 Old 05-03-2018, 12:41 PM   #1
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
Default Dash vents
Are the gen one speed3 dash vents the same as a speed6 near the doors?
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 05-04-2018, 06:29 AM   #2
GroceryGtr's Avatar
Posts: 472   (View Stats)
if I get a chance to get to the junkyard this weekend I can find out. They have a few 3s I need some random connectors off of anyways so I could grab a vent and test fit it. I assume they just pull out of the dash like most vent cans?
 Old 05-06-2018, 08:05 PM   #3
LenSpeed6's Avatar
@grocerygtr i know that the 6's you just pull them off, at least the dash vent by the doors.
sorry for the late reply, got a bunch of parts in so I've been thrashing on my car to get some work done on it.
thank you very much for looking for me!
06 Speed6
Smell in vents Highestrich4 Mazdaspeed3/6 General Discussion 10 01-22-2013 12:57 PM
Knock from ac vents? rcalt25 Gen2 MS3 General Discussion 5 11-22-2011 09:18 PM
AC Vents FWD=WWD MazdaSpeed 3/6 - Appearance 3 04-03-2009 11:17 PM
Cooling vents? red07 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 10-28-2008 12:20 PM
Page generated in 0.23784 seconds with 21 queries
