> CX-7 > How-To's
Like Tree6Likes
  • 2 Post By Raider
  • 1 Post By Raider
  • 1 Post By Raider
  • 1 Post By Raider
  • 1 Post By JBert
 Old 11-04-2010, 09:53 AM   #1
Default How to Seafoam your CX-7
Using this tube:
I disconnected it and I can confirm that this tube had a strong suction and sucked up all 3/4 of the can that I had put into a clear container. Thought the idle was rough during the time the tube was disconnected, I wasn't able to kill the engine when I dumped the tube into the last bit of fluid. So I just turned off the car, reconnected the hose and waited 15 minutes.
I started her up and whew... a ton of smoke came rolling out of the tail pipes and filled my neighborhood with smoke. Folks next door where not too impressed.
But after 20 minutes the smoke cleared and I took her out on the highway and drove her pretty hard for about 5 minutes, just to clear out any remaining crap.
So far so good, no CEL's (did I mention that I had a P0401 prior to any of this.) Overall I'm pretty happy with myself and glad I did it myself, learning all the components of my first turbo engine was a bit fascinating.
Mike's CX-7:
Finally did the Seafoam thing and so far so good. Right after I got a random misfire CEL, then a week or so later cylinder 4 was misfiring. Don't know if related, but I swapped the plugs and everything is fine now.
Was really easy to do this... biggest pain was that you have to get the Seafoam into the brake booster line very slowly. Feels like forever.
Although you can reach with the plastic shroud on, you should remove it. Then just get the clamp out of the way and pull - hard - to get the brake booster line apart.
It will idle rough, especially while you are getting the Seafoam in there. You have to balance how much you allow the brake booster line suck up so you don't stall it out right away. I used a full can, about a little more than 3/4 slowly then dumped the rest to stall and flood the engine. Dumping the whole can into something clear first helps. I used an empty and clean Propel bottle (like a water bottle).
Once you get it all in there let it sit (off) for 20 minutes or so, then turn it back on and hook up the brake booster line. It stalled out once more for me, but after that I idled for 20 minutes and got this smoke:
But after 20 minutes the smoke didn't stop... so I revved it and got tons of smoke! I had to run it ~2,500-3,000 RPMs for another 20 minutes before it finally stopped.
Now that the smoke has cleared along with the CELs, I've had no more CELs and it even seems to run a little better overall. Time will tell if I'll get the EGR CEL back anytime soon.
***Just note: In the 5 years since this was made, seafoaming is not really recommended. With our Direct-Injection, the valves will not get cleaned. IT is also known to kill O2 sensors. If you want to clean the valves, you need to take the intake manifold off and do it (look for how-to's). Also, Chevron Techron Complete Fuel System cleaner cleans the fuel system better (and helps unstick the EGR) so do this at your own risk***
rfinkle2 and djmojo like this.
dajuice27 (05-13-2011)
 Old 03-06-2011, 08:18 AM   #2
BillsFan's Avatar
Posts: 476   (View Stats)
BillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the world
Done! Nice and smokey
"Most of the time — and this includes naps — I'm an F-18, bro"
BillsFan is offline   Reply With Quote
 Old 05-05-2011, 03:36 PM   #3
Jake_MS3's Avatar
Posts: 859   (View Stats)
Jake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the world
Any chance you could post the picture showing which hose you disconnected. For some reason its not showing up. I'd use the brake booster line, but I can't reach it lol.
2009 Mazdaspeed 3
Jake_MS3 is offline   Reply With Quote
 Old 05-05-2011, 06:45 PM   #4
Crap, pics went poof. Will fix tomorrow. Here is the one you want!
Jake_MS3 (05-05-2011)
 Old 05-05-2011, 06:55 PM   #5
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i love that we felt the need to make a how to seafoam your cx7 when its no diff than how to seafoam your ms3
good work lol
 Old 05-05-2011, 07:03 PM   #6
Actually, the location we connect is different.
 Old 05-05-2011, 07:08 PM   #7
good work lol
I find myself not going into the Cx-7 parts of the site (I drive an ms3), and I guess it could be
possible that some cx-7 guys stay in their dedicated section.
