> CX-7 > How-To's
  • 1 Post By BillsFan
 Old 02-08-2011, 01:04 PM   #1
Alpha Wolf's Avatar
Posts: 396   (View Stats)
Alpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the world
Talking How To Install a ETS (or any other) TMIC on your CX-7
Once you open you hood the first job is to remove the engine cover/TMIC duct
There are two snaps that hold it down to the radiator support. Use a flat blade screw driver to pop the middle up and then they just pull out. Do not loose these.
Next just pull toward you and up and the cover will come off the two rear studs holding it in place.]
Remove the TMIC screen. Two bolts on the front need to be removed. Once removed push it back and up and the rear should unclip and come loose. Screw bolts back into TMIC so they do not get lost.
Next you need to remove the intake hoses from the TMIC. There is a clamp on each hose. Unscrew it until loose. Now twist the hose in a circular motion until it unsticks from TMIC. Now push it off being careful not to let the clamp fall off. Once off, tighten clamps just enough so they will not fall off until you are ready for them.
Now remove the hoses on the BPV valve. A pair of pliers and pinch the tabs together will loosen the clamps. Slide clamps down the hoses. Next push the hoses off the BPV nipples.
If you are also upgrading your BPV valve, remove the two bolts holding the BPV valve onto the inlet neck.. Once off, place BPV in large zip lock bag so no dirt/dust can get inside it and put the two bolts in there with it so you do not loose them. You will need the bolts to re-install you BPV valve.
Now remove the nuts off the studs holding down the TMIC. Be careful here as it is easy to drop them. I recommend when you are nearly off, you finish with your fingers. Now remove thw washer on top of rubber grommets. I use a magnet for this to insure I do not drop any of these.
Now lift TMIC straight up and off. Be carefull you do not dislodge any of the grommets and inserts on the studs and loose them.
Now that the stocker is off, unbolt the inlet neck. 4 small bolts. Clean the gasket or use a new one. Once gasket is clean, install inlet on the ETS TMIC. I recommend you use a tiny 1/4" ratchet as you are torquing steel bolts into aluminum and if you strip it you will have to install inserts. BE VERY CAREFUL and DO NOT OVER TORQUE those bolts.
Once the inlet is off, clean and seal up your stock TMIC as you may need it for warranty trips etc. I used painters tape over the openings. Then place a flat piece of card board over the radiator on both top and bottom and tape them together to hold them on. This will keep the fins from being damaged while stored.
Install the inlet onto the ETS TMIC with the 4 bolts you removed. If you are upgrading the BPV valve install new BPV valve and carefully tighten the two bolts. Again, steel bolts into aluminum!!!!
Remove grommets from stock TMIC and install on to the ETS TMIC. Now install the inserts with cylinder if you removed them from the studs back onto the studs. Now lower the ETS TMIC onto the studs being careful not to push the grommets out of the feet.
Install washers on top of grommets and then install and tighten the nuts. Note on mine the front foot was jigged wrong and was sticking up at a 45 degree angle and not sitting flat. I can tell you how to fix this if you encounter this. ETS says they fixed their jigs but just an FYI.
Now I put a little WD 40 on my finger and lube the part of the intake tubes where they go onto the TMIC and a little on the TMIC lip. Push both tubes all the way up until they are flush with the lip. Now slide clamps up until in the middle of the lip of the TMIC and tighten both of them down.
Now slip the two hoses back onto the BPV. Slide the clamps back up to seal them on the BPV nipples.
Double check:
1. That you have all TMIC mounting nuts on and tight.
2. That none of the grommets has come off during the iinstall.
3. That the both inlet hoses are on flush and that both clamps are tight.
4. That the BPV is on and both bolts are tight.
5. That both BPV hoses are on and both clamps are back on and tight and sealed.
Now disconnect the negative post of your battery. A few minutes later put it back on. Yes you will have to go through all the window clock radio stuff. Hold each window button up until it rolls up and clicks. Reset your clock. Reset your radio presets.
Now start your car. Turn you wheel lock to tock and then turn the car off.
Start car again and verify no odd noises and no warning lights.
Good to go.
