall everything.
The end.
ConnerSpeed6 (09-18-2012), Lancer-AM (10-23-2014), ottoblotto (11-20-2010)
 Old 11-15-2010, 08:48 AM   #2
Headbasha's Avatar
Posts: 85   (View Stats)
Headbasha is a splendid one to beholdHeadbasha is a splendid one to beholdHeadbasha is a splendid one to beholdHeadbasha is a splendid one to beholdHeadbasha is a splendid one to beholdHeadbasha is a splendid one to beholdHeadbasha is a splendid one to behold
Here are my pictures of cleaning it on the CX7
Headbasha is offline   Reply With Quote
The Following 3 Users Say Thank You to Headbasha For This Useful Post:
mikomi (11-20-2010), ottoblotto (11-20-2010), Raider (11-19-2010)
 Old 11-19-2010, 09:00 AM   #3
Thanks for the extra pics!
 Old 08-12-2011, 06:37 AM   #4
mjonesjr8's Avatar
Posts: 4   (View Stats)
mjonesjr8 is an unknown quantity at this point
YouTube - egr pipe valve dirty
Hey i'm in adamsville, Al saw you post about cleaning the valve, how hard of job is this? mY wife's cx7 is throwing this code.
thanks
Morris
mjonesjr8 is offline   Reply With Quote
 Old 08-12-2011, 06:42 AM   #5
Welcome! Check out post #1, has all the details. IF you are mechanically inclined, you can do it.
 Old 08-12-2011, 07:15 AM   #6
mjonesjr8's Avatar
Great thanks,
we have nothing but mazda's in the family lol
'09 RX8 R3
'07 MX-5
'09 CX-7
Raider likes this.
 Old 08-12-2011, 07:42 AM   #7
R3's are badass. I will probably get a rotary next, and with kids, an RX-8 is probably in the plans.
If you have OEM Nav, consider donating the $25 for VIP access. The 2011 Nav update is posted here to download and burn. It will also give you access to the buy/sell section, where things like exhaust systems and intakes are for sale by members. Pre-owned and big cost savings! Yes, she wants an exhaust, she just does not know it!
 Old 08-17-2011, 08:02 AM   #8
Indierocker7's Avatar
Posts: 9   (View Stats)
Indierocker7 will become famous soon enoughIndierocker7 will become famous soon enough
Thanks for the write-up and pics! This was a huge help, since my wife's CX-7 just threw a p0401 code. It was a lot of work for me (a novice) but after 50 miles the code has not come back. Probably need to do a Sea Foam treatment next to clean the rest of the gunk out.
Cheers!
Indierocker7 is offline   Reply With Quote
 Old 08-17-2011, 08:10 AM   #9
mjonesjr8's Avatar
ditto I just did my wife's cx-7 ydat major PIA but, if it works worth the work.
thanks again
'09 RX8 R3
'07 MX-5
'09 CX-7
 Old 08-17-2011, 08:19 AM   #10
Happy to help! If it helps, please consider making a donation to MSF, or going VIP.
 Old 01-09-2012, 08:47 AM   #11
dwdpt's Avatar
Posts: 3   (View Stats)
dwdpt is an unknown quantity at this point
Default no power or rpm check engine light is still on
2007 CX-7 2.3 MFI turbo DOHC 75,000 miles
I performed the egr valve cleaning service as outlined. I had no problems and it went smoothly.
Now when I start the engine it will idle but it has no power and the rpm's will not go above 2000. It is like something is limiting the rev's.
Also the CEL is still on
Before the egr service, the CEL was on and I got the po401 EGR code, but the engine ran well.
Will the computer limit the rev's as a protective measure or something or did I break something ?
Any advice ?........... before I have it towed to the dealer Thanks
dwdpt is offline   Reply With Quote
 Old 01-09-2012, 08:52 AM   #12
Something is obviously not connected.
1) Small hose from the TIP to the boost control solenoid, connected?
2) MAF- connected?
Post up pics.
For sure, something is not connected.
 Old 01-09-2012, 08:57 AM   #13
dwdpt's Avatar
I will check it all again
thanks
 Old 01-09-2012, 12:33 PM   #14
mjonesjr8's Avatar
Yeah sounds like a vac line or something
Might be off.
 Old 01-10-2012, 09:17 AM   #15
Any update?
 Old 01-19-2012, 09:15 AM   #16
dwdpt's Avatar
Well I finally figured it out.
Somehow 2 of the wires going to the female part of the throttle body connector ended up deep into the plastic connector. When I snapped it back on the wires were so far into the female part of the connector they were not making contact with the male part. I pushed the 2 wires forward into the female part of the connector snapped it in place rechecked the wires to make sure that they were all the way into the connector and it is running fine.
The CEL has gone off and all seems well.
Now I have to deal with the dreaded VVT start up noise problem. I am trying to make a decision about this situation.
It is a 2007 CX-7 Grand Touring Edition, Black with grey leather interior in all in excellent condition. 75,540 miles the VIN# is in the range of the TSB for the VVT start up noise debacle.
