> CX-7 > How-To's
 Old 11-04-2010, 10:00 AM   #1
Default How To: CX-7 Door Panel Removal
From Mazoom:
OK so you wanna remove your door panel?
Here's how!
First, simply remove the door handle cover, to remove the cover you will need to stick a flat head screw driver in the bottom of the cover like this
*Don't forget to take off the upper black trim on the other side of the mirror.* Makes it a lot easier.
Then after that you have two screws, the tunnels are long and the screws are not small so make sure you have a nice longish screw driver.
After those two you only have two more to go.
One is behind the door pull, hidden behind the cover, in order to get behind the cover you will need a flat head screw driver.
Then, unscrew!
After that you have one in the little pocket in the door, behind the felt stuff, just remove that and unscrew.
Go to the side of the door, and pull right where I am, and pull out and up, you might have some fasteners left on the door, and that can be a pain, just use that same flat head to pop them out and back on to the door panel.
Then, pop out the door pull after you have the panel off of the door, and the one window switch harness and you're done!
The same applies for the rest of the doors, the driver side door has 3 harnesses hooking into it and the rest should have one.
 Old 05-12-2011, 09:31 AM   #2
ryandlor's Avatar
Posts: 126   (View Stats)
ryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant futureryandlor has a brilliant future
This door doesnt resemble mine at all.
I got a 2009 Base AWD. Anyone have diff write up? Trying to get some new speakers in.
2009 CX-7
Platinum Silver Metallic
AWD
ryandlor is offline   Reply With Quote
 Old 05-12-2011, 05:12 PM   #3
edwhayes's Avatar
Posts: 157   (View Stats)
edwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to alledwhayes is a name known to all
Thanks Raider. You made a difficult job look easy. Looks exactly like my 2007.
edwhayes is offline   Reply With Quote
 Old 05-12-2011, 08:17 PM   #4
Mazoom posted it. Ryandlor, post pics of yours!
 Old 05-13-2011, 12:28 PM   #5
ryandlor's Avatar
Heres ya go. Im dumbfounded, I dont want to pay BestBuy $100 to install my speakers.
2009 CX-7
AWD
 Old 05-13-2011, 12:32 PM   #6
Looks the same to me, only the one mazoom posted was the passenger door.
 Old 10-09-2015, 05:38 PM   #7
speedhump's Avatar
Posts: 1   (View Stats)
speedhump is an unknown quantity at this point
Question Door removal
I was asking about the lower rear door panel. Any ideas?
speedhump is offline   Reply With Quote
Rotor Removal FantasmoNegro MazdaSpeed 3/6 - Suspension & Brakes 20 11-10-2013 02:28 PM
MS6 ECU removal kore2000 MazdaSpeed 3/6 - ECU Computer Tuning 14 01-27-2010 03:19 PM
Removal of pill phantom3 MazdaSpeed 3/6 - Turbo Induction 3 10-22-2009 12:02 AM
Door Trim Removal MS6... Driverman5777 MazdaSpeed 3/6 - Appearance 3 02-13-2009 12:24 AM
Page generated in 0.27732 seconds with 24 queries