2007 Touring CX-7 Liquid Platinum
Kenwood DDX419 DVD/Bluetooth/CD/ Rosen headrest DVD/Game units CP-E CAI ETS 3" Black Powder Coated TMIC
Forge Black Powder Coated BPV Nitto 420 Tires Vogtland Lowering Springs. Tuned with VersaTune
Alpha Wolf is offline   Reply With Quote
The Following 5 Users Say Thank You to Alpha Wolf For This Useful Post:
bzwyatt (02-09-2011), ottoblotto (02-09-2011), Raider (02-08-2011), skeeter149 (02-23-2011), Zdraveca (03-18-2015)
 Old 02-08-2011, 01:24 PM   #2
Thanks for resurrecting the thread. This is a biggee for the Cx-7 people. Keep in mind, my wife installed her TMIC on her CX-7 back in the day. So n00bs, it is easy for the newer gearhead.
 Old 02-08-2011, 01:38 PM   #3
char181's Avatar
Posts: 167   (View Stats)
char181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond repute
Groaned at 10 Times in 3 Posts
Nice write-up with excellent photography.
Black Mica 2010 Speed3; Xcel Nano SRI; JBarone short shifter, bushings, shift knob and rear sway bar; Corksport RMM inserts; Ptp HPFP internals; Cobb AP; Corksport TMIC; Denzo ITV22;
CP-e CDP; Tuned by Ptuning
char181 is offline   Reply With Quote
The Following User Says Thank You to char181 For This Useful Post:
Alpha Wolf (02-08-2011)
 Old 02-08-2011, 01:43 PM   #4
Oh, and please note. Galaxy Gray CX-7's show a 25% additional bHP increase over any other color CX-7.
 Old 02-09-2011, 10:16 AM   #5
ottoblotto's Avatar
Posts: 266   (View Stats)
ottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond reputeottoblotto has a reputation beyond repute
thats right bitchez.
2011.75 BMW E90 M3
El-Superbeast-O
ottoblotto is offline   Reply With Quote
The Following User Says Thank You to ottoblotto For This Useful Post:
 Old 02-09-2011, 10:19 AM   #6
Alpha Wolf's Avatar
But the Liquid Platinum are 25% lighter .....
 Old 02-09-2011, 10:27 AM   #7
That is because they don't put any airbags into them. Just balloons. Wheels are made of recycled toilet paper too.
 Old 02-09-2011, 11:09 AM   #8
Alpha Wolf's Avatar
ROFL...
Tires are filled with Helium.....
 Old 02-09-2011, 01:42 PM   #9
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
brilliant black is win!
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 02-12-2011, 07:17 AM   #10
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
The truth!
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
 Old 02-23-2011, 09:57 AM   #11
mikomi's Avatar
Posts: 148   (View Stats)
mikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to beholdmikomi is a splendid one to behold
New revised mod install guide
Materials
- part to installed
- a couple of buddies
- a flat or more of cold beer
- tools
Instruction
- mix everything (give buddies beers, tools, parts)
- done!
FYHN
mikomi is offline   Reply With Quote
 Old 03-20-2011, 07:28 PM   #12
BillsFan's Avatar
Posts: 476   (View Stats)
BillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the world
OK - so I had a free 45' minutes today and decided to do a quick TMIC swap - but the inlet hoses were not on board with this plan. I could get them to twist, but not get them off the stock TMIC.
Any secret tricks anyone can offer. They are the stock hoses and likely haven't been touched in 50k miles. Should of had Wheaties for breakfast instead of Waffle House.
I'll have free time either Thursday afternoon or Friday morning for take 2 - suggestions for getting those mofo's off is welcome.
Lastly - any issue with keeping the stock gasket between the TMIC and the inlet neck. If that's not advisable I'd rather have the gasket in advance - anyone now the part number?
"Most of the time — and this includes naps — I'm an F-18, bro"
BillsFan is offline   Reply With Quote
 Old 03-20-2011, 07:34 PM   #13
Small flat blade screwdriver. Try to break the bond between the two. Or, look for used Street Unit hoses in the speed 3 and CX-7 Forrest sale section. If not, get em new. Just a thought.
 Old 03-21-2011, 07:08 AM   #14
BillsFan's Avatar
Yeah - that's what I figured. I'll try again after eating some spinach...
 Old 03-21-2011, 10:04 AM   #15
mikomi's Avatar
if they can rotate, they'll come off with a little elbow grease. a little penetrant spray or wd-40 also helps.
FYHN
 Old 03-23-2011, 10:49 AM   #16
Alpha Wolf's Avatar
What Mikomi said.
Small flat blade screw driver to pry lip up carefully. Squirt a little WD40 in between and do this around the circumference until it breaks free.
Put a little WD40 on with your finger on the inside of the hoses when you go to put them back on. Makes it a whole lot easier..