I have fixed the oil cooler leak problem and the EGR/CEL problem. What’s next with this engine ?
It needs tires, $800 and the VVT problem $1400 fixed.
In your opinion, it worth putting the $2200 into it, or should I trade it off as is ?
I also got a price for the Mazda MEPP Primary Care Plan. The 24000 miles / 2 year warranty costs $1663 with a $100 deductible.
What’s you opinion on an extended warranty?
Tires $800 + VVT $1400 + MEPP $1700 = $3900
Trade in value is around $9,500
Any advice would be appreciated
 Old 01-19-2012, 09:22 AM   #17
The only issues really with these cars have been the AC Compressor, VVT, turbo seals, and EGR issue.
I priced our 07 GT with Tech at 88K ended at $12,000 trade-in.
If you do not want to put another dime into the car, trade it in. Just make sure you fully inspect it before buying, whatever it is.
 Old 05-25-2012, 09:10 PM   #18
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
Originally Posted by rs4playseo View Post
The building Lord really invincible, thought very have routines.
wtf kinda vooda wishwash gibrish shit is this? just reading sent me on a fucking acid trip and caused me to lose iq points. wtf?? troll maybe i cant tell this shit made me dumb!
 Old 06-07-2012, 07:11 AM   #19
nafteli's Avatar
Posts: 2   (View Stats)
nafteli is an unknown quantity at this point
Raider would you recommend doing this or using seafoam first?
nafteli is offline   Reply With Quote
 Old 06-07-2012, 07:17 AM   #20
Get the chevron techron fuel system cleaner, the large one. Use it for a tank and then if still on, clean it.
nmdonahoe likes this.
nafteli (06-07-2012)
 Old 06-08-2012, 05:08 PM   #21
nafteli's Avatar
Just spent the last 2.5 hours doing this task.. it was hell lol. but much thanks for the post it saved me about $730!
 Old 06-08-2012, 05:24 PM   #22
Glad it worked! Please consider donating $25 to the forum. Gets you VIP access, lots more info!
 Old 06-09-2012, 10:35 AM   #23
dgillie's Avatar
Posts: 142   (View Stats)
dgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud ofdgillie has much to be proud of
Groaned at 17 Times in 4 Posts
my extended warranty has covered a new turbo, ac comoressor, and vvt service all for about $300. also if you shop onkine you can find decent tires for about $600. just a thought
dgillie is offline   Reply With Quote
 Old 06-08-2013, 11:45 AM   #24
bsnyder's Avatar
bsnyder is an unknown quantity at this point
Cleared my cel but now my tcs light flashes. Any thoughts?
bsnyder is offline   Reply With Quote
 Old 06-08-2013, 11:52 AM   #25
Drive it over 40 mph?
 Old 06-08-2013, 11:59 AM   #26
Of not, drive.
 Old 06-08-2013, 12:20 PM   #27
bsnyder's Avatar
Actually have not.drivin. Will do thanks.
 Old 06-08-2013, 12:32 PM   #28
DoMiNic's Avatar
Posts: 571   (View Stats)
DoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the worldDoMiNic is the leader of the world
Groaned at 8 Times in 7 Posts
That is one sexy short/jacket combo.... Not helping the man crush I have on you Raider. Its mostly your power I,m attracted to but also the stitching on the 1992 starter jacket. You got beard rubbin credit with me big guy,
Nice write up.
TIP/AP-OTS-2/MS-SRI/JBR-88d-RMM/HPFP-Autotech/Ebay Downpipe/JBR-SP/Forged-BPV-v1.2/JBR-Boost-Tubes/WL-RSB/SPEC-CA/TWM-STS/JBR SB/TWM-Phantom-4in extension/Eibach-ProKit/Koni-Yellows/JBR-5mm-spacers/PCed-black-RX8s/Alpine-SWA-10S4/Alpine-M250/JBR-recirc-tube/DRAMA-E28-Tuned
Sold
08 FJ Cruiser Expo build in progress...
DoMiNic is offline   Reply With Quote
 Old 08-06-2013, 11:20 AM   #29
Project_dog's Avatar
Posts: 333   (View Stats)
Project_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond reputeProject_dog has a reputation beyond repute
Groaned at 7 Times in 5 Posts
With 77k on my cx7. Should I do this?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4
2007 Mazda CX-7: Custom FMIC, Forge V1 BPV, Grimmspeed 3 port EBC, BNR S3 turbo, 3 inch Catless DP, Muffler Delete, JBR 3.5 intake, Autotech HPFP Internals, JBR OCC, Vogland Springs. Stereo: Two Memphis 10" Subs, 2 Memphis 1.500 Amps. Memphis 4.50 Amp, Image Dynamics Components and Coaxials.
Project_dog is offline   Reply With Quote
 Old 08-06-2013, 11:26 AM   #30
Only if getting P0401. Just throw in some Chevron Techron Complete Fuel System Cleaner tho, helps me out.
