> CX-7 > How-To's
 Old 04-27-2011, 03:12 AM   #1
Shazza's Avatar
Posts: 35   (View Stats)
Shazza has a spectacular aura aboutShazza has a spectacular aura about
Default Installing CPe Catback Exhaust
Hi All...
I just received my new CPe catback (only), and wonder if anyone has any tips for the install.
One question I have is do I re-use the gasket between the stock muffler and the STANDARD mid section pipework..??
Thanks...!!!
Shazza is offline   Reply With Quote
 Old 04-27-2011, 03:26 AM   #2
dspider's Avatar
Posts: 119   (View Stats)
dspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud ofdspider has much to be proud of
i am guessing you are reffering to the quickpower pipe which deletes the second cat?or is it the axle back muffler.?. yes you need to reuse the gasket or you can use the high temp silicone stuff and then bolt the pieces together..
install is not too bad, a few wrenches and a floor jack or a friend to help and you are good to go
[SIGPIC][/SIGPIC][/SIGPIC]Just to be fair i hate everyone equally , so dont feel left out.
dspider is offline   Reply With Quote
 Old 04-27-2011, 04:57 AM   #3
You can reuse it if it is not damaged.
 Old 04-27-2011, 05:20 AM   #4
Grumpyjap's Avatar
Posts: 1,839   (View Stats)
Not to sound like a jerk, but the cat-back comes with instructions.
The Following User Says Thank You to Grumpyjap For This Useful Post:
rfinkle2 (12-18-2012)
 Old 04-28-2011, 10:00 PM   #5
Shazza's Avatar
The gasket is not mentioned in the destructions.....
 Old 04-29-2011, 01:38 AM   #6
Shazza's Avatar
That was fun.......
Certainly a different sound. Deeper, and a bit boomy. Time and carbon will settle it a bit. A nice long drive should help settling the sound down.
I am pretty impressed by the fact is actually fitted without the need for "creative metalwork." I'll give it a week to settle on the hangers, and then check the alignments.
 Old 04-29-2011, 10:56 AM   #7
Silver Ecstasy's Avatar
Posts: 2,450   (View Stats)
Silver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the worldSilver Ecstasy is the leader of the world
Groaned at 81 Times in 33 Posts
Mike
2008.5 CWP Mazda CX-7 Sport FWD - hers
2008.5 CWP Mazdaspeed 3 GT - traded
2011 LSM Mazdaspeed 3 Sport w/tech pkg - sold
Silver Ecstasy is offline   Reply With Quote
The Following User Says Thank You to Silver Ecstasy For This Useful Post:
bertrand_CX_7 (04-29-2011)
 Old 04-29-2011, 11:24 PM   #8
Shazza's Avatar
The exhaust is just audible at cruise speeds. Otherwise, it is probably a bit louder than what I anticipated. Funny thing is that my Partner is quite happy with it.
Here you go. A couple of pics. is it normal for tips to sit that low and have the welds so visible? They sit ~1 inch below the bumper.
 Old 05-06-2011, 06:47 PM   #9
Shazza's Avatar
A question for those that have the catback, and then added the Quick Power pipe.
How much louder was it?
 Old 05-07-2011, 06:41 PM   #10
Shazza's Avatar
I have to say, that after fitting this catback, my fuel economy has definitely become worse. There is no doubt as far as I am concerned.
The economy for the same driving has gone from 13.9L/100km to 15L/100km. Cruising economy is shockingly worse than before.
Now before you all tell me about "resetting" the ECU, that's been done by virtue of testing with a few different tunes. All return worse economy than before. I'm OK with having a nice exhaust note, and this one is really too LOUD, but when performance and economy suffer, I need to find out why.
has anyone seen worse economy?
Re-installing Stock Exhaust Silver Ecstasy MazdaSpeed 6 - Engine, Transmission & Driveline 0 07-27-2010 09:41 PM
catback exhaust axela2004 2010 MS3 - Turbo Induction 18 05-08-2010 03:24 PM
Page generated in 0.29639 seconds with 24 queries
