> CX-7 > How-To's
 Old 11-04-2010, 09:55 AM   #1
Default How to: CX-7 Standalone Foglight Mod
Fog light standalone
I didn't like how the fog lights cannot be turned on unless the headlights are on, so I looked into the wiring tonight and here are what I used to bypass this setup:
Time: 1 hour
Tool: Wire stripper and wire crimper, your preferred gauge of wire (I used 18 gauge), male & female quick disconnects (4 female, 3 male), small flat head screw driver, filler, 1 wire splicer connector and electrical tape.
Here were some tools used:
Open the hood and locate this relay box on the passenger side:
Remove the cover and see the relay for the fog lights is the relay on the left. (Other models may be different. DIY is made with a Sport model):
Remove the fog relay and set it aside:
File down a male connect. For reference, the connector on the left is an unfilled one and the connector on the right is after filled.
Get the wires and quick disconnects and make 3 wires and another wire as shown in the picture.
Install the wires onto the relay like so and put electrical tape onto the 2 vertail prongs (when facing the prongs) then put the relay aside:
Remove the relay box by pressing on these 3 locations and pull the box out. The yellow narrow is where the connector that was filled down need to go in. The red narrow socket will be left unplugged:
Use the flat screw driver and separate the bottom cover of the relay box by pulling on these 2 taps on each side of the relay box:
Stick the flat head screw driver into an unused socket to make room for the wire to come through. Might have to repeat the step on both the front and back:
Afterwards, connect the male connectors to it’s original sockets and run the long wire through the unused socket hole that was gutted:
Install the wire splicer connector on the end of the long wire and tap the other wire shown below (it’s a red wire with silver dots underneath the horn relay):
Tuck the wire under the relay box and install the bottom cover back to the relay box and it should look like this now:
Feels good to see my own work:
Test the fogs now:
 Old 05-03-2015, 04:24 PM   #2
Johnybeas's Avatar
Posts: 19   (View Stats)
Johnybeas is a jewel in the roughJohnybeas is a jewel in the roughJohnybeas is a jewel in the roughJohnybeas is a jewel in the rough
cool post but half of the pics are gone. don't mean to be the necromancer of 5 year old threads but I found this when searching... lol
Johnybeas
Smokey '92 SVX LS-L 3.3 AWD Project Car
Hydra Nemesis II,2nd motor, custm catback exhaust w/ 2 1/2 in. pipes flowmaster camero style muffler & twin 3 1/2 in tips, green cold air, 17" American Racing Casino's, '02 WRX 5spd, Pioneer Avic-f900bt, Alpine Type S Speakers(6.5's,6x9's)2 Kicker CVR12's custom enclosures
SiX '07 Mazda Speed6 2.3T AWD Daily Driver
HKS SSQV Limited Edition Black, AEM CAI, StreetUnit cold pipe, Stoptech Cross Drilled Rear Rotors and Stoptech Street Perf. Pads, Mercelli M25 18x8 front and 18x9 rear rims, smoked tailights, red fogs, Custom 3.5mm Aux plug
Lightning '99 Acura Integra LS Sold
AEM Intake, Catback exhaust, Halo headlights, clear turn signals, Tinted
The Beast '07 Ford F350 XLT Superduty 4x4 V8 Sold
Johnybeas is offline   Reply With Quote
 Old 05-03-2015, 10:44 PM   #3
I can if I backed it up this week.
 Old 05-15-2015, 08:12 AM   #4
About to fix it. Found pics I backed up.
 Old 05-17-2015, 04:07 PM   #5
Johnybeas's Avatar
sweet glad they are all there now! good write up!
Johnybeas
 Old 05-01-2016, 09:18 AM   #6
SpicyOrangeMSP's Avatar
Posts: 236   (View Stats)
SpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the worldSpicyOrangeMSP is the leader of the world
Great write up! Thanks! I did not have blade connectors so I just cut the wire and tapped into the wire from the horn relay like you did. Actually do not tap the horn relay cause the light will stay on even when the car is off. Tap into the pink wire which is only on with ignition on.
SpicyOrangeMSP is offline   Reply With Quote
 Old 07-21-2017, 09:14 AM   #7
Jpd686's Avatar
Posts: 3   (View Stats)
Jpd686 is an unknown quantity at this point
I can't see these pictures again... Is this from just my account not being VIP or the hoster needing to update his account on photo bucket.
Jpd686 is offline   Reply With Quote
Haltech Standalone Sprint 500 Brian MP5T MSP - ECU Computer Tuning 12 08-04-2013 01:23 PM
Haltech Standalone ECU Brian MP5T MSP - ECU Computer Tuning 14 06-19-2012 02:44 PM
Standalone on MS3 holeinmypocket MazdaSpeed 3/6 - ECU Computer Tuning 3 03-21-2010 06:39 PM
Standalone ECU subparpunk03 MazdaSpeed 3/6 - ECU Computer Tuning 28 03-08-2009 04:51 PM
EMS/Standalone ptperformance MazdaSpeed 3/6 - ECU Computer Tuning 16 11-30-2008 05:45 PM
Page generated in 0.30970 seconds with 23 queries
