 Old 04-23-2017, 07:38 PM   #1
Legal-z's Avatar
Posts: 1   (View Stats)
Legal-z is an unknown quantity at this point
Default eBay aux adapter
Does anyone have any experience with the $5.00 eBay auction adapters for mazdas past 06 like this one: https://www.ebay.com/p/?iid=14175105...pp=true&chn=ps
I've searched the forum and just found people piecing together there own contraptions and soldering things in neither of which I am good at so if anyone knows if these actually work that would be awesome.
Legal-z is offline   Reply With Quote
 Old 05-14-2017, 11:05 AM   #2
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
looks like it uses the cd changer inputs. if you dont have a cd changer it should work. ive used similar adapters that plug in the changer input. id suggest a ground loop isolate too, if you hear engine noise
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
 Old 11-28-2017, 11:20 AM   #3
Intrance's Avatar
Posts: 8   (View Stats)
Intrance will become famous soon enough
Apologies for bumping this older post but my question is on the same topic and I figured it would make more sense to post here than create a new topic.
I am also not great at soldering and DIY wiring, so I was looking at these AUX cables. However, my M6 MPS has the 6CD changer, though it is broken, will not load any discs. Could anyone tell me if it will still have the CD changer port available on the back, just with a plug already in it?
Would happily disconnect that for an AUX in port for my phone.
Mazda 6 MPS || Unknown history || Unknown mods, feels stock || I have no car modding or maintenance experience || Just love this Mazda
Intrance is offline   Reply With Quote
 Old 12-01-2017, 10:33 PM   #4
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Unless you have an oem cd changer in the glovebox or trunk or the OEM SAT radio add on the port should be present and empty.
The Following User Says Thank You to SSinstaller For This Useful Post:
Intrance (02-23-2018)
 Old 02-23-2018, 02:45 AM   #5
Intrance's Avatar
I'm unbelievably late on the reply, but thanks for the info! Will order one of those adapters and see if it works properly in the near future. Just need to get my MS6 road legal again, inspection has lapsed due to airbag light being permanently on. Airbag code #44 .
Page generated in 0.26273 seconds with 23 queries