 Old 04-04-2011, 07:08 AM   #17
BillsFan's Avatar
Done - What Alpha said that Mikomi said was right, was!
Installed and no CELs. Did have a "problem" that when taking out the old unit the entire post came out on the front left side. Guess that nut didn't want to come out. Separated him from the post, got the post back in, etc.
Also had to put an extra washer under the strut brace, but at least I knew I'd be doing that before I had it all buttoned back up!
Took a little longer having my daughter lend a hand (she's 9), but she likes working on cars, so what the hell.
msf ftmfw
Alpha Wolf likes this.
 Old 04-04-2011, 06:32 PM   #18
mikomi's Avatar
Future car person right there.
FYHN
 Old 04-06-2011, 07:46 AM   #19
Billsfan, nice install!
 Old 04-06-2011, 11:21 AM   #20
BillsFan's Avatar
She's a car person now - insists that we go to the new car show ever year, helps with oil changes, did the tune up (i.e. spark plug, oil and air filter) on the lawn mower last year!
Once I got the hoses loosened up - I spent more time removing the strut tower and dealing with the TMIC mount post than anything.
Last edited by BillsFan; 04-06-2011 at 11:21 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-06-2011, 11:38 AM   #21
Alpha Wolf's Avatar
Nice job Billsfan!
Nice to hear you are get the next generation of motor heads involved
 Old 04-06-2011, 12:08 PM   #22
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Was this thread really necessary? Anyone who does anything to their car has prolly taken their TMIC off/on about a million times...
3 bolts and 2 hose clamps... 15 minutes total
 Old 04-06-2011, 02:06 PM   #23
For someone who might not know how to do it, yeah. Keep in mind, I wrote the how-to originally back in early 2007 for a different forum, being one of the first to install one on a CX-7. It has helped a lot of n00bs who have not worked on their car, get the job done.
tritom45ca (03-02-2017)
 Old 04-07-2011, 06:46 AM   #24
BillsFan's Avatar
Basically - what Raider said. This is my first turbo and the first car that I've done any modding with beyond the airbox, so...
 Old 04-07-2011, 07:01 AM   #25
jstcruzin's Avatar
Posts: 152   (View Stats)
jstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the worldjstcruzin is the leader of the world
Looks good...hope my daughter will enjoy and want to help around the cars when she gets older too
09 CX-7 GT - cp-e Xcel intake w/ Nviscid pipe, ETS TMIC, HKS BPV, autometer boost gauge
jstcruzin is offline   Reply With Quote
 Old 04-12-2011, 03:29 PM   #26
Alpha Wolf's Avatar
Cool
Materials
- part to installed
- tools
Instruction
- done!
Might be done or it may be BOOMMMMM!!!!!
Depends on who your friends are and how much beer was consumed before/during the install...
While those of us with any basic mechanical ability no. I just did it.
But we have had so many ask who have never touched a wrench and now want to do this and they are nervous about doing anything that in their minds may damage their cars.
So it is here to help those that need a little help. For those that do not need help they will never bother to even look at this thread...
Last edited by Alpha Wolf; 04-12-2011 at 03:30 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-18-2015, 12:00 AM   #27
kawaxi's Avatar
Posts: 25   (View Stats)
kawaxi has a spectacular aura aboutkawaxi has a spectacular aura about
Can you upload the pics again? Some of them are not showing
nevermind.... turns out it was my tablet...
kawaxi is offline   Reply With Quote
 Old 03-18-2015, 12:45 AM   #28
kawaxi's Avatar
 Old 03-18-2015, 04:11 AM   #29
I was wondering! Lol.
 Old 11-09-2016, 06:50 PM   #30
09 cx7 Mods's Avatar
Posts: 5   (View Stats)
09 cx7 Mods has a little shameless behaviour in the past
Default ets speed 3 10-13 tmic
looking at ets tmic w shroud for speed 3 ,,will it fit my 09 cx7??
09 cx7 Mods is offline   Reply With Quote
ETS TMIC Problems after install (Help!) Bujwazay MazdaSpeed 3/6 - Turbo Induction 17 02-10-2011 07:40 PM
New noise after TMIC install ebnash 2010 MS3 - Turbo Induction 24 02-05-2011 01:49 AM
ETS TMIC Install? iracer7 MazdaSpeed 3/6 - Turbo Induction 9 07-02-2009 06:56 AM
Page generated in 0.50847 seconds with 32 queries
