> CX-7 > How-To's
 Old 11-24-2010, 07:50 AM   #1
BillsFan's Avatar
Posts: 476   (View Stats)
BillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the worldBillsFan is the leader of the world
Default Jacking points for CX-7?
Any opinions on the best place to jack the front / rear using a floor jack?
BillsFan is offline   Reply With Quote
 Old 11-24-2010, 07:59 AM   #2
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
Search "jacking points". There's a huge thread on this.
EDIT: sorry, didn't realize this was in the CX-7 section.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline   Reply With Quote
 Old 11-24-2010, 08:43 AM   #3
The manual has it. I cannot post the link for some reason, but its on the sides far forward and rear on the seam.
BillsFan (11-30-2010)
 Old 11-30-2010, 06:26 PM   #4
BillsFan's Avatar
I know (but thanks!) - I want to put the front end up on jack stands and thought it would be easier to centrally jack the entire front up and then lower. Not sure I can get a jack stand along side the jack at the typical jack points.
 Old 11-30-2010, 06:28 PM   #5
Yeah, no center point. If changing oil the ramps ftw.
 Old 11-30-2010, 06:42 PM   #6
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
BTW where can I get/buy those ramps Raider.
It'll be the next to have tool
I hope with ramp you mean the 2 metal you drop on the floor such that when driving on it with the 2 front wheels, It'll raise the distance between bottom of the car and the floor.
Thanks
 Old 11-30-2010, 06:50 PM   #7
Lol, yes. You can get them at Sears, Home Depot, Lowes, etc. Must hold 4000 lbs or more. I got some old metal ones from a friend that can hold up a tank.
 Old 11-30-2010, 07:20 PM   #8
bscar's Avatar
Posts: 1,846   (View Stats)
bscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the worldbscar is the leader of the world
Groans: 46
too many breakable things in the middle of the front end, so it'll hafta be from each side.
Or, get one of those garage floor lifts if you have a place to put them
bscar is offline   Reply With Quote
 Old 11-30-2010, 07:25 PM   #9
The small brace behind the crossmember is $200 to have replaced when you bend the shit out if it trying to jack up the entire front end, FYI.
 Old 11-30-2010, 07:55 PM   #10
BillsFan's Avatar
Yeah - I'd like to avoid that - have ramps for the oil changes.
Wanted to pull off both front wheels at once (HID install) - I'll live.
Thanks for the feedback.
 Old 12-01-2010, 01:55 PM   #11
Alpha Wolf's Avatar
Posts: 396   (View Stats)
Alpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the worldAlpha Wolf is the leader of the world
I have used the front suspension joint to the rear of front tires.
Alpha Wolf is offline   Reply With Quote
The Following 2 Users Say Thank You to Alpha Wolf For This Useful Post:
BillsFan (12-02-2010), mikomi (12-01-2010)
 Old 12-01-2010, 01:58 PM   #12
The last time I remember to have jack up the car using the engine as mount point.
The Following User Says Thank You to bertrand_CX_7 For This Useful Post:
Raider (12-02-2010)
 Old 12-02-2010, 10:51 AM   #13
Alpha Wolf's Avatar
Cool
Cast aluminum engine cast/pan etc not a good place to mount a jack or jack stand.
 Old 12-02-2010, 01:49 PM   #14
Hope you guys got it,
I was Kidding
 Old 12-02-2010, 02:00 PM   #15
We cannot tell with you, but hell, give it a shot.
 Old 12-02-2010, 10:50 PM   #16
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
There are indentations in the sheet metal along the sides under the doors. I grab a small piece of wood (so it doesn't bend the metal) and jack it up.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
The Following User Says Thank You to Hectik1 For This Useful Post:
Black(M) (02-03-2011)
Mazdaspeed 3 Shift Points 86AmishMs3 MazdaSpeed 3 - Engine, Transmission & Driveline 35 07-21-2014 10:04 AM
Jacking up the car bart1313 2010 MS3 - How-To's 2 07-12-2010 08:18 AM
Fuel Pump Internals Points of Failure kore2000 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 27 02-22-2010 09:15 AM
FIA approves new Top 10 points system for F1, WRC Haltech Automotive News 0 02-11-2010 04:30 PM
Page generated in 0.35156 seconds with 26 queries