 Old 05-05-2011, 07:10 PM   #8
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
looks the same to me
 Old 05-05-2011, 07:14 PM   #9
You guys might forget, we left a dedicated cx-7 forum to be here. We moved all the how-to's here. There might be dupe threads, but they have cx-7 owners in mind. Fucking Christ.
rfinkle2 (05-06-2011)
 Old 05-05-2011, 08:17 PM   #10
JBert's Avatar
Posts: 54   (View Stats)
JBert is a jewel in the roughJBert is a jewel in the roughJBert is a jewel in the roughJBert is a jewel in the rough
Everyone has an opinion on here
Justin
08 Mazda CX7 GT
Turbo + AWD = Can't be wrong
JBert is offline   Reply With Quote
 Old 05-06-2011, 06:40 AM   #11
BillsFan's Avatar
good work lol
Thanks for caring and checking in on us...
 Old 05-06-2011, 06:46 AM   #12
@Raider , I don't want you to get the wrong impression of my post. Even though one of the lines is in a different spot, I think your thread is useful, and thanks for taking the time to do the write-up and take pics etc.
 Old 05-06-2011, 07:33 AM   #13
Fink, I was poking back at Lenny.
 Old 05-06-2011, 07:36 AM   #14
I thought so, and I might have been also.
 Old 05-13-2011, 03:19 PM   #15
dajuice27's Avatar
Posts: 15   (View Stats)
dajuice27 is an unknown quantity at this point
Raider,
As always you've been helpful. I just followed your instructions ( I also threw a P0401 code last week) and man was there a lot of smoke! My car took the first 3/4 through the brake booster line, the remaining Seafoam will go through the gas lines to clear out the fuel system.
Thanks again!
Hey, you in the Toyota - you SUCK ASS!
dajuice27 is offline   Reply With Quote
 Old 05-14-2011, 03:19 PM   #16
Seafoam is only good for a few weeks. You gotta clean the EGR. If you remove the 4 tops screws of the valve (catch that metal gasket!) you can push on the EGR valve plunger ad see if it sticks. If so, take it off and clean it. If smooth, take the pipe off, it is clogged.
FWIW. 4 drives, CEL goes out.
 Old 08-15-2012, 05:52 AM   #17
Prodoco's Avatar
Posts: 5   (View Stats)
Prodoco will become famous soon enough
is it OK to use Vacuum line with blue clip that right next to the TB? please see attached.
Prodoco is offline   Reply With Quote
 Old 08-15-2012, 06:05 AM   #18
Not sure where that is in orientation of the tb, but everyone else is using the brake booster. I'd use that.
 Old 11-24-2012, 05:58 PM   #19
JBert's Avatar
Going to do this tomorrow along with an oil change and new spark plugs. Will update on the results.
Raider likes this.
Justin
08 Mazda CX7 GT
 Old 02-22-2014, 03:21 PM   #20
turbotrey's Avatar
Posts: 10   (View Stats)
turbotrey is an unknown quantity at this point
Tried to do this today but I can't get the brake booster cable off at the firewall. I undid the clamp and the tube is stuck on there. Any trick to getting it off?
turbotrey is offline   Reply With Quote
 Old 02-22-2014, 05:22 PM   #21
Might be pretty stuck on at this point. And after so may years, to truly clean the valves, it's known you need to take the intake manifold off and manually do it.
 Old 02-22-2014, 06:06 PM   #22
turbotrey's Avatar
CEL is on throwing EGR code. Thought I'd try this before going into it any further.
 Old 02-22-2014, 06:50 PM   #23
There is a how to for cleaning the egr. I wrote it.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f128/how-seafoam-your-cx-7-a-63610/
How to seafoam cx 7 - 1Q5A This thread Refback 07-19-2014 08:29 PM
How to Seafoam your CX-7 | MCX7 Community Forums This thread Refback 03-28-2013 10:18 AM
EGR valve | MCX7 Community Forums This thread Refback 03-27-2013 09:14 AM
EGR valve This thread Refback 01-27-2012 09:51 AM
How to Seafoam your CX-7 This thread Refback 06-16-2011 11:06 AM
How to Seafoam your CX-7 This thread Refback 11-09-2010 11:05 PM
No Smoke SEAFOAM? SpeedSixxx MazdaSpeed 6 - Engine, Transmission & Driveline 6 03-08-2010 04:58 PM
Here's a video of my car after Seafoam NJSPEED3 MazdaSpeed 6 - Engine, Transmission & Driveline 21 01-01-2010 05:32 PM
Seafoam to clean our carbon deposits, where to feed it in? bast525 MazdaSpeed 3 - Engine, Transmission & Driveline 46 11-03-2008 08:38 PM
Page generated in 0.40565 seconds with 30 queries