 Old 08-06-2013, 11:29 AM   #31
I have no cel on.
 Old 08-06-2013, 11:36 AM   #32
Then drive on, sir.
 Old 10-13-2013, 06:17 PM   #33
mazafoger's Avatar
mazafoger is an unknown quantity at this point
i got p0401 code and autozone guy told me egr and clear code for me so i take off egr valve check resistances and pipe and trottlebuddy clean but i did not found any clog now i don't have that strong boost kick like before check engine pup up . any idea??? 2009 65k
mazafoger is offline   Reply With Quote
 Old 10-13-2013, 06:41 PM   #34
Follow the steps on cleaning it. The pipe or the egr is clogged, or egr is sticking.
 Old 03-19-2014, 07:47 PM   #35
psunikki's Avatar
Posts: 1   (View Stats)
psunikki is an unknown quantity at this point
I got the wretched p0401 code and gave it a stab at cleaning the egr valve. Now my car is making an odd sound like air leaking out of a balloon when the rpms hit 2500 and I am accelerating. Soon as I take my foot off gas sound stops. Once I get going fast enough like cruising speed on highway it stops ven ifd at 2500 rpms. Any idea of what I did wrong? So frustrated.
psunikki is offline   Reply With Quote
 Old 03-19-2014, 08:19 PM   #36
Loose clamp somewhere.
 Old 07-18-2014, 11:55 AM   #37
bkdow's Avatar
Posts: 5   (View Stats)
bkdow is an unknown quantity at this point
I'm new here and newish to Mazda. I have a question about SeaFoaming: Do I disconnect the brake booster and just let 6 oz just get sucked in?
bkdow is offline   Reply With Quote
 Old 07-18-2014, 03:55 PM   #38
Brake booster. BUT, now we know it does NOTHING to improve anything, don't waste time and money. Clean the egr and be done.
 Old 07-18-2014, 04:15 PM   #39
bkdow's Avatar
Poo
 Old 07-18-2014, 04:44 PM   #40
bkdow's Avatar
Dealer wants $860 and my local guy wants $1,000 to replace it. UGH!! Anyone got an idea?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f128/how-clean-your-cx-7-egr-speed-63603/
p0401 cx 7 This thread Refback 08-11-2015 04:49 PM
How Many Quarts Of Oil Cx 7 2011 | Free Auto Repair Manuals Download This thread Refback 07-24-2014 10:09 PM
?????????? ???? : ???????, ??????? ??? ???????. - ????????????? ????????????? ???? Mazda CX-7, CX-9 - ???????? 3 This thread Refback 02-26-2014 04:27 AM
?????? ???????? - ????????????? ????????????? ???? Mazda CX-7, CX-9 This thread Refback 12-23-2013 08:51 PM
I'm a female who doesn't know shit about her Mazda. Help? : mazda This thread Refback 10-29-2013 11:12 AM
?????????? ???? : ???????, ??????? ??? ???????. - ????????????? ????????????? ???? Club-CX.ru - Mazda CX - ???????? 3 This thread Refback 06-03-2013 10:08 PM
How to: Clean your EGR (Speed 3 based instructions, but should help) | MCX7 Community Forums This thread Refback 05-11-2013 02:42 PM
Bumming out about my 08 CX7 | MCX7 Community Forums This thread Refback 04-18-2013 03:23 AM
DIY Replacement of EGR Valve_CX7 | MCX7 Community Forums This thread Refback 03-26-2013 05:42 PM
DIY Replacement of EGR Valve_CX7 | XenForo This thread Refback 03-16-2013 06:51 AM
DIY Replacement of EGR Valve_CX7 This thread Refback 01-12-2013 06:00 PM
?????? ???????? - ????????????? ????????????? ???? Club-CX.ru - Mazda CX This thread Refback 04-13-2012 03:09 PM
5earch This thread Refback 04-07-2012 03:37 PM
Bumming out about my 08 CX7 This thread Refback 08-25-2011 11:18 AM
How to: Clean your EGR (Speed 3 based instructions, but should help) This thread Refback 06-15-2011 06:39 PM
?????? • ???????? ???? - ?????? ? ???????????? Detroit Auto Show This thread Refback 01-17-2011 07:13 PM
How to: Clean your EGR (Speed 3 based instructions, but should help) This thread Refback 11-08-2010 09:23 AM
new break in instructions..... jracer Mazdaspeed3/6 General Discussion 4 06-24-2010 11:35 AM
Standback Installation Instructions, Please CosmicArkie MazdaSpeed 3/6 - ECU Computer Tuning 1 01-10-2010 09:31 AM
cpe tow plate instructions wisniaPl Custom Performance Engineering (cp-e.com) 3 06-28-2009 06:13 PM
Hamann introduces Bentley Continental GT Speed-based Imperator Haltech Automotive News 0 04-15-2009 12:30 PM
Page generated in 0.57702 seconds with 34 queries
