 Old 03-15-2019, 11:08 PM   #1
jabz's Avatar
Posts: 7   (View Stats)
jabz is an unknown quantity at this point
Default Amp Power wire to battery help for MPS3
Hi, I am attempting to route the power wire for amp through to the battery in my Wife's Mazda Speed 3 (Axela) Jap import, I am in New Zealand so it is a right hand drive.
Theres no factory AMP in this MPS3.
I've done some searching and it seems people are going through the firewall where the aircon pipes are. However when I look at our MPS 3, that place is pretty inaccessible by fingers, since the entire area has some heat shielding and the engine goes ALL the way to the back.
Any other suggestions?
Im installing an under seat Cerwin Vega VPAS12 Sub/Amp unit
Pics attached.
1st Pic is Zoomed out where the Aircon pipes are located.
2nd is zoomed in, pretty impossible to get hand/fingers into this space.
3rd is Right hand side, drivers footwell/pedals showing where the pipes come into cabin
4th battery bay
5th Left hand side, Passenger side under glove box area on the right
6th Left hand side, Passenger side under glove box area on the left
jabz is offline   Reply With Quote
 Old 03-16-2019, 01:24 AM   #2
jabz's Avatar
Actually never mind, some major pushing and finally got it through the firewall.
I assume one of the seat bolts can act as a ground?
 Old 03-18-2019, 10:38 PM   #3
Jayzon's Avatar
Posts: 103   (View Stats)
Jayzon has disabled reputation
Sounds like you got it, it takes quite a bit of pressure to get through the firewall. The seat bolts will probably work, I went with one of the bolts near the door.
Back to Stock
Jayzon is offline   Reply With Quote
why there is an orange/yellow wire drilled into my ecu coming from the plug, connected to the red wire in the harness? jabeel00 MazdaSpeed 3/6 - ECU Computer Tuning 30 08-15-2015 10:38 PM
How To: Wire V1 to switched power FrewBrew MazdaSpeed 3/6 - Car Audio & Electronics 7 07-05-2013 07:33 PM
Backup wire and speed sensor wire? Fozzy MazdaSpeed 3/6 - Car Audio & Electronics 4 06-01-2013 05:43 AM
Meth power wire questions Boost Addict MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 13 11-29-2012 12:31 AM
What's the wire on top of the power steering pump? mordant80 MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-03-2009 10:26 AM
Page generated in 0.24261 seconds with 22 queries
